Jun 13 2005, 03:36 PM
ok, now *i* have a stupid question ...
what if i have 911 hubs that fit the 914 wheel bearing and i use 911 stubaxles and halfshafts and change the drive flanges on the transmission to 75-76 911,
whouldn't that work just fine ???
Andy
Dr Evil
Jun 13 2005, 04:09 PM
911 axles are shorter so that would be an issue. If the splines for the 911 out put flanges are coarse, those will work.
JFJ914
Jun 13 2005, 04:14 PM
QUOTE (SirAndy @ Jun 13 2005, 05:36 PM) |
what if i have 911 hubs that fit the 914 wheel bearing and i use 911 stubaxles and halfshafts and change the drive flanges on the transmission to 75-76 911, whouldn't that work just fine ??? |
Only if the c/v's are 100mm and the 911 axles are supposed to be too short anyway. The earlier 108's require the earlier stubs and output flanges. With Cays config the 944 c/v's have the 914 (VW) spline and you could use the 914 axle shafts.
Jun 13 2005, 04:21 PM
QUOTE (Dr Evil @ Jun 13 2005, 03:09 PM) |
911 axles are shorter |
shorter as in "too short" or shorter as in "shorter, but still OK" ???
the axles moves quite a bit left/right, so how short is too short ???
Andy
Mueller
Jun 13 2005, 04:30 PM
QUOTE (SirAndy @ Jun 13 2005, 03:21 PM) |
QUOTE (Dr Evil @ Jun 13 2005, 03:09 PM) | 911 axles are shorter |
the axles moves quite a bit left/right, so how short is too short ??? Andy |
i thought I read that if you remove the clip, they can the shorter axles as is, you just have to remember that when you jack the car up or remove the transmission
skline
Jun 13 2005, 07:13 PM
Well, I called Scott at Renegade today to see if he would sell me just the adapters. The adapters are for the bus axles. He said they only sell the complete kits now. I told him I thought $780 was a little high and he said to buy them through him. He sells them for $599. all day long. So in my opinion, that is the way to go. Everything is brand new and will handle 500 horse with no problems. Now I just need to save up my pennies so I can get a set. Then I will feel comfortable driving my car the way it was built.
neo914-6
Jun 13 2005, 07:41 PM
Scott what tranny did you upgrade to?
ClayPerrine
Jun 14 2005, 06:31 AM
QUOTE (John Jentz @ Jun 13 2005, 04:14 PM) |
QUOTE (SirAndy @ Jun 13 2005, 05:36 PM) | what if i have 911 hubs that fit the 914 wheel bearing and i use 911 stubaxles and halfshafts and change the drive flanges on the transmission to 75-76 911, whouldn't that work just fine ??? |
Only if the c/v's are 100mm and the 911 axles are supposed to be too short anyway. The earlier 108's require the earlier stubs and output flanges. With Cays config the 944 c/v's have the 914 (VW) spline and you could use the 914 axle shafts. |
You don't have to change the axle shaft if you use the 944 axles. The 944 and 914 axle shafts are the exact same length.
If you are a cheap bastard, you can buy a 944 stub axle and one CV joint, and put it on the 914 /4 axle. Then use the 914 inner CV and drive flange.
If you want to do it right, use the 944 axle complete, and the 75-76 911 transmission drive flanges.
Oh, and using a 911 axle is asking for a failure. They will bolt up, but if you EVER hit full droop or full compression you WILL bind the CV joint and damage it.
Then you will be out the cost of the 911 axle parts, and your 914 will be back home on the jackstands.
Aaron Cox
Jun 14 2005, 09:39 AM
so let me get this straight (from transmissoun - out)
coarse spline 915 output shafts -> 944 axle -> 944 Stub -> pre 74 911 hubs?
ClayPerrine
Jun 15 2005, 08:54 AM
QUOTE (Aaron Cox @ Jun 14 2005, 09:39 AM) |
coarse spline 915 output shafts -> 944 axle -> 944 Stub -> pre 74 911 hubs? |
Exactly. Just make sure that the 915 axle flanges are the same bolt pattern as the 944 CV, and you are done.
Simple, No?
Dr Evil
Jun 15 2005, 11:08 AM
How hard is it to find used 915 coarse splined output flanges? Where? How much?
ClayPerrine
Jun 19 2005, 09:33 AM
That would depend. You can probably find them at a swap meet. I had it easy, I found them in a used parts bin at the local P-car parts supplier. I just asked the owner, and he said "I got them back here" and we went and picked them up.
Put an add on the bird board in the 911 classifieds. They should be able to hook you up.
matthepcat
Apr 10 2011, 10:29 AM
I tried this combination yesterday with the 944 hubs. Too long to just "bolt right in" so I must have something wrong or this is just bad information.
Output shafts..check
944 axles & stubs & hubs from a 1987..check
Apr 10 2011, 01:18 PM
QUOTE(matthepcat @ Apr 10 2011, 09:29 AM)
This thread is from 2005. A lot of new information has since come up. There are a few newer threads about the subject.
I'm currently running 944 CV's on machined stock 914-4 axles using 911 stubbies and 911 hubs.
http://www.914world.com/bbs2/index.php?showtopic=80641
matthepcat
Apr 10 2011, 03:13 PM
Thanks Andy.
I proposed the 944 hub question on your thread.
QUOTE(SirAndy @ Apr 10 2011, 12:18 PM)
Apr 10 2011, 03:25 PM
QUOTE(matthepcat @ Apr 10 2011, 02:13 PM)
It's been a long time so i don't remember all the details, but i do remember that i looked into using a 944 hub and decided against it.
matthepcat
Apr 10 2011, 04:10 PM
I noticed that the 944 hub has a hub-centric center to it.
I dont think this will work with 914-6 rotors?
Maybe that is why.
On a side note, I am glad I did not put new bearings in during this initial test fit.
QUOTE(SirAndy @ Apr 10 2011, 02:25 PM)
