QUOTE(914forme @ Aug 13 2019, 05:00 AM)
You will always pay when you rush.
My suggestion if you re going to put this engine together in a weekend. Clean up while you are waiting.
Get everything you will need laid out on the table(s) all tools, all chemicals, parts everything. White board note pad what ever and build a check list. All tools and supplies applicators etc... must go back to the spot. Count your danm rags.
I use paint pens also to mark when bolts and studs have been torqued. Torque, mark, torque mark. Clean tools put them back on the table in the same spot. Count all my rags, sponges, qtips what the not.
You are an engine surgeon , you must be precise and know what, where and why.
Take the upcoming days to prep well, and you will be ready to get it done.
HAVE A FREAKING
CHECK
LIST AND USE IT!
Don't know how many times I have skipped a step and paid hard for it latter. The more I am rushed the worse it gets.
I built an engine once, got it fired up, and promptly left the oil fill cap off of it. That almost cost me a nice race engine. I was trying to get to an event the next day. Do not be like this bone head. Learn from my mistakes. All my car guy friends seem to have a similar story.
So true!
But I am going back to the beginning and cleaning everything over again between now and the weekend.
On the first go I set myself small incremental goals for each night which seemed to work well. Tonight is pull rods, timing gear, and dizzy off crank.
But I think i will write it all out just to be sure!
Went back and reordered some parts that I don't like to use over like woodruff keys. I know they are fine to reuse but...
Also going to go back through and check all of my clearances and such. That would be a good list to have for stock builds.
