I have the inner adjusters. Dems ain't free though
Here's something to consider if you have the tool set:
If you have an 8x1.25 die you can mount that inner adjuster in a vise by that flange. Run the die up and down until it rides smoothly and you should be good to go (unless that 4mm hex is stripped)
If that hex isn't stripped that should solve your problem. Give me a call this morning and we'll put together a care package to get you running. Follow the banner below for the number.
