GB CLOSES in a few hours 31st for late window scrapers with new fuzzey (non-sucking), Basically buy the aluminum strips at a discount seals are FREE or just buy the seals on GB |
Mikey914 |
Oct 15 2019, 11:43 PM
The rubber man Group: Members Posts: 12,667 Joined: 27-December 04 From: Hillsboro, OR Member No.: 3,348 Region Association: None |
Yes the outer scraper on the late cars were superseded with the 911 profile.
Yes it's a more robust profile, but it also grips the glass more. This is even more true when it's new. So some have lubricated them, others have baked them both with some success, but the real problem is it was never really designed for the application. So you all know me I can't just leave something alone. we made a significant improvement to the product. See the seal that is like OEM below. Attached thumbnail(s) |
Mikey914 |
Oct 16 2019, 12:05 AM
Here's the solution.
We've added a strip of fuzzey to the scraper edge. Allowing the window to slide easily on the new "buffer" These will be $7 each side retail in the future, but we are starting a GB for $9.99 a set. SO who can use a set? Attached thumbnail(s) |
frostyf |
Oct 26 2019, 12:20 PM
Member Group: Members Posts: 153 Joined: 27-March 14 From: VA 23455 Member No.: 17,168 Region Association: MidAtlantic Region |
Here's the solution. We've added a strip of fuzzey to the scraper edge. Allowing the window to slide easily on the new "buffer" These will be $7 each side retail in the future, but we are starting a GB for $9.99 a set. SO who can use a set? Mike, yes please van I buy a set before the group buy ends? I'm also after one of your trunk cable and plastic guides as well. Can I pay you in a "one'er" and merge postage? Thanks Nick |
Lo-Fi Version | Time is now: 16th May 2024 - 06:33 PM |
