Well, still on it. Worked on the hood to eliminate the headlamp doors. I, know, it took me a while to convince myself to do it. The pop up headlamps are a great feature, but.
Took the filler pieces from a spare hood, and tried to cut for a perfect fit. lots of measuring, yet still off a bit.
I found that to achieve the correct angles, and keep the front lip correct, I needed to add a little.
Weld on!
The underside still needs some work, but heres a look at the top. The front lip lines up nice across the hood. I'm happy.
Now, as far as the headlamp relocation, been doing a bit of work on that idea. Also need to install correct size studs for the front wheels, touch up a bit of errors in my welds, and general catch up all around. Thanks for taking a look.
