[quote name='914forme' date='Aug 6 2016, 09:33 AM' post='2381292']
There is also another unit out there that a 914er started to work on, not sure if it was completed or not. I am calling you out Clay, where you not installing one in Betty's car
looked like a clean install, with a wiper motor relocation.
Someone needs to figure this out before I
my front cabin firewall to fit a Vintage Air compact unit in. I have three of their units here to see if I can make one of them fit.
Under dash unit will fit just fine, just don't like the look, you know it was an after thought. I am thinking about trying to tuck this up in the cowl, then making new front duct section. It is vacuum based servos
Have to move the ugly controls.
Micro unit, is just .5 to tall, can fix that with cutting the a section out and bumping the firewall down in that section behind the dash. Might take a slightly deeper cut to get duct work in place.
The Mini unit is to long to fit between the cowl supports, could move them.
I have also thought about, cutting one of them up, and moving the fan to a new location, and maybe clocking it, so it fits. It is all just ABS, should not be to hard to come up with something.
Way down the list for me of things for my build, but still in my plans for my 914.
[/quote
The one I was working on was for my car, not Betty's. Hers has the underdash unit in it, and it works well.
Mine got postponed due to the engine replacement for my car. I got the wiper motor relocated to make more room for the evaporator, but didn't get any farther.
