QUOTE(76-914 @ Nov 8 2012, 06:56 AM)
So, to clarify for my dumb ass; I can but an EZ30D with just about any Suby 5-6 speed, buy the Small Car $200 kit to adapt to the 914 ECU, buy your kit and have basically what I need sans the cooling, clutch parts? And if this is correct will it matter whether I go JDM or USDM. TIA, kent
Kent,
Basically, you are right in your recipe; however what the small car DIY kit does is allow the use of the stock SUBARU ecu. This is an alternative to an aftermarket standalone ECU, which is powerful and flexible but expensive. The DIY kit helps you weed out 70% of the unneeded wiring, resulting in a wiring system that consists of the ECU and only the wiring to run the engine properly (I’m doing a full ez30d set up for a customer right now, I’ll take pictures of the wiring before and after, I would bet there is 50lbs of copper that is removed).
"Just about any 5-6 speed," is not quite right either, although from about 93 onward manual Subaru transmissions can bolt up to basically any engine, doesnt mean they are equal. for the 6mt, only the new 2010+ 5mt based 6 speeds will work, the STI 6 speed cannot be converted to FWD up to this point and is too long for the 914 besides. for 5 speeds, in general you want to stick to the power output of the engine the trans was originally on, ie you should not throw an NA 5mt on a turbo motor and expect it to last. Furthermore, although it would be nice to think otherwise the transmissions are stronger the later the year ie: 2008 is stronger than 2004 is stronger than 2000 is stronger than 1996. Finally you want to think about what gear ratio you want to go with those range from 3.9-4.44.
I am working hard on many things right now, but i have a 5 page document with a much more in depth look at the engine/transmission choices that i will be posting up to my website soon hopefully. it should help to answer a lot of questions.
Also i do not know if small car carries jdm wiring kits, because yes it would matter.
Charlie,
I agree with you to a point on the aftermarket ECU, for people going for massive power and 90% of the JDM engines, aftermarket is the way to go. On the other hand, if someone just picked up an NA 2.2L or 2.5L for 1-1.5k(including ecu) and just want a reliable 914 with quite a bit more ummph, then the stock ECU is a better choice just for the budget. Even if a person plans on upgrading to a turbo engine later I don’t think it’s that necessary to spend the money on the aftermarket ECU. I mean with a 02-05 wrx you have both Romraider (free+50$ for a cable) and Cobb AP (200-500 used) out there for tuning assistance, at a price that is much less than a standalone set up.
On the small car stuff, im still learning, but basically it is what you described, it is made to get the stock ECU running not much else. However they do leave in the OBD2 dongle, which leaves an opening for romraider or AP. For the EZ30D i have found one experimental definition for romraider out there, which opens up some tuning options.
Thanks for the kind words, always nice to hear support =). I am thankful to all the pioneer conversions as well, I probably wouldn't be here without them. I'm definitely not an expert by any means on the wiring/ecu side of things, but I'm learning and exploring options as I go and the goal down the road is to be the source for basically top down subaru conversions on 914's cooling, ecu, engines and all. "kaizan," hmm, I've never heard that before, you may be interested to hear my plans for my own conversion then. Starting out narrow body 4-lug with an ej22/25 franken engine and taking it through the conversion life cycle, tracking my progress as i go, ending with a 280+ HP beast with all the trimmings.
