914-6 Alternator replacement |
Cazz |
Jul 14 2019, 01:40 PM
Newbie Group: Members Posts: 13 Joined: 22-December 16 From: NC Member No.: 20,688 Region Association: None |
I just bought a 914 that has been converted to a 914-6 with a 2.7 engine
Can the alternator be replaced with the engine in the car or do I need to drop it down/take the engine out |
Jul 14 2019, 01:50 PM
914-6 GT in waiting Group: Members Posts: 19,279 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
In the car is possible. There’s a thread or two. I think Clay wrote one.
Retroracer |
Jul 14 2019, 02:16 PM
Senior Member Group: Members Posts: 612 Joined: 7-July 13 From: Bend OR Member No.: 16,100 Region Association: Pacific Northwest |
(IMG:style_emoticons/default/agree.gif) yes, should not need to drop the engine.
SOme dependency on what intake you are running - carbs are a little easier to get unbolted, injection systems can be more involved. Good luck! - Tony |
Cairo94507 |
Jul 14 2019, 02:31 PM
Michael Group: Members Posts: 9,776 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California |
It is do-able. It is a tight fit and a pain in the rear but you can do it. I did it on my last 6 about 30 years ago when I was young, flexible and willing. Today, I would have someone else do it for me. I just can't bend like that anymore. Now I sweat tying my shoes..... (IMG:style_emoticons/default/beerchug.gif)
IronHillRestorations |
Jul 14 2019, 02:40 PM
If you also need to do a valve adjustment, I'd probably drop the engine. To leave the engine in the car you have to take off the induction and fan shroud, which can be as much of a hassle as just dropping the engine.
Luke M |
Jul 14 2019, 05:18 PM
Senior Member Group: Members Posts: 1,373 Joined: 8-February 05 From: WNY Member No.: 3,574 Region Association: North East States |
Like Perry just said... It's easier to drop the engine and do it. While there do the valve adjustment. It's way easier then in the car. I can drop my 6 engine by myself in 45 minutes to an hour. Once on the ground the fan housing/alt can be removed in 15 mins. I bet in that 1.5 hour time frame you will still be working away and swearing up a storm.
Here's a few link to view : http://www.914world.com/bbs2/index.php?showtopic=10187 http://www.914world.com/bbs2/index.php?showtopic=8098 |
porschetub |
Jul 15 2019, 05:37 PM
Advanced Member Group: Members Posts: 4,701 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Yep,will drive you nuts but it can be done,make sure you re-torque the fan strap to factory specs as it easy to overtighten it and your fan will touch the housing ...ask me how I know,also make sure you have a good ground strap altenator to crankcase as this is important,good luck.
cdn914 |
Jul 15 2019, 06:33 PM
cdn914 Group: Members Posts: 193 Joined: 15-March 04 From: Winnipeg, Canada Member No.: 1,801 Region Association: Canada |
Easier to do a thorough job by dropping the engine. You likely will regret trying it with the engine in the car.
PanelBilly |
Jul 15 2019, 08:18 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
Done it several times. Wouldn’t try unless you have a hole in the firewall to access the front.
Lo-Fi Version | Time is now: 21st May 2024 - 06:18 PM |
