What front oil cooler should I pick, I need to cut the body out soon |
PanelBilly |
Jul 25 2008, 06:36 PM
914 Guru Group: Members Posts: 5,807 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I was going to try to get away with just using the oil cooler on the engine and stay with a 3.0, but after riding in all the cars at WCR, I think I need a 3.2. So what cooler should I prepare the body for?
Its important that it be a model that uses a finished duct sheild allowing enough room for a spare. I want the front trunk to look right on the inside too? |
rfuerst911sc |
Jul 25 2008, 07:45 PM
Advanced Member Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
I'm doing a 3.0 conversion and I will be running a front oil cooler in addition to the engine cooler. I also want my trunk to be a trunk so I'm going to try something different. If you are familiar with early 911's with front mounted coolers they fit in front of the tub spaced away from the tub for good airflow. To do this they have a valance that protrudes away from the body allowing this spacing. I'm going to use a Behr oil cooler off a Mercedes diesel, this is a cooler the MB diesels used and was mounted in front of the radiator. It is typical German craftsmanship ( rugged ) and should work fine. I'm actually going to customize my front valance to look like the early 911's and hope to mount the cooler in that space. If I can do this I lose zero trunk space. Yes the oil cooler is more vulnerable but there are LOTS of 911's out there with this same setup. And I was able to pick up the cooler with OEM fittings for $50.00 (IMG:style_emoticons/default/biggrin.gif) Time will tell (IMG:style_emoticons/default/beerchug.gif)
Aaron Cox |
Jul 25 2008, 07:48 PM
i had heard that the inlet sizes on the BEHR mercedes coolers were too small for -12 or -10 size lines.
ArtechnikA |
Jul 25 2008, 07:49 PM
I was going to try to get away with just using the oil cooler on the engine and stay with a 3.0, but after riding in all the cars at WCR, I think I need a 3.2. QUOTE So what cooler should I prepare the body for? FluiDyne |
Joe Bob |
BAT Inc has MOCAL coolers for every need.....about 250-300 USD and they are nice units....get at least -12AN fittings. I just put one on BAD TUB...worked great.
rfuerst911sc |
Jul 25 2008, 08:05 PM
ArtechnikA |
Jul 25 2008, 08:44 PM
I don't think there will be any problem running -10AN or maybe even -12. AN-10 is *WAY* too small for any /6 application in the scavenge circuit. you could *maybe* get away with it in a pressure-side application, but then you wouldn't mount a pressure-side cooler up front... |
Chuck |
Jul 25 2008, 09:10 PM
What it eventually will look like . . . . Group: Members Posts: 355 Joined: 29-March 07 From: Maple Grove, MN Member No.: 7,632 Region Association: Northstar Region |
Or you could do what Rich Johnson did, and what I'm likely to do, and mount your external cooler under the rear trunk. It works for Rich in the Texas heat.
rfuerst911sc |
Jul 25 2008, 09:32 PM
I don't think there will be any problem running -10AN or maybe even -12. AN-10 is *WAY* too small for any /6 application in the scavenge circuit. you could *maybe* get away with it in a pressure-side application, but then you wouldn't mount a pressure-side cooler up front... Then I'll run -12AN. This cooler will work fine for my application. |
MoveQik |
Jul 25 2008, 09:50 PM
What size wheels can I fit? Group: Members Posts: 4,645 Joined: 5-April 05 From: Scottsdale, AZ Member No.: 3,881 Region Association: Southwest Region |
Or you could do what Rich Johnson did, and what I'm likely to do, and mount your external cooler under the rear trunk. It works for Rich in the Texas heat. When Joe did my car I asked if we could go the route Rich took as well. Mine keeps me cool in the AZ desert heat. Attached image(s) |
Justinp71 |
Jul 26 2008, 01:11 AM
Senior Member Group: Members Posts: 1,583 Joined: 11-October 04 From: Sacramento, CA Member No.: 2,922 Region Association: None |
If your not going to race it under the rear trunk is probably fine.
I bought the patrick Setrab kit with the 914gt shrouding b/c I only wanted to deal with it once and it was the factory spot. This was after hearing how under the trunk can sometimes not give enough cooling power... for hot days and DE's. Anyhow it works really good, I still haven't put the GT bumper in... Probably a little over kill. (IMG:style_emoticons/default/smile.gif) |
IronHillRestorations |
Jul 26 2008, 10:14 AM
I've put a 25 row Mocal in the right rear quarter panel, similar to oil tank, but passenger side. Worked fine with a carb'd 3.0 in TN, probably work better in the NW. If you are doing track or competition driving front mounted is best.
PanelBilly |
Jul 26 2008, 10:55 AM
Thanks for the help. I didn't want to cut a hole in the car and didn't ever think of putting one in the back. I assume you leave some space between the trunk floor and the cooler so air can pass thru it, but does the fan suck air or blow it. (OK I'm asking for rude jokes here). Doesn't the hot air from the headers just cook the oil?
Joe Bob |
Jul 26 2008, 11:11 AM
I've done them under and above the rear trunk, rear fender, front fender and nose.....by far the nose is best IF you have flow front and back....don't mount it flush to a sheet metal wall. Give it a inch or more.
Believe it or not, repro 75-76 fiberglass front bumpers have a ton of room for a cooler..... |
Chuck |
Jul 26 2008, 01:03 PM
I went back and found this photo that Rich sent me a while back showing his setup.
Attached thumbnail(s) |
Bryho |
Jul 26 2008, 02:58 PM
Newbie Group: Members Posts: 39 Joined: 27-May 06 From: Frisco, Texas Member No.: 6,080 |
Rich Lambert just installed mine.
It is a PMS Setrab kit with the 914 GT shrouding, fg front bumper and valance, etc... and I have been driving it in this 100+ Texas heat for the last couple of weeks and it is staying very cool... Extremely pleased w/ the results!!! One thing don't waist your money on the PMS floor pan w/ louvers. It doesn't work well and Rich ended up just cutting a hole and covering it w/ mesh. |
Bryho |
Jul 26 2008, 03:00 PM
Jul 26 2008, 03:10 PM
What front oil cooler should I pick LARGE ... the bigger, the better. mount it in the front, where it gets *airflow* ... and mount a thermostat as close to the engine as you can get away with. (IMG:style_emoticons/default/bye1.gif) Andy Attached image(s) |
Joe Bob |
Jul 26 2008, 04:56 PM
What front oil cooler should I pick LARGE ... the bigger, the better. mount it in the front, where it gets *airflow* ... and mount a thermostat as close to the engine as you can get away with. (IMG:style_emoticons/default/bye1.gif) Andy Thermostat.... (IMG:style_emoticons/default/agree.gif) |
TimT |
Jul 26 2008, 09:37 PM
Lo-Fi Version | Time is now: 21st May 2024 - 04:40 PM |
