GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
Mikey914 |
Oct 15 2019, 11:43 PM
The rubber man Group: Members Posts: 12,668 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the outer scraper on the late cars were superseded with the 911 profile.
Yes it's a more robust profile, but it also grips the glass more. This is even more true when it's new. So some have lubricated them, others have baked them both with some success, but the real problem is it was never really designed for the application. So you all know me I can't just leave something alone. we made a significant improvement to the product. See the seal that is like OEM below. Attached thumbnail(s) |
Chris914n6 |
Oct 22 2019, 10:41 PM
Jackstands are my life. Group: Members Posts: 3,320 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
So which scrapers are actually the better ones? Early, late or fuzzy late?
OT: Have you gotten all the other fuzzies in stock? *Doing it right... doing it all at once (IMG:style_emoticons/default/laugh.gif) |
Mikey914 |
Oct 22 2019, 11:29 PM
So which scrapers are actually the better ones? Early, late or fuzzy late? OT: Have you gotten all the other fuzzies in stock? *Doing it right... doing it all at once (IMG:style_emoticons/default/laugh.gif) All other fuzzes and goodies in stock, check the PM special links I sent you will see it's a perfect time to replace as much as you want as they are all discounted through the GB also. As far as which is the better seal. The un fuzzey late ones do SUCK. With the fuzzey added they are a more substantial seal, so I'm leaning toward these being the best. The early once are a very fine wiper, so they do keep water out, but I do slightly favor the new seals we are offering up here. PMs sent to all so far We are planning to run this to the end of the month then close it it really is a screaming deal ! |
Lo-Fi Version | Time is now: 17th May 2024 - 06:54 AM |
