Here is the email I sent you.
“20.
If you pull the shift console, then try to see if you can move the 1 and 2nd rods you encounter into a gear. That piece locks in the other rod when you shift. So, shift the first rod fore or aft, then try to shift the other rod. If it will shift, that part is missing. If it won’t, then that was someone’s spare that made it into your parts. ”
OK, thanks. The shift console is still off, but looking in I can only see one bronze shift fork. This is a modified side-shifter. Do I need to take off the bottom plate at the back end?
Pic attached.
No need to remove anything. Please re-read my instructions from this step and let me know what needs clarified.
"shift the first rod fore or aft, then try to shift the other rod (next rod in). If it will shift, that part is missing. If it won’t, then that was someone’s spare that made it into your parts. " Ill bet you $100 that what you have is a spare from one of the parts boxes. The fork you see is on the rod I was talking about. Move the fork/slider fore or aft to lock that in a gear, then try to shift the other rod/fork/slider. If you can even budge the next rod/fork/slider then that piece is missing.
The detent is mine... I can move one fork all the way and still move another. Can I trade the $100 I just 'won' for instructions to put it back in? :-/
