914-6 stock engine mount prices |
Jett |
Feb 1 2021, 10:42 PM
Senior Member Group: Members Posts: 1,638 Joined: 27-July 14 From: Seattle Member No.: 17,686 Region Association: Pacific Northwest |
Our next project is a 914-6 conversion and was wondering what the cost of a stock engine mount is? In addition, we are looking for a stock air box but know very little about the different types. The core motor is a 69 911s 2.0 with Weber’s.
Any education and or pointers would be appreciated. Darren |
Superhawk996 |
Feb 2 2021, 06:54 AM
914 Guru Group: Members Posts: 5,829 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch |
Not sure what you mean by stock mount. True 914/6 OEM mounts are super pricey and hard to find.
I went with a MadDog OEM style mount cost is about $350 but I paid a bit less on a Black Friday discount. The only downside I see to it is that the isolation isn't the OEM mount but one of the rather small Wevo spool mounts. I intend to modify the body side of the mount to use the OEM rubber isolation for better NVH. My engine side of the mount if out for powder coat along with your tin! Which reminds me I need to follow up on those parts (IMG:style_emoticons/default/huh.gif) |
mb911 |
Feb 2 2021, 07:00 AM
914 Guru Group: Members Posts: 6,854 Joined: 2-January 09 From: Burlington wi Member No.: 9,892 Region Association: Upper MidWest |
Not sure what you mean by stock mount. True 914/6 OEM mounts are super pricey and hard to find. I went with a MadDog OEM style mount cost is about $350 but I paid a bit less on a Black Friday discount. The only downside I see to it is that the isolation isn't the OEM mount but one of the rather small Wevo spool mounts. I intend to modify the body side of the mount to use the OEM rubber isolation for better NVH. My engine side of the mount if out for powder coat along with your tin! Which reminds me I need to follow up on those parts (IMG:style_emoticons/default/huh.gif) That mount shouldnt need any modification to use the stock isolator. It is also what I recommend to all of my customers. It has the most clearance and keeps things simple. |
mb911 |
Feb 2 2021, 07:02 AM
Our next project is a 914-6 conversion and was wondering what the cost of a stock engine mount is? In addition, we are looking for a stock air box but know very little about the different types. The core motor is a 69 911s 2.0 with Weber’s. Any education and or pointers would be appreciated. Darren Darren, The stock air filter assembly wouldn't fit properly in my car. I had a steel air box and restored it then it didn't fit. |
Superhawk996 |
Feb 2 2021, 07:08 AM
Not sure what you mean by stock mount. True 914/6 OEM mounts are super pricey and hard to find. I went with a MadDog OEM style mount cost is about $350 but I paid a bit less on a Black Friday discount. The only downside I see to it is that the isolation isn't the OEM mount but one of the rather small Wevo spool mounts. I intend to modify the body side of the mount to use the OEM rubber isolation for better NVH. My engine side of the mount if out for powder coat along with your tin! Which reminds me I need to follow up on those parts (IMG:style_emoticons/default/huh.gif) That mount shouldnt need any modification to use the stock isolator. It is also what I recommend to all of my customers. It has the most clearance and keeps things simple. Interesting. The Wevo spool is held by an adapter plate. I had assumed that I'd have to do something to make an OEM 914/6 rubber mount work and just looked into a used part on the F/S forum to use as the template for mod's. I guess I should just go ahead and order the new 914/6 isolator and see how it fits up. |
mb911 |
Feb 2 2021, 07:34 AM
Not sure what you mean by stock mount. True 914/6 OEM mounts are super pricey and hard to find. I went with a MadDog OEM style mount cost is about $350 but I paid a bit less on a Black Friday discount. The only downside I see to it is that the isolation isn't the OEM mount but one of the rather small Wevo spool mounts. I intend to modify the body side of the mount to use the OEM rubber isolation for better NVH. My engine side of the mount if out for powder coat along with your tin! Which reminds me I need to follow up on those parts (IMG:style_emoticons/default/huh.gif) That mount shouldnt need any modification to use the stock isolator. It is also what I recommend to all of my customers. It has the most clearance and keeps things simple. Interesting. The Wevo spool is held by an adapter plate. I had assumed that I'd have to do something to make an OEM 914/6 rubber mount work and just looked into a used part on the F/S forum to use as the template for mod's. I guess I should just go ahead and order the new 914/6 isolator and see how it fits up. Yes just remove the adapter and your all good |
Jett |
Feb 2 2021, 11:11 AM
Thanks for all the information. eBay has an OEM mount for $700, but that sure seems expensive, but maybe aftermarket is best from a cost perspective.
Does anyone have a picture of the correct air box? |
mb911 |
Feb 2 2021, 11:16 AM
Thanks for all the information. eBay has an OEM mount for $700, but that sure seems expensive, but maybe aftermarket is best from a cost perspective. Does anyone have a picture of the correct air box? It would be plastic.. Re the mount see maddog motorsports and buy the oem style setup for $350 ish and never look back. |
Jett |
Not sure what you mean by stock mount. True 914/6 OEM mounts are super pricey and hard to find. I went with a MadDog OEM style mount cost is about $350 but I paid a bit less on a Black Friday discount. The only downside I see to it is that the isolation isn't the OEM mount but one of the rather small Wevo spool mounts. I intend to modify the body side of the mount to use the OEM rubber isolation for better NVH. My engine side of the mount if out for powder coat along with your tin! Which reminds me I need to follow up on those parts (IMG:style_emoticons/default/huh.gif) Lol no worries and no rush (IMG:style_emoticons/default/smile.gif) |
dr914@autoatlanta.com |
Feb 2 2021, 11:18 AM
914 Guru Group: Members Posts: 7,866 Joined: 3-January 07 From: atlanta georgia Member No.: 7,418 Region Association: None |
Mad Dog has a very reasonable one. We have his and the German much more expensive one and the quality compares
Our next project is a 914-6 conversion and was wondering what the cost of a stock engine mount is? In addition, we are looking for a stock air box but know very little about the different types. The core motor is a 69 911s 2.0 with Weber’s. Any education and or pointers would be appreciated. Darren |
Jett |
Feb 2 2021, 11:39 AM
Mad Dog has a very reasonable one. We have his and the German much more expensive one and the quality compares Our next project is a 914-6 conversion and was wondering what the cost of a stock engine mount is? In addition, we are looking for a stock air box but know very little about the different types. The core motor is a 69 911s 2.0 with Weber’s. Any education and or pointers would be appreciated. Darren Thanks George |
rgalla9146 |
Feb 2 2021, 04:55 PM
Advanced Member Group: Members Posts: 4,555 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
OR
Fabricate your own version of the original bulkhead mount. Buy the new copy of the OEM rubber mount Create a 914 6 'on engine' mount by modifing a 911 part. Attached thumbnail(s) Attached image(s) |
horizontally-opposed |
Feb 2 2021, 05:06 PM
Advanced Member Group: Members Posts: 3,432 Joined: 12-May 04 From: San Francisco Member No.: 2,058 Region Association: None |
I used the Rich Johnson mount. It's like the factory 914-6 mount, but uses two rubber-isolated mounts instead of one. Seems steadier to me, came finished in black with all hardware and the mounts IIRC, and went in without a hitch. It's been in use with zero issues for about a decade.
Great info on the various bulkhead mounts here: http://www.914world.com/bbs2/index.php?showtopic=110919 Factory 914-6 airboxes seem to list for $350-850 depending on condition (and optimism…). Suspect your metal 911S airbox might well offset that cost, as it too is a desirable piece. This board, Pelican Parts, and Early 911S Registry are all good places to check. For some pics of a plastic 914-6 airbox, see below. http://www.914world.com/bbs2/index.php?showtopic=335848 Key differentiator is the snorkel points to the passenger side on a 914-6 airbox, where a 911 snorkel goes the other way. A cut-down snorkel won't matter much, or you can go with the "GT3 Cup" filter holder—which is what I am running—instead. I prefer the acoustics of the factory airbox to rain hats, but YMMV! (IMG:style_emoticons/default/smile.gif) |
930cabman |
Feb 2 2021, 05:19 PM
Advanced Member Group: Members Posts: 3,065 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States |
We are gathering parts and pieces for a /6 conversion, looking at this one:
https://naroescapemotorsports.com/product/9...n-engine-mount/ looks simple, price decent |
mb911 |
Feb 2 2021, 05:21 PM
We are gathering parts and pieces for a /6 conversion, looking at this one: https://naroescapemotorsports.com/product/9...n-engine-mount/ looks simple, price decent Do know that if you use that mount it causes the engine to sit lower i. The chassis by 3/4" and the engine tin does not seal and you will have to do custom shift linkage.. it also pulls the engine forward in the chassis which strains on the trans ears and mounts. |
Feb 2 2021, 05:26 PM
914-6 GT in waiting Group: Members Posts: 19,275 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Porsche also sells a stock 914-6 rubber mount. Porsche (914-375-049-01)
Sunset lists it for $200, pelican charges $250 |
Superhawk996 |
Feb 2 2021, 05:34 PM
We are gathering parts and pieces for a /6 conversion, looking at this one: https://naroescapemotorsports.com/product/9...n-engine-mount/ looks simple, price decent Without completely revisiting the topic that has been covered elsewhere. You need to know what you want out of the mount. Mounts that may work well for racing aren't what you want for street use where minimal NVH is presumably what you want. Minimal NVH comes from mounts with high stiffness and lots of rubber to isolate. |
930cabman |
Feb 2 2021, 06:03 PM
We are gathering parts and pieces for a /6 conversion, looking at this one: https://naroescapemotorsports.com/product/9...n-engine-mount/ looks simple, price decent Do know that if you use that mount it causes the engine to sit lower i. The chassis by 3/4" and the engine tin does not seal and you will have to do custom shift linkage.. it also pulls the engine forward in the chassis which strains on the trans ears and mounts. Thank you for the heads up Ben. For sure I want the engine tin to seal. Is the Mad Dog a good option? I have tried the search and have not been very successful. Our 914/6 conversion will be a street cruiser only, will never see a track |
mb911 |
Feb 2 2021, 06:09 PM
We are gathering parts and pieces for a /6 conversion, looking at this one: https://naroescapemotorsports.com/product/9...n-engine-mount/ looks simple, price decent Do know that if you use that mount it causes the engine to sit lower i. The chassis by 3/4" and the engine tin does not seal and you will have to do custom shift linkage.. it also pulls the engine forward in the chassis which strains on the trans ears and mounts. Thank you for the heads up Ben. For sure I want the engine tin to seal. Is the Mad Dog a good option? I have tried the search and have not been very successful. Yes @mcmark designed it and its the best mount out there The rich johnson mount and the maddog copy of the Rich Johnson mount are fine but the oem style doesn't block or get in the way of anything. Really the way to go.. I built 4 oem mounts then gave up because there are so many options. I even have a retrofit with corrections done to a Naro mount but I am thinking I may just buy a bunch of mad dogs oem mounts and I will resell to folks looking. Ps I get no kick backs for being a fan. I have used all the options out there and the oem style is the best. |
We are gathering parts and pieces for a /6 conversion, looking at this one: https://naroescapemotorsports.com/product/9...n-engine-mount/ looks simple, price decent Do know that if you use that mount it causes the engine to sit lower i. The chassis by 3/4" and the engine tin does not seal and you will have to do custom shift linkage.. it also pulls the engine forward in the chassis which strains on the trans ears and mounts. Thank you for the heads up Ben. For sure I want the engine tin to seal. Is the Mad Dog a good option? I have tried the search and have not been very successful. Our 914/6 conversion will be a street cruiser only, will never see a track https://maddogsmotorsports.com/shop/ols/pro...ica-motor-mount |
Lo-Fi Version | Time is now: 19th May 2024 - 09:42 AM |
