QUOTE(andys @ Oct 7 2011, 05:55 PM)
QUOTE(wingnut86 @ Oct 5 2011, 05:58 AM)
Eventually you will have a buddy reproduce the core piece via cnc block?
Pricepoint?
It would most certainly take "a buddy" to do the work for cheap. I looked into reproducing the bearing carrier pictured in post #331 that uses the larger 911 bearing when considering a custom trailing arm offering. The up front costs for the first best quantity price break was simply more than I was willing to entertain. I think it's far easier to use a bolt on bearing carrier like the Corvette.
I also went so far as to machine a set of bearing carriers from aluminum (pictured) thinking I might do a set of aluminum trailing arms, however the post fabrication (welding) multi step heat treating schedule made that cost prohibitive; also the potential for fatgue failure wasn't worth the risk.
Andys
I have a buddy with 3 state of the art cnc machines, we can use the machines in weekends when they are not in use for production. My only cost is the raw material and beer..
Your aluminium bearing carriers look very nice, but my initial choice would be steel, unless you make a complete aluminium hub.
Also an idea is a bolt on complete hub like the lotus Elise.....I also toy with the same idea as Britain; using the complete lotus suspension....
plenty of ideas........I'm now building a hydraulic bending machine to make the new guts for the 914. I'll finish both hubs for fitment later on and my intention is to make a flat bottom from front to rear where the wishbones will be attached to. That part will at the same time be the frame for the engine/transmission.
I also want to have the option to mount the original trailing arms and I will tie in the Tangerine racing mounts into the cage. The reason for this is simply that if the inspector at the yearly checkup does not approve of my double wishbone, I can change this in an hour or so, so that I comply and they do not revoke my registration...
