914GTSTI
Nov 11 2018, 06:02 PM
Yes, I found out the tran's is a 06. Male axles and using the case numbers.
I was told by the old owner it has a LSD but we will see.
Also been think over the weekend and think I will just use the 901 and the Turbo " Leg "motor and build a cradle for it. Also think I will leave the GT idea behind.
This will free up the trans and EZ30 for a different build.
76-914
Nov 12 2018, 10:49 AM
IMHO, running a 901 on anything other than a Porsche power plant is akin to driving a square peg into a round hole.
914GTSTI
Aug 5 2022, 01:41 PM
914GTSTI
Aug 5 2022, 05:55 PM
Went back and reread my build. Only change was I used weld-through paint on this arm. Man I have been doing this car for a long time. Sad. But I'm not dead yet.
914GTSTI
Aug 15 2022, 10:30 AM
After looking at 6 taillights. I now have one left and one right. What a pain. But I saved $$$.
Click to view attachment Click to view attachment
914GTSTI
Aug 15 2022, 10:32 AM
914GTSTI
Aug 15 2022, 07:36 PM
Supply's are here. Paint the "Mirror Chrome" tomorrow .
914GTSTI
Aug 16 2022, 05:55 PM
First paint down. Black. In 48 hours I will spray the chrome. Then we will see. But anything will be better than what is not their now.
autopro
Aug 16 2022, 09:00 PM
I've used that paint before and it works great, do light coats and it will really look like chrome. The only problems I've had is when I try to clear over it, the chrome turns dull and just looks like silver paint.
914GTSTI
Aug 16 2022, 11:58 PM
QUOTE(autopro @ Aug 16 2022, 08:00 PM)
I did some checking and the "net" said don't do it and that is the way I will go.
914GTSTI
Aug 17 2022, 03:39 PM
Opened up the right jack point. Lower outer jack cove is rusted. The next inner panel is rusted. The next panel looks ok so far. Take a look and tell me what you would do ?
Click to view attachment Click to view attachment Click to view attachment Click to view attachment Need to move the lift arm to cut our the lower spot welds.
rjames
Aug 17 2022, 07:58 PM
Wire wheel and keep cutting back little by little until you hit good metal, then replace it.
I encountered a similar issue when I first got my car.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
914GTSTI
Aug 17 2022, 10:11 PM
That was what I was thinking.
Thanks.
914GTSTI
Aug 27 2022, 04:23 PM
Been planning what wheels I will be using and don't want to pay for changing them. So started building a HF manual with the duck thing. Will test tomorrow. Will use the biggest tire and rim I have 295/50r15 on a 10 x 15 .
914GTSTI
Aug 28 2022, 05:31 PM
A little more progress. Maybe test tomorrow ?
914GTSTI
Aug 28 2022, 05:32 PM
914GTSTI
Aug 29 2022, 04:58 PM
It works !
Just need to get it bolted to the shop floor.
914GTSTI
Aug 29 2022, 07:57 PM
question. Leave the the motor seal or remove it ? I will be using EZ Subaru motor.
914GTSTI
Sep 1 2022, 05:17 PM
Tested the tire change and it worked Great. Now I can play with any tires I want.
Painted the chrome today also. What do you think ?
914GTSTI
Sep 2 2022, 12:06 AM
Wanted to say THANK's to 914 Rubber. I ordered two turn signal covers and gaskets and for got the screws. I then ordered the 4 screws on a different order. I got a refund for the shipping . They put the screws in the first order. Way to go 914 Rubber. "THANKS"
914GTSTI
Sep 2 2022, 05:30 PM
914GTSTI
Sep 4 2022, 05:53 PM
First clean up. Used by blaster co clean off the bad paint and to prep for a refinish.
autopro
Sep 6 2022, 12:31 PM
Looking good, chrome paint came out great!
914GTSTI
Sep 7 2022, 05:07 PM
Mounted up a 185/55R15. Looks good.
Click to view attachmentClick to view attachmentAnd the 914 Rubber lens and seal are installed. Simple thing but fun.
Click to view attachmentDid the math on the Subaru WRX 5MT with a EZ30R using the 185/55R15.
At 2500 rpm with a speed of 62 in 5 gear.
Also tested the tail lights. May need to get new covers ?
Click to view attachmentAny reason not to go with this size tire?
On a side note I'm not going to go with the GT look. Maybe later but for now .
Just going to do the repairs and get on the road.
914GTSTI
Sep 11 2022, 01:18 AM
One more wheel cleaned and will seal on Wednesday. Using Cerakote Clear - Aluminum MC-5100.
914GTSTI
Oct 3 2022, 02:05 PM
A very little more. But it is moving forward.
914GTSTI
Oct 6 2022, 02:02 PM
Some more cutting. Need to get a face shield.
Click to view attachment Is their a listing for the spot welds on the panels. Like where they are ?
Thanks
914GTSTI
Oct 14 2022, 07:43 PM
Am I getting this right ?
R_u_dd
Oct 15 2022, 08:57 AM
QUOTE(914GTSTI @ Nov 10 2018, 11:45 AM)
Got some parts in. Very nice !
But still trying to decide what way to go ? Use the 2.0 turbo with the 901 or sell that setup and go with a EZ30 and the MT5 ?
Ideas ?
Zerodecibalmotorsports.com. is that the vendor website?
914pipe
Oct 15 2022, 10:11 PM
I'm running a EG33 with a FuelTech 550. If I change my engine I will go with the 3.6 . But you won't go wrong with the EZ30.
Maybe you have seen this clip:
https://youtu.be/uod6avfs4AM Here are some pics of my running build... It's stupid fast and make great noises!
Click to view attachmentClick to view attachmentKeep it up!!! I would like to see more of this build!!!
Pipe
914GTSTI
Oct 16 2022, 11:30 PM
Yes, great run. But I think you may have cooked your tires .
914GTSTI
Oct 31 2022, 11:21 AM
Things change. Putting up my car's for sale with all the parts. EJ20T with Kennedy adaptor kit with new starter , two 914 motors not running. Exhaust built for Subaru motor to turbo. Two cars with titles one I can't find. Main car is almost rust free but drivers side front has been fixed at some time. Two tran's one side shift. One is a roller the others are on pallets. 5 Fluke wheels 3 striped . Some photos of the other car's. Have a forklift to help load.
$6500
Thanks
Click to view attachmentClick to view attachment Click to view attachmentClick to view attachmentClick to view attachment
914GTSTI
Nov 2 2022, 11:04 PM
OK
I will just build it .
mgp4591
Nov 3 2022, 05:52 PM
QUOTE(914GTSTI @ Nov 2 2022, 11:04 PM)
OK
You've got a support group with fellow Subaru hybrids here and thanks for your posts so far. Look forward to many more to inspire me and others as well!
914GTSTI
Nov 3 2022, 11:33 PM
I will try to keep driving.
