Progress!, Gotta be on the road for Rte 66 Classic |
ThinAir |
May 24 2005, 10:31 PM
Best friends Group: Members Posts: 2,542 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
Now you see it:
ThinAir |
May 24 2005, 10:32 PM
Now you don't:
ThinAir |
Oh - there it is!
ThinAir |
May 24 2005, 10:33 PM
It's been 16 months since I lost the oil and froze it up. It's almost weird to see it back where it belongs! I'm hoping I'll be able to try and fire it up on Thursday!
P.S. - That new motorcycle jack made this the easiest Type IV install I've ever done. This post has been edited by ThinAir914: May 24 2005, 10:34 PM |
MoveQik |
May 24 2005, 10:41 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Damn that looks good!!! I knew I should have powder coated the tins to match the car. Damn it! damn it! damn it! (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
ThinAir |
May 24 2005, 10:43 PM
I WISH it was powder coat. It's just Ace Hardware rattle can paint, but it's called Sunflower Yellow and it matches the VW Sunflower Yellow on the car.
SLITS |
May 25 2005, 12:25 AM
Yellow IS Faster..................... (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif)
redshift |
May 25 2005, 01:34 AM
I can't see it! It's too yellow!
M |
ThinAir |
May 26 2005, 01:05 AM
This may look like just any ordinary, fast 914 resting quietly next to it's beloved jackstands, but no - this 914 touched the ground at 11:45 p.m. tonight for the first time in many, many, many months. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
It didn't seem fair to the neighbors to try and fire it up anymore tonight so I'll hold that for tomorrow when I get home from work. I can hardly wait, but I'm also as nervous as can be. After fixing the clutch tube, moving the fuel pump, and overhauling the engine I'm hoping that all goes smoothly tomorrow. Watch this space for updates tomorrow! P.S. - I saved the worst job for last. I HATE reattaching the outer ends of the axles! Getting them to line up is pure guesswork and just when you are ready to give up they suddenly drop into place. This post has been edited by ThinAir914: May 26 2005, 01:16 AM Attached image(s) |
VegasRacer |
May 26 2005, 01:43 AM
ELVIRA Group: Benefactors Posts: 8,503 Joined: 27-March 03 From: Between Scylla and Charybdis Member No.: 481 Region Association: None |
Good luck Ernie.
You will soon be rewarded for you many hours of work. |
CptTripps |
May 26 2005, 06:15 AM
:: Punch and Pie :: Group: Members Posts: 3,584 Joined: 26-December 04 From: Mentor, OH Member No.: 3,342 Region Association: Upper MidWest |
Good luck man...I've been there. It's an awesome thing when they fire up after a long-long nap!
brant |
May 26 2005, 09:47 AM
914 Wizard Group: Members Posts: 11,622 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
good luck.....
having another 914 leave its jackstands is a good thing!!!! brant |
ThinAir |
May 26 2005, 11:00 PM
Well, no luck tonight. First I discover that I hadn't hooked up the transmission ground strap - can't believe I missed that. I check everything else and discover that I missed plugging in the alternator harness to the relay board.
At this point I know I have fuel pressure and I have spark, but the engine hasn't even coughed yet. I suspect that the FI system isn't powered. I won't be able to work on it until Monday because I have to go to Phoenix this weekend. At least I'll get to sit down with my son and look over the wiring diagrams to get a sense of how to tell if I'm right about the FI. The only other clue is that I have no oil indicator light when I turn on the key. I think maybe I'll start another topic to ask for technical input. (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) It will be worth a couple more days after all this time to make sure I get it right and don't just stumble around. |
jet1 |
May 26 2005, 11:13 PM
Member Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States |
I like the yellow tin. It really makes the engine compartment look nice and clean. Good luck with the start up.
ThinAir |
May 26 2005, 11:19 PM
Gint |
May 27 2005, 05:41 AM
Mike Ginter Group: Admin Posts: 16,070 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
You'll get 'er done Ernie!
JmuRiz |
May 27 2005, 11:31 AM
914 Guru Group: Members Posts: 5,425 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
Where'd you get that motorcycle jack from? I hear some of them have interference from the jackbar point hitting the tranny etc. Car looks awesome!!! |
ThinAir |
May 27 2005, 01:08 PM
I got it from Pep Boys - $45 after a rebate. It does have some interference from the rear section of the jack. The hydraulic part is fixed and does not swivel so when you lower the jack that section does not go down even though the front part lowers. This means that I ended up with the engine down and the tranny up when I slid it under the car. That was OK because I just used my regular floor jack to lift the car a little and just slid it under - didn't even have to remove the rear valance! |
JmuRiz |
May 27 2005, 01:11 PM
Cool, I was wondering if it was that Pepboys one in the ad a couple weeks ago. Sounds good. The tranny needs to be dropped less than the engine anyway so no big deal. I might look around for one of those jacks...too bad there are no pep-boys in my area.
Lo-Fi Version | Time is now: 8th May 2024 - 02:00 PM |
