GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
Mikey914 |
Oct 15 2019, 11:43 PM
The rubber man Group: Members Posts: 12,670 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the outer scraper on the late cars were superseded with the 911 profile.
Yes it's a more robust profile, but it also grips the glass more. This is even more true when it's new. So some have lubricated them, others have baked them both with some success, but the real problem is it was never really designed for the application. So you all know me I can't just leave something alone. we made a significant improvement to the product. See the seal that is like OEM below. Attached thumbnail(s) |
drem914 |
Oct 16 2019, 10:43 AM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Mark, I am in for a set, but is the bulb that slides into the aluminum track larger than the last ones you did? My issue with the scrappers was the bulb portion kept popping out of the track. I went and installed earlier model scrappers and it went into the track with the right tension and does not pop out every time I roll up the windows. is there a difference in the aluminum door track between early model and late model?
Lo-Fi Version | Time is now: 21st May 2024 - 12:29 AM |
