QUOTE(Retroracer @ Mar 12 2021, 01:51 PM)
I don't think you've missed anything. My set up is almost identical to yours; I ended up needing a small spacer between caliper and mount to center the caliper too. I have Carrera rear calipers / rotor / drums.
If I recall, when I was putting together mine (and memory is dim here, but): the front of the mounting lugs rides very close to the back of the rotor. It did not rub/interfere, but looked super close. Some restrained adjustment (grinder) was deemed necessary. Might want to assess that clearance on yours.
Nice job on the welding BTW,
- Tony
Pretty welds are the easy part...although there is a reason that I didn't take a macro shot of these welds. I didn't quite get pretty colors due to some crud suck in the small corrosion pits in the trailing arms.
QUOTE(sixnotfour @ Mar 12 2021, 02:30 PM)
backing plate bracket, not present= washer
Thanks for the confirmation that spacers are required. I moved porsti onto the 4 post lift this weekend so that I can drive the C10 and was able to confirm that I used spacers on the PorSti rear calipers too.
QUOTE(2mAn @ Mar 12 2021, 07:28 PM)
QUOTE(CptTripps @ Mar 4 2021, 06:08 AM)
Scott does the best work, and at some point will be crowned the "Finisher of stalled projects" by those of us that have benefitted from his extremely talented hands.
That is a wonderful title , as someone who has both had to abandon projects and picked up abandoned projects it’s so great to finish them and so heartbreaking to throw in the towel...
Can’t wait to see this done
Don't tell my BMW 2002 that I am a protect finisher...haven't touched it in nearly 20 years!
