Ok, I checked out the suggested 914 in Findlay, I am going to post some pictures immediately following this. There is good and bad. First I'll run through the bad, and then someone should chime in and let me know if the good makes up for it.
Bad:
-Expense, this is a car in pieces for 6500, which can buy a lot of car in a lot of places
-There are some rust issues, although not in the places I suspected.
-----two or three pinholes in the passenger long, not hell hole
-----3x3 hole under gas tank
-----holes at bottom corner of tail lights on both sides
-----small hole under the driver's headlight
-----rust scale on bottom of trunk and behind front bumper
-It's a 76' so it has holes for bumpers I don't want, and doesn't come with bumpers I do want.
-I'm not sure How wild I am about yellow
-It comes with two transmissions, both in unknown condition, one side shift, one tail shift
-it has holes for a hood badge and a rear reflector(not crazy about either)
-my 5 lug wheels wont fit it
-Front mounted oil cooler mounted with rivets to the trunk floor
And now the good:
-The paint seems REALLY nice
-----is 2001 boxter yellow, which should be fairly easy to match
-no evidence of rust in the hell hole
-no signs of rust in the floors near the firewall
-no rockers on car to cover up horrors
-2270 Raby big 4 (CLAIMED 160hp at wheels
seems too high)
-SS heat exchangers
-Accusump bladder (not sure exactly what this is, I heard it pressurizes the motor oil before it turns over)
-front and rear sways
-BMW front calipers
-turbo tie rods
-harnesses+harness bar
-ss brake lines
-19mm master
-LOTS of spare parts
--two transmissions
--two sets of seats
----one with yellow inserts, one stock
--AN ORIGINAL SARATOGA TOP!!!
--SS rocker panels
--Maybe an extra motor or two
--extra tops
--He will deliver to me at no extra charge
SO... will everyone please chime in and help me decide Deal or no Deal?
Thanks in advance!
-Ross
Trunk Floor Looks flawless except for a tiny bit of seam sealer missing in the corner
Click to view attachmentClick to view attachmentUnder the trunk starts me worrying
Click to view attachmentClick to view attachmentIs anyone familiar with "Controlle" shocks? never heard of em myself
