Mblizzard
Sep 10 2019, 06:20 AM
QUOTE(DRPHIL914 @ Sep 10 2019, 04:18 AM)
QUOTE(Mblizzard @ Sep 10 2019, 08:14 AM)
Well after all the struggle I have achieved failure!
Going through careful steps for starting cranked over until oil pressure built.
Started checking out all of the ECU functions and when sorting a lose wire something went to ground and
smoke was emitted from the ECU!
Luckily the 2 Amp fuse was still good so I at least I can use that over.
Time to call it and put it aside for a while.
What kind of ECU were you using? Is a replacement ECU easily obtained?
Microsquirt can order today be here tomorrow most likely but still would not have time to break in the engine and sort out all of the potential bugs.
Too much money in it to not do it carefully and right.
poorsche914
Sep 10 2019, 06:22 AM
I have a brand new Microsquirt unit in the box.
Come by and get it today.
ClayPerrine
Sep 10 2019, 07:13 AM
QUOTE(poorsche914 @ Sep 10 2019, 07:22 AM)
Do it! You have the wiring complete.
"Never Give UP, Never Surrender!" - Galaxy Quest
VaccaRabite
Sep 10 2019, 07:29 PM
Ohhhhhhhh man I have done exactly that. POP! smoke and dead Microsquirt!
The good news is that after I finished kicking myself is that there is a fuse on the board (IIRC) that can be replaced, and there is a guy in Virginia Beach that can fix it. He fixed mine.
Won't help get the car on the road this weekend, but its not the end of the world either.
Zach
Mblizzard
Sep 23 2019, 06:23 AM
Well after my last electrical failure I have been redoing all of the wiring!
Finally got to replacing the 12 pin wire harness that should have looked at least a little like this nice new one from 914 Rubber.
Click to view attachmentBut after 44 years of time and some seriously questionable repairs it looked like this.
Click to view attachmentWas going to continue taking off all of the tape but when I found a wire nut and bare wires just twisted together I just had to quit!
Completely took apart Microsquirt harness and rewiring everything! Should have the wiring button up this weekend I hope.
Betty
Sep 24 2019, 05:43 PM
Matty900
Sep 24 2019, 11:25 PM
914four
Nov 24 2019, 10:55 AM
Mike,
What's the latest with Part II? Any progress?
Kelvin
AmjadY
Mar 26 2020, 06:05 PM
So what happened??
Mblizzard
Mar 26 2020, 06:38 PM
Well after being sidelined by a long deployment to an undisclosed location I am getting it going. Finished all of the complete redo of the wiring and started it today! Oil leaks at the valve covers but other than than and resolving control of the cooling fan control moving forward. Pictures to follow.
DRPHIL914
Mar 27 2020, 06:44 AM
QUOTE(Mblizzard @ Mar 26 2020, 08:38 PM)
welcome home! so that means we might see you driving again this year?(albeit in the rear view mirrior
Root_Werks
Mar 27 2020, 08:37 AM
I've been gone so long I've been missing all these great build threads. Looks like a great combo!
ClayPerrine
Mar 27 2020, 08:42 AM
QUOTE(Root_Werks @ Mar 27 2020, 09:37 AM)
There is one nice side effect of the coronavirus... Lots of old 914World members are wandering back in here. Because of boredom or masochism or maybe something worse....
Now we just need Miles to show back up.
Welcome back. We do miss you when you aren't here.
Mblizzard
Mar 27 2020, 04:25 PM
JOEPROPER
Mar 27 2020, 07:56 PM
Ouch. That stings.
Betty
Mar 27 2020, 09:08 PM
914werke
Mar 28 2020, 12:12 AM
Man! That bites. What about going Teflon buttons instead?
Mblizzard
Mar 29 2020, 04:56 PM
Well I am one lucky SOB!
Click to view attachment Looks like #1 lost the retaining clip but no damage to the cylinder. Minor scratches in cylinder but not detectable by touch. Also found #4 clip almost out.
Replacing all clips and putting back together. Take 2!
Mar 29 2020, 06:21 PM
Mblizzard
Mar 30 2020, 10:33 AM
Well as I wait on my clips to be delivered I am getting to a few things I skipped in the rush to finish last time.
Installed the Tarrett Racing Semi-Solid trans mounts.
Root_Werks
Mar 31 2020, 08:45 AM
Talk about a dodged bullet!
Mark Henry
Mar 31 2020, 10:02 AM
QUOTE(914werke @ Mar 28 2020, 02:12 AM)
Won't work with JE's.
Mblizzard
Apr 2 2020, 08:43 PM
Ok so maybe I am paranoid but this seems like a lot of crank movement and there is a a distinct clunk of things moving. I couldn’t make the code work for embedding the video so the liknk is posted below.
https://youtu.be/OFYB_Z3A0NIThis is with the trans on did not notice this when I set the axial play but this just seems like a bad thing to have but I have no idea what is casing this.
Mblizzard
Apr 3 2020, 06:38 AM
QUOTE(Mblizzard @ Apr 2 2020, 06:43 PM)
Well hopefully I am a moron. Thought about it and this is happening with the valve train installed on one side. So of course it would move so much as it is loading only one side and the klunk is the valve springs pushing the crank forward and back.
Apr 3 2020, 06:53 AM
Take your time with this and it will all work out.
Root_Werks
Apr 3 2020, 08:58 AM
That seems like too much Thrust play? Is the flywheel back on?
Mblizzard
Apr 3 2020, 12:59 PM
QUOTE(Root_Werks @ Apr 3 2020, 06:58 AM)
All good now! With only half the valve train in it moved a lot. Adding the both sides resulted in minimal movement.
While I did not pull the flywheel it now has what seems to be normal movement. Now just gives the expected small thunk when moving back and forth.
Root_Werks
Apr 4 2020, 09:02 AM
Whew!
Driver174
Apr 4 2020, 11:23 AM
Does anyone have experience with this tool?
Apr 4 2020, 11:30 AM
QUOTE(Driver174 @ Apr 4 2020, 01:23 PM)
Click to view attachmentBest tool in the world and worth every penny.
Mblizzard
Apr 4 2020, 11:31 AM
QUOTE(Driver174 @ Apr 4 2020, 09:23 AM)
Click to view attachmentYep. They are worth every penny of the cost. I was struggling trying to install the clips and was getting really afraid of damaging some very costly pistons.
This solved the issue quickly. Now I obviously had some operator error on my install. Resolved by installing pistons and clips before the jugs and using a ring compressor that came apart and allowed the pistons to be installed in the jugs from the bottom.
I have the 22mm one.
Driver174
Apr 4 2020, 01:10 PM
I will definitely order one before assembling another engine. Those JE circlips were really tuff on my thumbs, and had to have my son help as my thumbs were too sore to install all eight clips.
Mblizzard
Apr 6 2020, 07:14 PM
Taking it slow and easy as suggested. Did a final check of the intakes before moving forward and found a washer in the #1 intake. Always make a point to vacuum and inspect intakes with bore scope before adding the intakes.
Top part of engine done.
Click to view attachmentLove how the CFR exhaust looks!
Click to view attachmentClick to view attachmentTomorrow add the Microsquirt wiring and start!
Mblizzard
Jun 17 2020, 05:05 PM
OK so long time no post.
Tomorrow enginge comes back out! I have an oil leak that I just can't trace down. Part of it is at the rear main but it is pouring out the 3 4 side. All I can think of is that I must have a leak at the cylinder case interface.
I did get in one small drive and this thing is going to be EVIL! Not a great tune in it but hit it hard from a start and smoked wheels all through first, broke wheels lose in 2nd and continued to smoke. Let off in 3rd but still smoked the tires.
Will pull it all down and reseal the cylinders and check all galley plugs and push tube seals. Had great oil pressure so don't think it is a galley plug but I am not taking chances.
New front and rear seal, new push tube seals, and seal up everything.
Mblizzard
Oct 25 2020, 03:20 PM
Well been laying low and hiding from the pandemic but do have a bit of an update.
Went through and replaced all seals including oil pump, tubes, front rear, oil filter, and new valve covers.
Fucker still leaks! Even with a bore scope I can’t see where it is leaking from. While I had it apart I did reseal some of the head bolts which seemed to slow it down some. But it is coming from the left front side from high up (yep checked the oil pressure gauge about 6 times and resealed).
I think it has to be coming from the are where the cylinders meets the block. This case was opened up for the 102s so maybe there is a flaw.
But as it is a slow drip (doesn’t seem to increase with engine speed/oil pressure) I have been able to drive it.
HOLY CRAP IS IT STRONG! Torque like I never felt in a 914 with a 4 cylinder. Rolling in second grear and you can spin the tire with a punch of the throttle. The Tangerine Racing headers and exhaust make a truly frightening noise. Obviously not too many miles on it but thought I would drive it a bit. Will take it to the dyno soon to see where it is and then start chasing the leak again.
ChrisFoley
Oct 25 2020, 04:29 PM
QUOTE(Mblizzard @ Oct 25 2020, 05:20 PM)
Correction: The headers don't make that noise, your engine does. The exhaust system just doesn't stifle the awesome sound.
RE your oil leak: Have you checked the thermostat pulley bolt?
Mblizzard
Oct 25 2020, 05:18 PM
QUOTE(ChrisFoley @ Oct 25 2020, 02:29 PM)
Other side of engine. But I did read one of your post that suggested that so I did check anyway.
Mblizzard
Oct 25 2020, 06:37 PM
Oh and by the way, I have to give Chris a shout-out for his oil cooler thermostat and cooler design. While not hot these days, this is a big engine and temps never ventured above 200 F. I have fan set at 190F so may be a bit of a delay in response but I drove it hard for a while and it was rock solid on temp. Had to take a bit of timing out to get cylinder head temps in the 250F range but cooling won’t be an issue for sure.
You can do it cheaper than CFR, but it will never be as dependable and as functional. Use Your Brain and use CFR stuff. I am a first class pain in the ass when it come to letting go of my dollars, but I have never regretted a single dollar I spent with CFR. Wish I was getting a discount for promoting CFR, but the best is worth paying for.
Betty
Oct 25 2020, 07:15 PM
Mblizzard
Oct 25 2020, 07:36 PM
QUOTE(Betty @ Oct 25 2020, 05:15 PM)
It’s on!
ClayPerrine
Oct 26 2020, 09:56 AM
QUOTE(Mblizzard @ Oct 25 2020, 08:36 PM)
It’s on!
I think I am a bit handicapped in this competition..... you don't have 245x45/16 tires on the rear.
But then again, I have 2 more cylinders and a bunch more displacement.
We need a burnout smiley....
Mblizzard
Oct 26 2020, 11:32 AM
QUOTE(ClayPerrine @ Oct 26 2020, 07:56 AM)
It’s on!
It should be about even. But if not I have a Hollywood stunt trick we can use.
Mblizzard
Nov 13 2020, 03:12 PM
Despite oil leaks,
I AM AN ENGINE BUILDING GOD!Just look at the graph!
Click to view attachment529 hp! It’s on the internet it has to be true? Right?
Well no, my tablet fell off the mount and it seems the accelerometers granted me a few extra hp.
Not sure how much I buy into the “calculated” hp, but this one seems close.
Root_Werks
Nov 13 2020, 03:25 PM
Am I reading that correct, 529hp?!?!?!?
Mblizzard
Nov 13 2020, 03:32 PM
QUOTE(Root_Werks @ Nov 13 2020, 01:25 PM)
Yes, but it was due to the tablet falling. The program uses accelerometers and gps to estimate hp. Obviously wrong.
ClayPerrine
Nov 13 2020, 03:38 PM
DAMN!! With 529.5 HP, you had me sweating for a minute!
It was that final .5 hp that had me worried.......
Betty says that if you win our shootout I have to buy your drinks for the whole Okteenerfest weekend.
As for oil leaks, I am fighting them too. Good luck!
Clay
