GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
Mikey914 |
Oct 15 2019, 11:43 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the outer scraper on the late cars were superseded with the 911 profile.
Yes it's a more robust profile, but it also grips the glass more. This is even more true when it's new. So some have lubricated them, others have baked them both with some success, but the real problem is it was never really designed for the application. So you all know me I can't just leave something alone. we made a significant improvement to the product. See the seal that is like OEM below. Attached thumbnail(s) |
Mikey914 |
Oct 16 2019, 01:40 PM
Our rubber for these is the same durometer used on 90% of the other seals. The thinner seals seem more soft but are not. They do harden over time, so one of the fixes was to bake them. Any harder they become more difficult to install. A catch 22, unless you change another variable, which we just did.
drem914 |
Oct 16 2019, 08:13 PM
Senior Member Group: Members Posts: 1,030 Joined: 16-May 08 From: Trabuco Canyon, CA Member No.: 9,062 Region Association: Southern California |
Our rubber for these is the same durometer used on 90% of the other seals. The thinner seals seem more soft but are not. They do harden over time, so one of the fixes was to bake them. Any harder they become more difficult to install. A catch 22, unless you change another variable, which we just did. Any chance you can shed some light on the bulb size between early and late models? BTW thanks for sending the door card nut arm rest nut plates. |
Lo-Fi Version | Time is now: 17th May 2024 - 09:46 AM |
