Full Version: Need some help choosing Dual carbs
Pages: 1, 2, 3
Joe Bob
Jesus Geoff....isn't that a "little" simplistic? Zeke's engine had issues such as high compression and an overly aggressive advance that was unique to HIS engine. Coupled with a high speed pass at Willow Springs with out an engine break in period.... blowtorch.gif flame out....
You can't blame the engine flame out on the the carbs....you sound like Captain Crusty on Rennlist....use blue RTV and die, use braided stainless steel brake lines and die.... blink.gif
If the "cactus boy" wants the carbs they are available.
email me direct at 356@cox.net
Bleyseng
I was just pointing out that nothing is "bolt on" everything requires some effort to make it work right. I had suggested to Zeke to dyno that puppy......
Mikes carbs should be a good deal if he just can't figure out the FI. Someone here should know the baseline jetting for em too.
Geoff
Joe Bob
Yup...I agree...
cgnj
Hi,
Start Rant
We want you to succeed. None of us have our hands in your wallet. We have 914s. Most of us do put own work. Why do we do that? Is it because we are cheap? Or is it because 99% of the time the guy with his hand on your wallet, trying to sell you something doesn't really know these cars, works on some similar air-cooled product and has a similar fix that may or may not resolve your issues. I never worked on my own cars. I did a carb conversion on my first car. Here is the story. Circa 1982
Car was idling low or high, I don't recall. Took it to a local porsche shop (356 and 911). Paid for 6 hours of premium labor. What I got. Couldn't diagnose my problem. What I got. Advanced or retatded my timing, pick one. I am about 24 and unassertive. I eat the bill. I drive home and swear that no shop will ever do mechanicals on my car again. I realized that I could have bought and shipped to my doorstep, the new-fangle dual Dellorto 40mm carbs and a 050 distributor complete and have money leftover to buy tools and a Haynes book for less than what I just paid for essentially nothing. I did that.
While I was installing them, I found the cause of my idling problem. Bottom nut on intake manifold spun off and I had an intake leak. I spent about $1000 in 1982 dollars to "fix" 5 minute no parts problem.
I took the time to search for all of your posts. Because I want to beat you up? No, I want to help you. There are two many. From what I can tell, This car was a runner with a starting problem when you first bought it. You post questions, we try to help. On the posts that I have scanned, it seems that you don't ever really say. I found the problem or I fixed it. It works is different from I fixed it. Every fix seems to have lead to a different problem. We have no way of knowing if you actually are doing what the various members who probably have more direct experience with these cars than than your air-cooled guy and don't have our hands on you're wallet.
You have to let us help you. You have to say, yes I did exactly that. This is what happened. Don't do anything else. Don't leave anything out. We want you to succeed. We want you to be happy. We want you to like 914s. If you continue like this people will start to tune you out. You will be left with a non-op 914.
This site is better than a Haynes manual. It's better than (pick a number) 99% of the shops or people who tell you they know 914s.
End Rant
Why don't you start a new thread with a time line that starts with:
I bought this car I had to bump start it because the starter wonk crank. This is what I did to fix it to Should I buy carbs?
Save your money for stuff you really need, like gas and insurance.
Carlos
Wish I had a 914 and the internet when I was 16
Joe Bob
Good advice....
mike_the_man
agree.gif Totally! He keeps asking questions, but I'm never sure if he listens to any of the advice. It almost seems like he doesn't. These cars can be damn frustrating, but you have to step back, clear your head, and approach things logically.
Bleyseng
What do you expect he is 16....
Atleast Andyrew would post, "I did that and it didn't work, now what?" and "OKAY its fixed, now this doesn't work what did I do?"
Geoff
tod914
Cactus,
Here is something you should do even if you decide to get carbs!
1. Drain and clean the fuel tank. Replace the tank lines. Replace the fuel filter.
It is very easy to do and here is how you do it.
a. The gas tank evaporator(plastic box where your pour gas into), unbolt that. I think it's 6mm bolts on the top. Remove it. Unplug the wire that attaches to the fuel sender.
b. Siphon out all the gas. Look inside with a flash for any rust. Check for debree by the screen.
c. There is a big bolt that is on the top of the tank that is holding on a clamp. Undo that. Now, start to pull out the tank. There are two lines. One feed and one return. The one with the screen inside the tank is the feed. The other, the return. LABEL them on your tank. Also label where the hoses go into the fire wall. "F" and "R". Feed and Return or A & B dont really matter as long as it is consistant.
d. Now, remove the hoses and take out the tank. If the tank has rust, take it to a radiator shop, have it boiled and lined. There is this red rubbery liner they can use to create a bladded. Have them use that. Never have another rust problem. For fuel lines, you can use 8mm inner diameter high pressure line or order a kit from AA. Price will be about the same. The high pressure lines aren't needed there, but hey will last longer. Install is the reverse.
Buy enough line to redo all the lines in the engine bay as well.
Stuff you'll need;
4 inner injector seals, 4 outer injector seals, gas tank gasket for evaporator, 2 intake manifold seals. 4 FUEL INJECTION hose
clamps (not the kind u buy at home depot), new hose clamps for the fuel lines in the engine bay.
Find a local foriegn auto parts store. They should have the line and clamps.
Once you determine your fuel source is uncontamined/blocked, then we can help you with the rest of the system. Most of the vendors like Pelican will carry what you need. Only AA has the fuel sock.
That you can do yourself in a few hours. If your tank is clean with no rust, then blow it out with air. DONT use water! Make sure the sock isnt corroded. Once that is done let us know. I can walk you through the same steps that was taught to me by a member if you like. And or, Im sure other's are more than willing to help you out as you can see. PM me if you need my phone number.
Scott S
1972 2.0, carb specific webcam, euro pistons, dual 40's, MSD, compufire, and a factory 2.0 dizzy with an active vacume advance tapped into the passenger side carb.
Car was not run since right after Halloween. Uncovered it two weekends ago, turned on the key, hit the gas pedal once and it fired right up - no coughing/spitting - nothing. Immediately dropped to a 950 idle. Drove it all day. It took the tranny longer to warm up than the motor.
Do what you want - it's your car. I do agree that dropping a grand into a car that has never run would not be my first choice - new carbs wont cure a major mechanical issue.
Before everyone jumps all over my car, realise that I did not have the option of fixing my FI. It appears from reciepts that my car was one that had an FI engine fire - there is litterally not a shred of FI on my car anywhere - including randome things like the charcoal canister/lines. There was no way I was or ever will invest in all of the *used* parts to re-assemble that system. You want me to do an engine rebuild on a car that runs great just so some think its right? pissoff.gif
brians914
Thanks Tod for posting that detailed proceedure. I bought a fuel pump relocation kit last summer and did not do it because removing the fuel tank seemed like a more difficult task. I guess I can do that one in a weekend. Thanks again, Brian.
anthony
Chill out Scott. Nobody is suggested he repair his FI system 'just because' it's right. He's in a totally different place than you were. He's got all the FI pieces but he doesn' t even know why the car is not starting/running. He doesn't know if his tank, filter or lines are plugged. He has no idea whether his fuel pump is working or not. We're just trying to save the kid a grand.
I just don't understand the "I'm switching to carbs because I don't undestand FI" attittude. If someone spends a couple hours reading and a couple hours with a multimeter they'll understand djet pretty well in just a Saturday afternoon. The tests for the individual components are usually pretty easy to do.
cgnj
I rowed the same boat. I priced backdating to FI. Carbs are cheaper.
This car was a runner that needed to be bump started when he first posted.
Look at all the things that have been touched since it was bought.
Take a poll. FI failure or inadverant self induced problem, or better yet car sat for X years, bump started, ran till the fuel filter couldn't do its job anymore.
Carlos
Not an FI Missionary
Joe Bob
QUOTE(brians914 @ Mar 23 2004, 08:42 AM)
Removing the tank is not a difficult job and should be considered a maintenance item. There are critical fuel lines underneath that get ignored.
The tank has to be removed to install a sway bar as well...
Dave_Darling
First, let me state that I am an "FI guy". I think you should fix the FI.
But, if you are going to carbs...
If you trust your mechanic, you should get your parts through him. Bringing in your own parts is a good way to piss a mechanic off, because part of how he pays his rent every month is by making a little money on the parts he installs. In general, simple hourly rate isn't enough to pay the bills. (I personally would think twice about that mechanic, but if you trust him then that's good enough.)
Weber 48s are way too big for a 2.0 street engine. The 44s are a pretty good choice, maybe a little on the large side. The 40s are also a good choice, but are probably a little on the small size for a 2.0 engine. The little Webers listed (34s?) are very small for a 1.7 motor, let alone a 2.0 one.
Solexes are, from my reading, so-so. The newer ones (now made by Kadron?) seem to have a reputation as being cheap, but cheap. (Notice "good" isn't in that sentance.)
The Dell'Orto carbs seem to be the carbs of choice. The problem is that they're not being made any more, and some of the parts are hard to come by. CB Performance lists most of the parts, but it sometimes takes a couple of months to get them in. Dell 40s would be a good choice. They evidently have much better progression between idle and full throttle than the other carbs, and don't suffer so much from the "light switch" effect where power is all-or-nothing.
There are lots of choices, here...
Next, we come to the "extra stuff" you will need.
Rich is dead-on about the fuel pump. The stock pump will not work with carbs. One of the people I know who has tried it blames that for the engine fire that damaged the car pretty thoroughly not long after the swap. A real fuel pressure regulator (not the cheap chrome thingie) is probably a good investment, as is a fuel pressure gauge for carbs.
You can use your current distributor, if it's in good shape. IMHO, the "009" distributor is crap and should be avoided. Some carbs will have the correct fittings to hook up the vacuum advance and/or retard on the stock distributor, which IMHO is a Good Thing. The big-$$ Mallory distributors have many fans as well, who insist that this distributor is far better than any other for our engines.
You will need manifolds. Bug manifolds will not fit our motors at all. Late Bus manifolds (the "Type IV engine" ones) can be drilled for the three-stud pattern of the 914 2.0 heads.
You will need a linkage. A Bug linkage will need a fair amount of creative tinkering to work. The rod will need to be shortened, and the bellcranks probably monkeyed with.
You will need extra parts to make the carbs work correctly with your engine. Most of them come with venturis that are suboptimal (in some cases very bad) for our engines. Most of them need re-jetting. And so on. So a collection of venturis, main jets, idle jets, air correction jets, emulsion tubes, and on and on are things that you will need. Plus some advice on where to start, plus tuning time.
Speaking of tuning, a real synchrometer is the only way to go. The "Uni-syn" floating-ball thingie is not generally considered the best way to synch the carbs.
Once you add up all the stuff above, you might see fixing the FI in a new light. ... Or maybe not.
Most of the "usual suspects" in terms of suppliers have been mentioned. I think Pelican may also sell Webers and associated parts, but I'm not sure frankly. (As I said, I'm an FI guy.) John C at aircooled.net will generally have good (not necessarily great, but good!) prices and excellent service. He seems to be one of the Good Guys. I think Pierce Manifolds still does sell Webers for the 914 as well.
That's all I can come up with off the top of my head.
Now, you need to figure out if it's worth it for you to take the car to someone and have them "just fix it", or if you want to do the work yourself. If someone else is doing the work, you should probably let them pick the parts if they have strong opinions... After all, you are trusting them to do the work, right? And let them make their profit off of the parts prices as well. If you DIY, then you can shop for deals to your heart's content. But it takes longer, of course, and it's more work.
Again, my opinion is that the stock FI should be fixed. But if you want to go to carbs, the above is the best advice I have.
--DD
brians914
Sounds like I better get it done before I am in Mr. Cactus's shoes.
Mueller
at first glance into the engine compartment the FI and wiring can be intimidating, add in the cost of some of the FI parts and I can see why people go that route...hell, I started down this path myself once...the only reason I sold my carbs and taught myself more about FI was due to wanting to turbo or supercharge my car and I even tho carbs can work with either system, I've come to the conclusion that FI is better for my application...
as to those 1.8 dual carbs...my only concerns would be getting rebuild parts for them......
Scott S
QUOTE(anthony @ Mar 23 2004, 08:53 AM)
My frustration comes from how the carb vs FI topic seems to always outweigh any other discussion point. there are folks on this list who own some extremely poor examples of our beloved cars - things I would classify as rusty pieces of junk that have no business being on the road. Yet we welcome them with open arms, tell them what a great car they have. Then there is other ugly head - if a car is on ebay and not owned by one of our members it is a piece of junk. If it is carbed, it has been butchered by a crappy mechanic and worth far less than an FI car.
Sorry for the rant - it's just getting old.
fire away....
Joe Bob
That's what is nice about this forum....unlike a email subscription list. If the subject is one that makes you wanna blow chunks, you don't HAVE to read it or participate.....
majkos
Scott, I'm glad you've vented,just not worth holding it in. You've something to say,and we listen(read) clap56.gif Truthfully,if it's any consolation,you've one of the Baddest,neatest carbed set-up! wub.gif
I too,live in Colorado, and was very impress to hear how well your car can start up and go w/o having to warm up! I've F.I. and have to wait for 'her to warm up.AND I HAVE A HEATED GARAGE!
and laugh at all stories on this unbeivable site!
QUOTE(Scott Schroeder @ Mar 23 2004, 10:28 AM)
fire away....
but i think you're right. a good carb setup does not devalue a car, IMHO.
i'm not a CW.
if it works, it works.
i used to work with carbs and dual setups for years on my VW-Bugs.
(had probably 10 of them over the years).
everything from stock single carb to dual & quad with homemade linkage
and manifolds and kompressors all kinds of trick schtuff.
i knew how to work 'em and then i bought this VW-Bus that had a 2.0L
Type4 FI engine in it. 100 HP made the bus going like crazy.
ripped the engine out and threw it into my bug.
that WAS an eye-opener. i didn't know sh$t about FI at the time.
hooked it all up and it ran. no cold start problems anymore.
fired right up everytime. perfect idle. smooth running.
i haven't looked back ever since.
Andy
GWN7
What most people have tryed to point out to Catcus is that he has a 1/2 working FI system now and it would be cheaper to get it fixed right than going to the carbs.
Only time I have seen people poop on carbs is when it's a single bug style or they are duels on a car ad that states it's all orginal.
BTW I have Dells on the 70 and can concur that they take tinkering. The flow meters are available on Ebay for $50 all the time and some parts have to come from Italy for them.
The 73 is FI and the 74 has a single carb setup waiting to go in it, but as it's a 750 Holly I don't think anyone but a CW will complain. The 71 will be FI, but the only reason for that is I have all the parts and can spend the $1,000 for converting on other things. beerchug.gif beer3.gif
mike_the_man
So Cactus, you out there? What do you think of all of this? Let us know how the carb swap goes, if you decide to go that route. Although I think there have been many reasons stated to stay with the current fuel injection. What do you think?
krk
It's funny. Dunno if I'm a Carb guy or a FI guy.
When I got the 73, I was a carb guy -- no instinct for FI -- and it had problems. It was pretty frustrating, particularly without internet resources for debugging the thing. A simple vacuum leak could produce very odd results. I'd fix one and I'd have a different very odd problem as I moved from leak to leak. I eventually realised that the vacuum hoses were probably original and all leaked -- I replace them all in one operation. It was a totally different car, and it basically ran beautifully until I sold it. So perhaps it was an acquired taste, but I loved the FI on that 2.0. Quiet, and no funny gas smells.
Now I've got my /6 running (second week daily driver duties -- still no roof on! laugh.gif), and have started getting used to carbs again. There are things I think are fun about them -- they make "go fast" sounds even when you're not going all that fast -- and they are an analog system, so the symptom is often closely related to the problem. (even being out of practice meant that I could diagnose and quickly fix a dirty idle jet) But they do give off more noise, and more gas smells, then the FI ever did on the /4.
So given my druthers, on a stock /4, I druther have FI. If I were hopping up a /4, you get to choose between a megasquirt-type system or carbs. 'Till Saturday, my druthers on the /6 were carbs -- but the Turbo came home -- so my druther for a /6 is a turbo! wub.gif
As for our cactus (aside: we are cactus/succulent gardeners here at our house -- "cactus boy" is a better name than Mr. Succulent laugh.gif kidding of course) problem, I think lots of folks have given sound comments on this thread. The goal is a running car -- pick the one you are most confident at winning with and tally ho. (remember to save the old parts). Best of luck with either choice -- there will be folks to have answers here either way.
kim.
weird_looking_cactus
Ok ok... I have to admit that I had a problem. Probley the main reason I wanted the carbs was so I could tell everyone I have porsche with dual weber carbs and when I pop the engine lid I wanted something to show off. But I just got back talking with my mechanic and he was working on my porsche he seemed very happy about the progress so it made me fill alittle happyer about fuel injection. He had lots of little gizzmoes hooked up to my car like remote starter some little fuel injecter pluse lights and he had put brand new connections on all the fuel injection wires. But he said he still can't get any pluse. So next he's going to clean the distributor and check the fuel injection trigger points and clean it all up. When I first went there I forgot to ask how much they charge an hour. I asked him today and they say for students its about $40 a hour. If I wanted to get my car fixed like today they it he said it would go up about to $70 but he's not constly working on it just when he has spare time. Here is a list of things I have done to the car. Before bringing to the shop
1-Took the fuel tank out changed all the gas lines there cause they were leaking bad
2-Changed all the fuel injecter lines cause a couple were linking
3-Put a new ignition switch in hoping with would fix my starter problem I now know its the wire,
4- I stuck a new fuel injecter in cause when I had the system running and found one was not shooting
5- I put new spark plugs and wires in.
6- I put new points and condensered and new distrubitor cap.
7- Put a new ignition coil
8- Changed the oil twice withen the same week.
9- Took all the old raggy carpet out found there was a hole under the seat cause of rust so now I need to weld a plate over that.
Here is what plan to do with the next month
1-Get the car running on fuel injection or carbs
2- fix the hole
3- get 2 new turn signal lenses
4- get new porsche back trunk lenses
5- buy a carpet kit
6- replace old beaten up seats with nice ones
7- buy dash cap or get a new dash
8- sand car down prime and paint black
9- drive car to school show my friends I have a porsche
So if I stay with fuel injection I will probley have lots of money left over to do all the things I want to do but I still think it would be nice to have something to show off in the engine.
Joe Bob
OK....clarify please....in one area you say that the wrench can't get a pulse, then one of the injectors was replaced....
I assume that meant no pulse to the injectors? If so, why was one replaced?
Also has the INJECTION trigger points been looked at? They are under the points for spark plugs in the dizzy....
I replaced one of the injecters before the fuel injecter system went out on me cause I switch it with another and it still did not work but the other still work in the old ones spot. And yes the mechanic is going to look at the trigger points. Im not sure what your talking when you say ""wrench can't get a pulse"" mueba.gif
Joe Bob
First paragraph.....you wrote,,,But he said he still can't get any pluse. ......
wrench = your mechanic
mike_the_man
Sounds like somebody has carb envy! Is that a big weber in your engine bay, or are you just happy to see me? laugh.gif
Joe Bob
QUOTE(SirAndy @ Mar 23 2004, 03:14 PM)
QUOTE(weird_looking_cactus @ Mar 23 2004, 02:40 PM)
if that's the case, get your engine tin and intake runners and fan housing powdercoated in a "bright" color...
bright yellow would go nicely with a black car as would a bright red or bright blue.
even green will work.
get the "fake" braided lines and put them over your vacuum hoses.
get a chrome K&N air filter.
that should add some bling-bling to your engine comp.
Andy
Bleyseng
You can also get rid of the air cleaner and run a K&N cone filter so that looks cool. Dual carbs look ok but FI all painted up looks nice and rice.
Geoff
I like the sound of the chrome airfilter but can't seem to find any pictures huh.gif also can you discribe what powdercoated is. Also would it be easy to paint.
Bleyseng
Korijo just did some powdercoating at home.
Basically, you spray the powder paint on and then heat it until it melts and then drys.
no one chromes the air cleaners due to the cost. You could paint or powdercoat it chromesilver or red if you want.
Geoff
I posted the engine bay pic just to show you what it can look like if you clean it up.
QUOTE(weird_looking_cactus @ Mar 23 2004, 03:39 PM)
someone had a pic of a nice engine with yellow powdercoated tin ...
it was posted here, dunno which thread.
9xAuto, altough i think their HP gain claims are wishful thinking (or better, wishful marketing),
it does look better than the stock air-box ...
IPB Image
Andy
found it!
check out this thread for a lot of pictures of nice looking powdercoated engine tin and intake runners etc.
http://www.914world.com/bbs2/index.php?act...llow+engine+tin
Andy
krk
QUOTE(SirAndy @ Mar 23 2004, 05:08 PM)
found it!
Andy
Andy,
That is an evil thread. If you have any thoughts about coloring or power coating, this thread will suck you over to the dark side in a hurry!
But definitely there is beautiful work on that thread!
kim.
anthony
Do those exposed K&N cone filters run when it's raining?
rhodyguy
kevin
QUOTE(anthony @ Mar 23 2004, 05:28 PM)
as long as you have the rain-tray.
if not, you need to put a rain-block-off plate over it ...
Andy
Bleyseng
I have run a K&N cone filter on my 2.0l just mounted to the TB. Looked cool
Geoff
Can I take out all the engine tin out and paint it with out dropping the motor. Is that possible also what about the fan housing hows that come off.
rhodyguy
probably and probably. getting it all back in is another story. much faster to drop the engine and MUCH easier. take the engine out after you get it running!!!!!!!!!!!! what did the mechanic tell you? you need to approach this car methodicly. worry about a showy car after you have a running car!!!!!! i fear you will get it in pieces, run out of patience(we're starting to) and money. you going to send me the postage for that coil?
kevin
QUOTE(weird_looking_cactus @ Mar 24 2004, 06:19 AM)
with motor OUT of the car, it'll take you a saturday. (including the dropping of the engine).
with motor IN the car, it'll take you a week before you give up and drop the motor anyways.
Andy
mightyohm
QUOTE(Bleyseng @ Mar 23 2004, 06:29 PM)
Geoff
Around December you could put christmas lights on it and a little star...
majkos
sunfloweryellow914
Mr, Cactus
I feel for you.
My advice is to get your dad to help you put any kind of carb system in there and get the car working. Forget about everything else like rust. You'll have alot of fun with it no matter how it drives. Just get it driving. Go out with it, take the top down and have a ball. You can worry about all this fancy stuff later. Just get the thing where it runs, and enjoy.
Bleyseng
If you have been following his posts all along you will not the car first had to be push started because of a starter issue. I think it ran. I still runs but only if he pours some gas down the TB. This means its should just be a fuel pump problem, maybe just a fuse or relay. Ripping out the FI is stupid and paying to install carbs for $500 to 800 is even dumber.
He still hasn't told us what the problems are other than it don't run. We ask questions to help troubleshoot it and get no response. WTF! oh,well as he is a typical 16 year old.
Geoff
sunfloweryellow914
Geoff,
Your'e right, I'm wrong.
My note was stimulated by me remembering my first 914, a 70 1.7 rust bucket which had a single home made carb set up. It ran lousy, and got smashed inumerable times before I finally gave it away. It was held together with gorilla hair. Man, did I have fun in that car.
Joe Bob
Be advised...cactus guy lives in the ....well podunks of Utah... and not a lot of choices for foreign car service.
Sounds like the guy he is going to, is pretty much it where he lives. Otherwise it's trailer it somewhere else....
