Bought a light meter to better analyze the output of the lights. Seems to work pretty well.
Click to view attachmentThe first lights I looked at where these ones for my 930. They are similar to the 914 brake lights but with 48 LEDs vs 56 LEDs on the 914 brake.
Click to view attachmentI measured the light output in LUX on the standard bulb and the LED board from about 4 ft away in the garage at night. The opposite light, the center brake light, and the license plate lights were covered up. I measured at 3 angles: 0, 15, and 30 degrees.
Here is the comparison of the 930 taillights. The LED drops off pretty quickly from center but starts at a much higher intensity. This focused intensity of the LEDs was pointed out by some folks.
However, the center relative intensity of the LEDs (directly behind vehicle) for the taillights is over 6x that of the bulb.
Click to view attachmentThis is a comparison of the brake lights on the 930. Here the same profile is evident. Directly behind the vehicle the relative intensity of the LEDs is 3.5x that of the bulb.
Click to view attachmentI tried to put this information into a format which would directly relate to the light pattern behind the vehicle. This graph shows the brake light pattern as viewed from above the vehicle. The intensities are 1x, 2x, and 3x of the standard bulb.
The driver directly behind the vehicle would see 3x intensity of the bulb.
A driver in the next lane at 10FT left or right from the vehicle about 25FT behind the vehicle would see an intensity about 2x of the standard bulb. This assumes the driving lane is 10ft wide.
