Dave_Darling
Jan 28 2012, 11:33 PM
Easier, yes. Cheaper? Not sure.
To change from the tail-shift to the side-shift setup, you not only need to change the transmission (or modify the tail-shift one), but you also need a complete later gear-shift linkage, including all of the rods and even the gear shift lever itself, plus the motor mount bar and all of the mounting hardware for that bar.
--DD
Jeffs9146
Jan 28 2012, 11:36 PM
QUOTE(Dave_Darling @ Jan 28 2012, 09:33 PM)
--DD
Except he has a factory 6 so the Motor Mount is not an issue!
OmaPossu
Jan 29 2012, 02:30 AM
QUOTE(Jeffs9146 @ Jan 29 2012, 07:36 AM)
--DD
Jeff, I wrote about my ex 914 (1971 1,7), not 6.
Jeffs9146
Jan 29 2012, 09:12 AM
Oh!
OmaPossu
Jan 29 2012, 01:00 PM
I found this number on the side shift transmission in my 6
Click to view attachment 914.301.101.00
I did not found anything with this code. To what model it belongs?
Niklas
Jan 29 2012, 01:10 PM
I think it is for a 1972.
Niklas
Jeffs9146
Jan 29 2012, 01:20 PM
Along the top of the transmission stamped into the ridge there should be a number! I remember seeing it I just don't remember what it was except it was not 914/01!
Jeffs9146
Double post
Jeffs9146
Jan 29 2012, 01:21 PM
Here is a photo of a 914-4 stamped serial number and a 914/6 stamped serial number!
Jeffs9146
Jan 29 2012, 01:32 PM
What's going on with the web site today! If I edit it makes a whole new post??
OmaPossu
Jan 29 2012, 01:42 PM
Ok, I'll check the transmission numbers next time I visit garage.
Jeffs9146
Jan 29 2012, 05:28 PM
You might want the contact this person they have alot of what you need!
Pelican ThreadFor Sale Link
OmaPossu
Mar 27 2012, 01:29 PM
I was starting to clean up oiltank and found this little crack. It is in upper part of tank.
http://harrasteet.1g.fi/kuvat/OmaPossu+II/...27.3.12+011.JPGShould I solder it or just leave it like that?
How to paint tank, how was it after it left factory?
OmaPossu
Mar 29 2012, 03:20 PM
OmaPossu
Mar 31 2012, 01:14 PM
Where is all the rust? Very little rust in this 6-body
Okay some accident repair and welding has to be done!
QUOTE(OmaPossu @ Mar 30 2012, 12:20 AM)
OmaPossu
Apr 1 2012, 10:13 AM
Is this oiltank copper? What is this paint then? It does not weight as much as copper should.
http://harrasteet.1g.fi/kuvat/OmaPossu+II/...il+tank+028.JPG
Niklas
Apr 1 2012, 12:00 PM
That was not so much work on your body.
Looks easy !! 1-2weeks work.
I think you should epoxypaint the body as soon as possible.
The oiltank is cooper coated so it will not rust.
why don't you powdercoat it? Satin black.
Niklas
OmaPossu
Apr 1 2012, 12:38 PM
Its soda blasted so it is not so hurry with painting.
Do I have to take copper away before powdercoating? Its rust free and copper layer is solid. What paint would stay on copper?
Niklas
Apr 2 2012, 12:34 AM
No I think you just can paint it.
OmaPossu
May 16 2012, 06:08 AM
Just got all four fenders from Restoration Design, sail panel repair piece from 914-teile and shake hands for a deal with Lithuanien restoration shop. Body is going to Riga for straightening and welding and painting
But what is the colour...
Mr.242
May 16 2012, 08:54 AM
I had my oil tank specialty coated with a covering (gloss black) that helps PULL heat out or a distrubtion heat coating. It looked very good and in concept it can't hurt to help pull some degrees out from the oil.
I think the color came out nicely and I'm all for using new technology on these cars that was not around in 1970.
Here is a look (crappy cell pic):
Click to view attachmentUsed these people:
http://www.performancecoatings.com/index2.htmlGood Luck!
OmaPossu
May 17 2012, 12:00 AM
Interesting coating and looks good! I already painted my tank old way..
Can some body help me to show my repair shop how to make those back and front boot sprayed seam sealings? Need pictures to show! If pictures are from silver -6 cars the better. If you like to help, send pictures to my email, jukkapoh @ gmail.com
OmaPossu
May 22 2012, 12:38 PM
OmaPossu
May 30 2012, 12:48 PM
Damn, deal with Latvian shop went off
They drag price up and up..
Back to begining. Motivation do not disappear.
Niklas
May 31 2012, 04:56 AM
Sorry for that.
It is expensive to do sheetwork on cars in Scandinavia...
The best is to do it yourself:)
Niklas
OmaPossu
May 31 2012, 10:39 AM
May be I am waiting for you, Niklas, to do the welding
Niklas
Jun 1 2012, 02:07 PM
QUOTE(OmaPossu @ May 31 2012, 06:39 PM)
Sorry but i don't have the time.
I have two 914 and two vw pickups and one beach buggy to get ready
The beach buggy will be ready within a week or so.
Niklas
OmaPossu
Jun 1 2012, 02:18 PM
I made new deal today with local welder/painter
Only problem is that he does not have "celette bench" but I can arrange that elswhere.
It's going to cost little more than in Latvia but...
Relieft!
Niklas
Jun 24 2012, 11:57 AM
Do you really need a bench to the body ??
You can cross meausure the body.
Have you measured it ?
Niklas
Jun 24 2012, 11:59 AM
What is the cost to fix the body....??
OmaPossu
Jun 24 2012, 12:29 PM
Niklas: I have not measured it properly but drivers side front corner seems to be 3-4cm up. Thats 1,5 inch. After celette bench I am sure its straight!
Maybe Jeff has an opinnion about this?
4k€ for velding and painting in Finland. Cheap in Finland, expensive elswhere..
OmaPossu
Jun 24 2012, 12:32 PM
..btw I bought used whole drivers side inner fender and front trunk floor from Germany. Costs delivered 200€.
914Timo
Jun 24 2012, 01:16 PM
Keep up the good work. Hope everything will go fine with the new welder.
914Timo
Jun 24 2012, 01:17 PM
double post
Niklas
Jun 24 2012, 03:07 PM
4000 Euro for paint and rust fix is very cheap!!!
Normal price for paint a vw bug in my area of sweden is 2000 Euro.
I think you have got a good price!
Niklas
Niklas
Jun 24 2012, 03:11 PM
QUOTE(OmaPossu @ Jun 24 2012, 08:32 PM)
that was very cheap!!!
I payed more for my front trunk floor from Holland.
Niklas
OmaPossu
Jul 27 2012, 02:09 PM
Somethings happening at last! Body is now in Autorobot (Celette bench) and straithning begins next week. It is not straight, now its easy to see.
http://harrasteet.1g.fi/kuvat/OmaPossu+II/Autorobot/
OmaPossu
Nov 17 2012, 11:52 AM
Nov 17 2012, 11:57 AM
OmaPossu
Nov 18 2012, 01:50 AM
Are the any official dimension for door gap's? I did not find any previous threads conserning this?
Niklas
Nov 18 2012, 03:25 AM
I think the official porsche gap is 4 mm.
Niklas
OmaPossu
Nov 22 2012, 02:18 PM
Proceeding fender by fender
Frame is straightened, bouth step panels repaired, bouth back fenders are repaired, right door hinge panel is straightened and moving on..
http://harrasteet.1g.fi/kuvat/OmaPossu+II/...Welding/263.JPG
OmaPossu
Nov 25 2012, 01:53 PM
About colour, my cars original colour was L96D or 80. How much L97A differs from that? Bouth are metallic silver paints. Pictures?
OmaPossu
Dec 7 2012, 12:39 PM
It begins to look like a car
http://harrasteet.1g.fi/kuvat/OmaPossu+II/...7.12.12+003.JPGIs this local way of making wind shield frame strenghtening kit? Found all 3 bolts and ton of glass fiber inside frame..
http://harrasteet.1g.fi/kuvat/OmaPossu+II/...7.12.12+008.JPG
Jeffs9146
Dec 7 2012, 12:44 PM
http://harrasteet.1g.fi/kuvat/OmaPossu+II/...7.12.12+008.JPG Where were those???
OmaPossu
Dec 7 2012, 01:00 PM
Just there where picture shows ;)There was 1 inch diameter hole in wind shield frame and those bolts and lots of GF was squeesed inside from there...
OmaPossu
Dec 8 2012, 05:26 PM
Need pictures under rocker panels. Need to know how this lip and upper part of rocker panel meets. Is this lip straight all the way from back fender to front fender. Are there differences between year models?
silver74insocal
Dec 8 2012, 05:45 PM
QUOTE(Jeffs9146 @ Jan 29 2012, 11:32 AM)
is it also adding exclamation points to all your statements!?!
j/k
OmaPossu
Dec 9 2012, 10:00 AM
How to clean this? Have any one used ultrasonic cleaner?
Niklas
Dec 9 2012, 03:09 PM
Show us a picture of this rocker panel.
Niklas
