Emblems |
Emblems |
Mueller |
Jul 27 2017, 12:35 AM
Machined here in California, 3mm thick by 20mm tall (.120" x .787")
Can be made larger or smaller, with or without chamfers. Sorry no pins or studs, these are to be adhered using double stick tape (not supplied) Prices: $10 per letter or number, for example the 3.0 sample will be $20 plus shipping. The 914-GT will fit in a small USPS flat rate box which is currently $7 |
76-914 |
Jun 14 2023, 10:01 AM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,500 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Sweet. Asian? Power feed? DRO?
Mueller |
Jun 14 2023, 03:23 PM
Sweet. Asian? Power feed? DRO? Chinese base machine with Taiwanese linear rails and ballscrews. Full CNC control so the computer will control the speeds and feds and has a DRO. My lathe is all manual with hand cranks and that has DRO. I'm looking forward to doing some 3D machining which this should be ideal at. |
76-914 |
Jun 14 2023, 07:29 PM
Sweet. Asian? Power feed? DRO? Chinese base machine with Taiwanese linear rails and ballscrews. Full CNC control so the computer will control the speeds and feds and has a DRO. My lathe is all manual with hand cranks and that has DRO. I'm looking forward to doing some 3D machining which this should be ideal at. I've never seen you post anything about your lathe but I figured you had one. This Old Tony has a good video about replacing the ball screws.Can't wait to see you turn out some things on the mill. Bitching! (IMG:style_emoticons/default/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 13th May 2024 - 01:20 PM |
