The official chappy 914-6-gt-turbo carrera thread, The car is real scary to drive, clutch is broke in, im not! |
iamchappy |
Aug 22 2007, 10:31 PM
It all happens so fast! Group: Members Posts: 4,893 Joined: 5-November 03 From: minnetonka, mn Member No.: 1,315 Region Association: Upper MidWest |
Ok, it's starting, almost all the pieces are in place.
I worked Spring and Summer getting the car all in primer and finishing up the custom valances. I actually thought this time last year I was suppose to be done. Here are some photos of the car last week getting towed to the bodyshop, and pictures of how it looked this morning. Next week I will start to assemble my two and a half years of acumulated stuff back onto the car and fit the engine. I will document it with pictures as I go along. The Completed Car Photos for those who want to skip all 25 pages: http://homepage.mac.com/davidchapman1/PhotoAlbum26.html The car is going to be a beauty and a very special 3.1 twin plug turbo powered one at that. Here are the past links showing the progression and R&D it's taken over the years to get the car to this point. http://www.914world.com/bbs2/index.php?sho...c=16348&hl= http://www.914world.com/bbs2/index.php?act...rrera&st=60 http://www.914world.com/bbs2/index.php?act...l=turbo+carrera http://www.914world.com/bbs2/index.php?act...l=turbo+carrera http://www.914world.com/bbs2/index.php?sho...c=8438&st=0 (IMG:style_emoticons/default/beer.gif) (IMG:style_emoticons/default/beer.gif) Attached image(s) |
LarryR |
Aug 22 2007, 10:35 PM
Senior Member Group: Members Posts: 929 Joined: 15-March 07 From: E. Bay Area, N. California Member No.: 7,604 |
Wow that looks great! Having a car that looks that nice will help when sifting through the parts.
scotty |
Aug 22 2007, 10:40 PM
The Fun Never Stops Group: Members Posts: 773 Joined: 20-May 03 From: Portland. Oregon (SW) Member No.: 718 Region Association: None |
Nice color!
Mugs914 |
Aug 22 2007, 10:57 PM
"Hey, yellow IS faster!" Group: Members Posts: 618 Joined: 22-July 05 From: Temple TEXAS Member No.: 4,452 Region Association: Southwest Region |
rick 918-S |
Aug 22 2007, 11:03 PM
Hey nice rack! -Celette Group: Members Posts: 20,426 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
Can I stop over next week and see it? (IMG:style_emoticons/default/aktion035.gif) (IMG:style_emoticons/default/drooley.gif)
iamchappy |
I will be impossible for me at this point to put a dirty or old used part that hasn't been reconditioned back on it.
Here is what is getting put back in. IAMCHAPPYS PORSCHE 914 6 GT TURBO CARERRA BUILD SHEET 3.12 CIS Turbo Twin-plug engine Using 1979 SC 3.0 block, crank. rods and heads and cams 91 3.3 turbo pistons and cylinders Rod pin modification for stroke ARP rod bolts with 928 nuts Supertec Head studs Elgin racing valve springs and retainers 930 turbo oil pump K27 7200 Spearco 1080 cfm intercooler Electric automatic temp fan relay switch Two 7" electric pull fans for intercooler Transmission cooler Tilton electric transmission cooler pump Mark Donahue special edition steering wheel(very rare). Tekniq quick release steering wheel hub Terry cables Custom aluminum intake and pressure side turbo piping Silicone elbows, hump hoses and reducers 86 930 turbo intake manifold Euro fuel distributor Bosch 400 lph racing fuel pump Tial 46mm wastgate Tial 50mm BOV Turbo x boost controller Adjustable micro pressure switch for 7th injector 7th fuel injector micro fueler (911sc CSV) Supertech generation 2 - 12 plug conversion distributor MSD boost retard ignition with rev control MSD shift light 2 MSD Blaster 2 coils Magnacore twin plug 12 wires RSR plug holders Maganaflow 2.5"in 2.5"out muffler Custom stainless crossover pipe Hooker resonator exhaust tip 930 cam driven oil pump Aeropquip stainless and blue line socketless fuel and oil lines Fire sleeve Front mounted oilcooler Factory 914-6 oil tank Factory 914-6 engine mount Factory 914-6 rear stub axles Front mounted oil cooler with thermostat Smart Racing oil cooler block off remote oil filter stand Smart racing on engine Thermostat no bypass Canton remote oil filter Canton inline transmission filter 911 front end with aluminum crossmember 951 Turbo brakes calipers front and rear 911 Ebrake modification New Ebrake cables Brake bias valve Carrera solid rotors Speed bleeders Porterfield RS-4 brake Pads 23MM master cylinder Adjustable front swaybar Rear sway bar (unmounted) for street 2 Set's of 7, 23mm offset 8X16 phone dial wheels Set of 7, 9 x16 Fuchs Yokohama es100 225/50/16 , 245/45/16 Contiextremecontacts 225/50/16, 245/50/16 Toyo RA1 225/50/16 , 245/45/16 Adjustable Koni shocks in front 911 gauges 901 side shift trans with Quaife and short gears (M,S,Z) 901 side shift trans stock gearing 914 6 Cv and axles with Dr. Evil safety wired CV bolts Kennedy stage 2 clutch and pressure plate with starter ring Shorten shifter 914-6 aluminum plated headers 914-6 factory heat exchangers and heat ducts and diverters Rear end has been reinforced Suspension ears reinforced Engman Interior long reinforcement Brad Mayeur outer long reinforcement kit Bilstien shocks adjustable perches in rear 200lbs springs Turbo tie rods Steering rack has been lowered for bump steer camber truss front and rear Wevo transmission mounts Autopower Full roll cage( unmounted for street ) 2005 Alpine cd mp3 player with 8" Quart subs driven by Alpine T220, Alpine type R 5 1/4 door and 6.5 kick panel speakers driven by Alpine T240 amp. LED blue gauge bulbs Gauge trim rings Halogen headlights. Euro side maker lamps Gtech computer a/r before turbo analog gauge Westberg vdo boost vacuum gauge Autometer sport comp boost gauge Autometer Pro Comp fuel pressure gauge with isolator Autormeter Pro Comp transmission temp gauge Autometer Pro Comp volt meter LM1 analog wide band A/R gauge gauge pods Optima yellow deep cell battery Billet battery holder Oil breather catch can 993 spare tire cover and tool kit GT fiberglass flares, rockers, MSDS rear GT valance, and rear spoiler with intercooler duct. Black Leather upholstered interior Harness bar Morsphectra carpet set custom for use with aluminum floor boards Aluminum floor board driver and passenger Aluminum pedals All new chrome trim items New OEM exterior door handles New OEM mirrors driver and passenger New engine lid letters New ghost reflector rear lens New windshield Tow hooks Modified Gt valance with brake ducts 914 Club badge Shine racing needle bearings Chrome fuel door in hood Lightweight doors with late window regulators and glass Roll bar vinyl and sail panels Original car color - Signal Orange Dupont chroma Premier 2 Stage paint SPA onboard 4L Fire suppression system Amerex 2.5 Halon fire extinquisher - on custom seat mount Special thanks to all 914 club members who have contributed and helped me source all of the parts. Rick 918 s Camp 914 Engman Dr. Evil Qarl Morphenspectra John Neo 914 6 lotus 65 GWN7 spunone dlee1967 Garold Shaffer Brad Mayeur NYchef MSDS RacerJerry Henry Schmidt - Supertec Minnetonka autobody Johnson Autosports and a special thanks to Joe Sharp for sending Ollie Narp tees... |
wbergtho |
Aug 23 2007, 12:44 AM
Senior Member Group: Members Posts: 1,314 Joined: 28-April 03 From: Roberts, WI Member No.: 623 |
Wow Dave! That things looks great in Sig Orange! Can't wait to see it with my own eyes!!! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/thumb3d.gif)
neo914-6 |
Aug 23 2007, 01:57 AM
neo life Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
Looking sweet!
glad to have helped a little... |
Phoenix-MN |
Aug 23 2007, 07:27 AM
Senior Member Group: Members Posts: 927 Joined: 23-January 04 From: ST. Bonifacius,MN Member No.: 1,590 |
You are officially "Hooked" and off the deep end now. Glad to see it (IMG:style_emoticons/default/thumb3d.gif)
scotty |
Aug 23 2007, 09:42 AM
3.12 CIS Turbo Twin-plug engine (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/ohmy.gif) Be sure to use a sturdy air filter as the intake is likely to suck in small children and pets! |
JmuRiz |
Aug 23 2007, 10:18 AM
914 Guru Group: Members Posts: 5,424 Joined: 30-December 02 From: NoVA Member No.: 50 Region Association: MidAtlantic Region |
I really dig the rear spoiler, looks like LOTS of work went into smoothing it and the flairs, this is going to be one outrageous car. You and 'falcon need to get together and have a 6-cly turbo off (IMG:style_emoticons/default/biggrin.gif)
Doug Leggins |
Aug 23 2007, 11:03 AM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
That car is looking fantastic! (IMG:style_emoticons/default/thumb3d.gif)
Your color choice is perfect!!! (IMG:style_emoticons/default/biggrin.gif) |
Ferg |
Aug 23 2007, 11:34 AM
914 Guru Group: Members Posts: 5,948 Joined: 8-January 03 From: Boulder CO Member No.: 116 Region Association: None |
That car is looking fantastic! (IMG:style_emoticons/default/thumb3d.gif) Your color choice is perfect!!! (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/agree.gif) Also, just noticed your front valance (IMG:style_emoticons/default/happy11.gif) COOL |
pete-stevers |
Aug 23 2007, 12:08 PM
saved from fire! Group: Members Posts: 2,641 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest |
lookin Great so far......can't wait to see further assembly!! (IMG:style_emoticons/default/piratenanner.gif)
MoveQik |
Aug 23 2007, 12:14 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
There is something special about a freshly painted 914 shell (IMG:style_emoticons/default/pray.gif)
TJB/914 |
Aug 23 2007, 12:29 PM
Mid-Engn. Group: Members Posts: 4,326 Joined: 24-February 03 From: Plymouth & Petoskey, MI Member No.: 346 Region Association: Upper MidWest |
That car is looking fantastic! (IMG:style_emoticons/default/thumb3d.gif) Your color choice is perfect!!! (IMG:style_emoticons/default/biggrin.gif) Chappy (IMG:style_emoticons/default/agree.gif) Beautiful paint. (IMG:style_emoticons/default/thumb3d.gif) When I opened up the post I was expecting to see a black car?? I didn't know you changed your mind. All bright colors are great on 914's. Keep those pictures coming. Tom |
iamchappy |
Aug 23 2007, 01:11 PM
I have to catch up on some work today, I re-fabricated my muffler hanger to accommodate a larger wastegate, I now need to do a little welding on it to re-strengthen it.
I sandblast etched into the aluminum intake pipe the Porsche script. Attached image(s) |
iamchappy |
Aug 23 2007, 01:15 PM
Here is the engine layout. I have made a few changes since this picture, but it gives you an idea.
Attached image(s) |
iamchappy |
Aug 23 2007, 01:20 PM
view of tail pipe. Now back to work...
Attached image(s) |
Root_Werks |
Aug 23 2007, 05:09 PM
Village Idiot Group: Members Posts: 8,308 Joined: 25-May 04 From: About 5NM from Canada Member No.: 2,105 Region Association: Pacific Northwest |
My friggen good lord man! That is amazing! I am going to watch this thread! (IMG:style_emoticons/default/boldblue.gif)
Lo-Fi Version | Time is now: 28th April 2024 - 07:28 PM |
