START of 2017 Build-Off Part Deux Click to view attachment2017 Build-Off ChallengeBuild-Off Part Deux
Intro 2017
October: Michigan Build Im going to continue the build and entered the 2017 Build-Off Challange.
Here is the goals, and direction I want to go.
A. Engine:
R & Repair engine oil leaks
Replace front trans seal
B. Significant body work:
Remove the White Plasti-Dip & Finish the final body work (now primer, multi color, and poor finish work underneath)
Prime and block sand
Paint the entire car.
C. Significant interior work:
R & Replace the fuse panel, repair connections
R & Reinstall the interior to add sound deadening
Update sound system,
Modify stock seat comfort
X. Misc:
Install integrated Running lamp/3rd brake lamp.
October Update: Michigan Build Starting with the interior. The goal here is, improve the sound system, and add some comfort, plus a few small things along the way like the new fuse panel, sound padding, and dash layout. In addition I have never taken care of the floor pan. I removed the tar padding, and worked on the dash a bit.
Overall I want to keep it "clean" less is more. I have loved the simple dash design from the first time I saw it. That was a '70 basic, not even a fog lamp switch.
Removing Plasti-Dip from primed parts of the body work, little bit at a time.
I have removed this material before, and a heat gun works best. warm it up, and scrape it off. In some spots it will lift off like a sheet. In others it may pop up due to rust. I found that this time it took a lot of effort to remove. It get tougher with age, the tar not me. : ) Some rust spots, and seems to repair. More surface rust then I thought would be there. This will pay off on my satisfaction meter when done.
I also found that with the radio, and glove box removed, theres a lot of space there. I would like to keep the sub, but not the center console. Built a trail foam board box. More to come on this.
Heres a few shots. Thanks for the look.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
