QUOTE(r_towle @ Feb 2 2014, 09:26 AM)
Quickly....
The floor pan welds over (under really) the inner long?
So it's just laying on the inner long in that area where you show a picture above?
I know I have done this before, but I cannot see it ......
Yes Rich, The factory inner long actually has a slight recess pressed into the bottom. The Restoration design part does not. It also does not have the stamping recesses for the muffler clamps or the oval shaped cut outs. I only used the Restoration Design part as a starting place.
Because of the condition of this car (not as rusty as most) I determined what I needed to actually repair.
I cut the rust damaged inner long section out, I fit a section of the R.D. part then used my bead roller to add the recess to the R.D. part. When you look at the area where the pan spots to the long the repair I made now looks like the factory section I left in place.
Once I had the section where the seat belt bolt is welded in I used the balance of the R.D. part as a reinforcement and plug welded it to the inside of the long.
Here's what I worked on yesterday. This is a reinforcement panel and a outer rail closing panel I hand formed.
Click to view attachment The R.D panel for the outer rail that welds in behind the jack post cover and it kicks up behind the quarter panel is huge. I did not need to replace that much of the outer long and did not see the point in purchasing a $ 300.00 plus part to cut off 8"
Click to view attachmentHere is the inner reinforcement mocked up in place. This part is slipped in behind the rail at the kick up and ends at the edge of the R.D. clam shell edge. This gives the 8" outer repair panel I made a backer behind the butt weld and adds a second layer of strength behind the jack point.
Click to view attachmentI have to repeat this on the left side. R.D does not make left side repair panels past the clamshell.
BTW: I don't have a sheet metal brake. All my panels are hand formed using my vise and what ever I can figure out.
