[quote name='76-914' date='Jan 7 2013, 03:11 PM' post='1798330']
[quote name='scotty b' date='Jan 7 2013, 11:30 AM' post='1798206']
"I'll be doing 2 in the not to distant future ( hopefully by the end of the month and can do a write up at that time "
That would be stellar Scotty. I went thru 6 pages of your topics and found where this was touched upon but didn't find any details: I have prep work to keep me busy until you post up."Either leave the doors on while you weld the vertical walls, or brace the jambs as I and others have shown when doing hell hole repairs"
Bracing has got to be the correct answer. probably the biggest thing is to TAKE YOUR TIME, and space the welds out. Do not start in one spot and work your way around. Instead do 2-3 welds in the center of one panel. Move to the other side of the car and do 2-3 welds, then move to the back panel and do 2-3 weld. GO back to the first and do 2-3 at the opposite end. This keeps the heat in any given area to a minimum.
So a little like torque sequencing a head, no?Use .023 wire. This requires less heat and will give you every bit as solid of a weld as a heavier wire will.
CheckPreferably leave the doors on and the brace in such a way that you can shut the doors periodically to check the gaps. This way you will see any change before it is too late.
This in itself is worth waiting for your writeup. Trying to think what that brace would look like. I also like to start in the center of the panel so I can make any adjustments in the fit as I work
OK, this part needs splaining to me. By adjustments in the fit do you mean how well the 2 pieces mate or whats happening in the shrinkage dep't?
[quote name='Trekkor' date='Jan 7 2013, 11:35 AM' post='1798207']
http://www.914world.com/bbs2/index.php?showtopic=14508Had all four wheels on the ground.
No shrinkage or bracing.
Now you see; yet another successful approach though contradicting common sense. I see your in CA also Trekk. Could it be our chassis are beefier because we have less rust?
KT
Another thing that I would like to see addressed is what to do if you begin to notice small warp-age occurring. When and how to correct, if you will. Or am I totally overboard on this and have no worries if I follow ScottyB's tutelage.
[/quote]
By adjustments to the fit, I think he means fitting the stiffener kit tight to the frame so it can be welded properly. I had to wedge a piece of steel tubing against the opposite long. to get the stiffener kit steel to lay flush against the long. A few times I had to resort to a BFH.
It took me awhile to learn that fit-up is one of the most important parts of getting a decent weld. And I'm a slow learner.
I'm pretty sure Scotty might know what he's doing. Following his advice and ignoring mine, might also be good advice.
