Tech articles under development., List of who is doing what. |
Air_Cooled_Nut |
May 1 2007, 12:11 PM
914 Ronin - 914 owner who lost his 914club.com Group: Members Posts: 1,748 Joined: 19-April 03 From: Beaverton, Oregon Member No.: 584 Region Association: None |
Please make a single post as to which technical article you are working on. When you are done with it and have submitted it to whomever, please EDIT your original post to indicate that you have finished it.
Please, let's just try to keep this as a thread of who is working on what. No real need for hijacks and extraneous comments. The Tech Articles are located: http://www.914world.com/specs/tech_art.php You can navigate to this page via the 914 Info link at the upper right corner of the Forums pages and then to the Technical Articles link in the Technical Information table. Added by Gint QUOTE(Gint) Submit the finished articles to link to PM Gint using the format outlined below in McMark's quote. If you can't do HTML, then simple text in the format outlined below will be fine. Just list the file names of the pictures in the text and email (not PM) the text and pics to gint@914world.com. Pics need to be no larger than 800x600 please. If you don't resize them, I'll have to do it. I can do it for those that don't have the capability, but for those that can, please resize them yourself. Thanks! There are a lot of good articles in the classics forum that need to be copied and formatted for the Technical Articles section. We need people to do that, as well as create new articles. Here's a quick template for formatting the pages: CODE <h2>This is the title of the article</h2> <br> This is the introduction to the article describing what we will cover here, how long it should take, how hard it is, etc.<br> <br> <b>Tools and Supplies:<br></b> <br> This is the list f tools and supplies required to perform the task. <br> <b>Step 1: name of step</b><br> <br> This is the first step/section.<br> <img src="THIS IS THE URL FOR AN IMAGE"><br> <br> <b>Step 2: name of step</b><br> <br> This is the second step/section. Copy and paste for each step. Feel free to delete the <IMG> line if there is no image, or to add multiple <IMG> lines if you want.<br> <img src="THIS IS THE URL FOR AN IMAGE"><br> <img src="THIS IS THE URL FOR AN IMAGE"><br> <img src="THIS IS THE URL FOR AN IMAGE"><br> <br> <COMPILED>Info compiled by WHOEVER POSTED THE INFO.</COMPILED> This post has been edited by Gint: Aug 12 2014, 03:32 AM |
McMark |
May 1 2007, 12:13 PM
Tail light refurbishment - Cleaning, checking, correct bulb replacement.
Air_Cooled_Nut |
May 1 2007, 12:24 PM
Headlight adjustment.
Published. BTW, photos are by me using my beater, er, 914 (IMG:style_emoticons/default/biggrin.gif) |
rhodyguy |
May 1 2007, 12:55 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,072 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
Mallory dist optical pickup module distruction for those with fat wallets.
k |
914forme |
May 1 2007, 01:08 PM
Times a wastin', get wrenchin'! Group: Members Posts: 3,896 Joined: 24-July 04 From: Dayton, Ohio Member No.: 2,388 Region Association: None |
I just did a 914 Limited log repair install, but mine is a little different from most. I gues I could write it up, I took a few pictures. I left the jack posts off my install. So somebody woould have to fill that in.
Gint |
May 3 2007, 08:19 PM
Mike Ginter Group: Admin Posts: 16,066 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
Toby! Your published. Very nice job by the way. I added a few line breaks and that was about all. Very easy edit on my part.
http://www.914world.com/specs/headlight_adjustment.php |
markb |
Jul 9 2007, 09:24 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
914 Lock Re-keying DONE & sent to Gint
ThinAir |
Oct 6 2007, 11:21 PM
Best friends Group: Members Posts: 2,541 Joined: 4-February 03 From: Flagstaff, AZ Member No.: 231 Region Association: Southwest Region |
4-cylinder Alternator Replacement. I just did this today and made it a point to take pictures. It's not a hard job, but a real pain in the neck. I'm hoping my step-by-step can make it easier, especially for folks who have not done the job before.
rhodyguy |
Oct 9 2007, 09:51 PM
new muffler and some piping for a bursch style exhaust. early 2.0 all stainless he's. edelbrock muffler . 2" steel mandrel bent steel piping
k |
thesey914 |
Nov 7 2007, 12:18 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
Can I add my tensioner rebuild article for those with sixes?
link in my sig |
jk76.914 |
Nov 7 2007, 03:13 PM
Senior Member Group: Members Posts: 809 Joined: 12-April 05 From: Massachusetts Member No.: 3,925 Region Association: North East States |
How about door assembly? From empty to factory- assembly sequence, adjustments, rust prevention, sound mat....
I just finished the driver's door, and it took about 4 Saturdays. Mainly because I kept taking 2 steps forward and then 1 step back. Apparently, assembly has to be done in the right order! When I do the passenger door, I'm taking the pictures and throught I'd write it up. Jim |
orange914 |
Nov 7 2007, 11:10 PM
http://5starmediaworks.com/index.html Group: Members Posts: 3,371 Joined: 26-March 05 From: Ceres, California Member No.: 3,818 Region Association: Northern California |
i'll get our pictures together for front sway bar conversion/install (IMG:style_emoticons/default/beerchug.gif)
where will these articals be located? mike |
Challe |
Dec 5 2007, 02:27 AM
Member Group: Members Posts: 60 Joined: 25-September 07 From: Sweden, Europe Member No.: 8,149 |
AAR repair, with language edit from member vsg914, lots of pictures ready, has only the reassambly left.
orange914 |
Dec 5 2007, 05:17 PM
How about door assembly? When I do the passenger door, I'm taking the pictures Jim jim could you take a picture of the inside aarea of the pass. door skin where the mirror mounts? i've personally witnessed and have been told all years have a nut plate put in so the dealer could add a mirror option. (IMG:style_emoticons/default/thumb3d.gif) heres a link that we were just talking about that on the "other" site http://www.914club.com/bbs2/index.php? mike |
McMark |
Dec 5 2007, 07:05 PM
Tech articles end up in the 914Info section at the top of the page.
Gint |
Dec 16 2007, 12:26 PM
McMark's alternator replacement article and Orange914's sway bar installation article have been posted.
Gint |
Jan 1 2008, 10:00 PM
MarkB's 914 lock re-keying article is Complete! Lot's of pics in that one.
race914 |
Jan 9 2008, 05:37 PM
73 914-4 Group: Members Posts: 1,006 Joined: 31-October 05 From: Nipomo, California (Central Coast) Member No.: 5,027 Region Association: Central California |
I've been revising my gear ratio model and have also come up with a companion tech article on why you would consider re-gearing, how to use the speadsheet, etc.
Tech Article, Spreadsheet and member gearset library all updated! This post has been edited by race914: Jan 5 2009, 01:56 PM |
Gint |
Feb 4 2008, 10:50 PM
We've added two new articles.
Slits wrote the Late 75-76 914 Ignition Switch Replacement Re-gear Your 914 by Race914 |
watsonrx13 |
Mar 18 2008, 11:38 AM
Advanced Member Group: Members Posts: 2,734 Joined: 18-February 03 From: Plant City, FL Member No.: 312 Region Association: South East States |
Replace firewall shifter bushing....
Now, if Gint will reply to my e-mail with an address I can send the document to.... (IMG:style_emoticons/default/bye1.gif) -- Rob |
Lo-Fi Version | Time is now: 6th May 2024 - 02:10 AM |
