QUOTE(cgnj @ Mar 27 2016, 06:57 PM)
QUOTE(JamesM @ Feb 6 2014, 09:33 PM)
Think I have said this a few times now, but check out the later 2.1 Vanagon throttle body. 50mm, bolts to the 1.8 plenum, and has a few other neat things about it. You just want to massage out the opening on the plenum a bit to match the larger size. Intake runners on the 1.8 are the largest stock diameter you can get (same as the 2.0 914 setup)
Hi,
You need to explain this to me. I just measured the volume of a 2.1 liter vanadon plenum and a 2.0 porsche plenum. Volumes are not even close. Additionally, for a 2270 the minimum throttle body size is 58 MM. Not going to fit on a vanagon tb. I just measured and mocked this up this afternoon. Tell me why your experience is different than mine.
Carlos
What do i need to explain here? My experience is different than yours in that i have experience. This is the setup I have been running on my autox car for the last 3 years, it works great, To be clear though I never said anything about a Vanagon plenum, I am using the 1.8 plenum which is actually even smaller. Also to be clear I am running this on 2056, but its a 2056 that spends a good deal of of time above 6k RPM. Is it theoretically perfect, no, but no off the shelf parts are going to be. In fact even going fully custom you might have a hard time getting to theoretically perfect just due to the engine layout. It does work extremely well though and is simple to put together.
I am curious as to how you came to the conclusion that a 58mm throttle body is the MINIMUM for a 2270. Theoretical calculations as well as real world experience tells me this is on the upper side of where you would want to be unless your looking to build a max power high revving 2270, in which case you might as well be running ITBs anyways as the throttle body is not going to be your limiting factor.
Depending on what sort of motor you are building, best throttle control for a 2270 is most likely going to be somewhere between a 47-52mm throttle body.
