76-914
Aug 29 2020, 04:25 PM
Looks like the edge of the brace won't move much further. Maybe saw cut it leaving the spot welds in place. After the gap issue is resolved go back and seam weld the brace.
dakotaewing
Aug 29 2020, 07:01 PM
When I added the Mayer kit for my car I bought a drill press and Quadrupled the number of holes for the roset welds. Consider having smaller C-clamps for the bottom crimp welds.
I have a bunch of pics on the install in my build page. And be advised that these will affect the fit of the rockers - more than a little bit...
tygaboy
Aug 29 2020, 07:42 PM
QUOTE(dakotaewing @ Aug 29 2020, 06:01 PM)
I had prepped a Mayer kit for my build and did the same thing. I ended up going a different way but did like the idea of more attachment points. Just remember that the only place the part contacts the long is on the long's raised ribs - unless you add a filler plate to close that gap.
Matty900
Aug 30 2020, 10:01 PM
QUOTE(FL 000 @ Aug 19 2020, 02:42 PM)
Been a few months since I have done much work but I have been having fun driving! A/C seems to be working well but may need a few more tweaks down the road. Went on a long road trip last month and the cab got heat soaked; AC was still blowing cold but it was getting hot inside. If anyone has any ideas I am open ears, and I am thinking a couple of things may help:
1) I need to make a panel to seal off the opening between my radiator and forward bulkhead in front of the gas tank so the hot air only escapes through the cutouts by the tires. Relying on my fiberglass hood to do that job isn't working well, especially at speed when the increased pressure is pushing the hood up.
2) Additional thermo mat in the cab couldn't hurt. I have a decent amount on the floors, the front/rear firewall, and inside the doors. I forgot to put some under the targa top.
I am starting to try and figure this out for my V8 car and I am curious about the hood and the pressure. I am thinking of having a decorative cover made for the firewall and gas tank and have some thermal protection added in it. Can you post some photos of the inside of the fiberglass hood and let me know where it is pushing up?
FL000
Aug 31 2020, 07:24 PM
QUOTE(Matty900 @ Aug 30 2020, 09:01 PM)
Sure thing
@Matty900 , I have noticed while driving around the pressure forces the air up over the bulkhead in front of the gas tank. Fiberglass never fits as well as the stock steel hood right? So I realized during reassembly after paint that the factory bulkhead seal was too tall. Nothing a little trimming couldn’t fix, but yours my fit better with that in mind.
The channel running left/right is letting air through, and more at speed.
Click to view attachment Click to view attachment My plan is to seal off this top planform area best I can, and use a thermal blanket on the front of the bulkhead and underside of cover.
Matty900
Sep 1 2020, 12:01 PM
We got the 1st set of Carbon fiber parts done but realized that I need to get the GT hood pins. We are working on the balsa wood reinforcement that will go on these. The weight savings is drastic but don't think that I really need that with 400+ hp.
FL000
Sep 6 2020, 01:21 PM
QUOTE(Matty900 @ Sep 1 2020, 11:01 AM)
Wow that sure looks nice. Would have to seriously consider leaving the underside as is it I had one of those.
FL000
Sep 6 2020, 01:39 PM
I signed up for the WCR in Nov so time to get some work done. I used my stud welder to try and pull the rear jack support piece back straight. Got it closer but ended up over pulling in a few areas that created raised dimples.
Click to view attachment Ended up removing it to hammer and dolly it. Didn’t take as long as I thought it would to remove. On a side note I was surprised how easy it was to straighten a number of areas on the floor pan using a hammer inside the car. I didn’t pay much attention to the underside when I went through the car the first time, but when I am done with this I think it will look pretty straight. A little surface rust underneath but nothing too bad.
Click to view attachment I know many of you can walk circles around me with metal work, but I think these turned out well given my skill level for a couple hours work. Here are some before and afters.
Click to view attachment Click to view attachment Click to view attachment Should I fill in with any other of those holes I drilled or just reuse them all for plug welds when reattaching?
FL000
Sep 6 2020, 01:55 PM
Next up got the car on supports to adjust the door gaps for the long kit. A bit scary having it resting in a couple pieces of lumber and jack stands, but I have other platforms under each wheel in case she decides to fall. I think I’ll limit the time my skull is under the car too.
Click to view attachment Click to view attachment Here are my driver and passenger side door gaps as resting on the supports without anything else supporting the rear:
Click to view attachment Click to view attachment Click to view attachment Click to view attachment I’m pretty happy with the passenger door gap as shown here. Driver side will need to be closed up a bit. Calling on
@914forme and others - my plan is to weld the passenger side long kit in first since the gap is good, then use a jack under the trans to lift and close the driver side door gap to the right amount before welding in the driver side. My assumption is the passenger side won’t move while doing this. Good assumption or no? I would like to do this with the doors attached so no easy way I am aware of to set both driver/passenger gaps before welding.
76-914
Sep 6 2020, 02:21 PM
Insert some wood shims from inside between the door jamb and door?
914forme
Sep 6 2020, 05:57 PM
You will always get a bit of shrinkage when you weld, the key is controlling it.
Once you get the passenger side set, then it would be fine to jack up the back and put it close to where you want it.
I would also investigate and look at your door opening and door lengths. And check the pins for wear would also be a good idea.
You can use a rod end at the upper seatbelt, to the lower front. Please please please if you goto the store and pickup a turn buckle make sure it is big, the bigger the better, and it is forged. Cheap ones will blow up, and if it doesn't your very lucky. If it Dows, metal bits go flying about your garage, getting stuck in various items hopefully not you.
But if you want to try closing up the gap, just lower it down on its rear wheels, you gap will close right up, then pick it up in the middle right at the jamb. and fine tune your gap.
Hopefully it is you pins are worn, easy enough fix, and you can get on with it.
Have fun playing with molten metal, I know I always do.
FL000
Sep 16 2020, 07:37 PM
Well that sucks. Got passenger long reinforcement welded in with gap set as desired and this was the result with weight on wheels. Not sure how evident it is from picture, but gap closed up quite a bit. No more rubbing so I guess that is good.
Door is functional so going to put problem to back burner again. Short of a frame bench I think a roll cage may be my only at home solution at this point. Don’t really want a roll cage so need to ponder on it for awhile.
The longs do the majority of the work keeping the door gap set, so I wonder if my flex is happening in the metal above it, with the shock being the lever to bend it all forward.
914forme
Sep 17 2020, 08:39 PM
One other way is open it up, and add a metal roof and make it a coupe.
Theater solution is the 914LTD kit.
But I am thinking you might want to take a closer look at your logs.
FL000
Oct 11 2020, 09:05 AM
I see a couple threads on brake related items so this is fitting. I have been busy the last few weeks (more to come on progress) but need to fast forward to last night.
Bleeding my brakes with my Motive pressure bleeder as I have done numerous times before. I am at the right rear wheel and hear what sounds like a sprinkler...in my garage.
Stand up and go to front of car and there is a heavy stream of brake fluid, more like a gusher, shooting up at underside of the hood and coming down all over the front of the car
We all know brake fluid and paint don’t match right? Long story short I cleaned up what I could, rinsed with a bunch of water, followed by dish soap and then another rinse. I didn’t see any paint residue while cleaning so may have gotten lucky.
Oh yeah the culprit was the hose that connects to the bleeder tank ruptured. I know things can fail but not sure if I will be using it again any time soon.
Oct 11 2020, 09:20 AM
FL000
Oct 11 2020, 11:42 AM
So going back a few weeks I finished up my 914LTD install. The driver side went on pretty smooth with my lessons learned from the passenger side. Also I wasn't fighting a bent long and a bunch of preload (best I can assume) so it was really just getting it set in place.
Here are some pics fro the passenger side and notes about the install.
Click to view attachment Click to view attachment I added a few extra holes for each rib, and in hindsight, the lower ones shown were too low and didn't make good contact with the long. After tacking the two pieces together I removed it through the rear wheel well to finish welding them together on the ground; with the Sheridan kit I couldn't do it on the car.
FL000
Oct 11 2020, 11:51 AM
Some finish work on the welds, liberal use of seam sealer, and paint to call it good.
FL000
Oct 11 2020, 12:01 PM
I noticed my rear trailing arm bushings were not in good shape and preventing the arm from moving freely. Figured it was a good time to install an Elephant Racing polybronze set. Fairly straight forward install and amazing how easy yet precise the arm moves now. Forgot to take pics of this one.
Years ago when I installed my coil overs I cheaped out on the helper springs and used some wire to keep the spring attached to the top hat. Every time you lift the car the lower part of the springs rise out of their seat and need to find their way back in when lowered. As you can see from the picture it can give your threaded sleeve a beating. I know others have done this successfully so to each their own. I added the helpers since I was already in there.
Click to view attachmentClick to view attachment
FL000
Oct 11 2020, 12:13 PM
Next I moved onto the fun stuff I have been looking forward to for a while. I acquired a set of Boxster S calipers, rotors, and adapters recently (hat tip to Stephen
@914forme ) and figured with the trailing arms off I was already halfway there.
If you are this far into my thread you clearly know I don't mind deviating from the beaten path and open to trying a different approach. I really want to have a parking brake when this is done, but wasn't having great luck finding the 911 parts. I decided to go with the Wilwood MC-4 style parking brake. I knew it would require some fabrication and a different cable to make it work.
Click to view attachment Click to view attachment Click to view attachment These pics were during the mockup but you can see where I am trying to go with it.
FL000
Oct 11 2020, 12:28 PM
Got to love these comparison pics. I know there are more variables than just the physical size of the calipers/rotors, but looks cool.
Click to view attachment Click to view attachment Click to view attachment Click to view attachment My wife helped me bleed them the old school way and after 2 trips around the car I think I have good enough pedal feel for a road test. Need to do a couple other minor things first so maybe tomorrow or later in the week.
I'll consider realigning the rear trailing arms after that. I also need to figure out the parking brake actuation piece. I thought I could have some custom cables made but running into some challenges there. Maybe a good opportunity to install some linear actuators but that may take more time than I have right now (WCR right around the corner).
FL000
Oct 18 2020, 07:17 PM
Wow, loving the big brakes. Haven’t done a full on panic stop yet but all indications say way more braking capacity available than my previous setup. I did the PMB recommended bedding-in procedure and putting some miles on it to build confidence.
Also changed my little plastic do-dad in the passenger door exterior handle and that door opens fairly easily now. May still address the door gap down the road but satisfied with functionality for now.
Went full circle on the parking brake cables and turns out Wilwood makes a universal kit for their caliper - go figure
I now have functional parking brakes again and here is the setup under the car:
FL000
Oct 18 2020, 07:29 PM
Inside the cabin I started by removing the metal guide plate. Still a mystery to me in identifying where all the spot welds are
Click to view attachment I didn’t want to prep and spray paint in this area, so I put down some Ospho to at least coat it and hopefully ward off any future rust.
Click to view attachment Ran the steel cables through the factory pipes and this is the (almost) final setup. You’ll note the angle of the wires to the handle is a bit extreme. I think I will go back in and use part of the guide plate I removed to help correct the angle and put less stress on the handle. Another day
76-914
Oct 19 2020, 10:01 AM
Looks good. With the weight of the V8 you needed some larger brakes.
FL000
Nov 8 2020, 03:24 PM
I felt like my car was dialed in before heading out for WCR on Thursday morning. Even went so far as to jinx myself on that thread
Met the So Cal crew in Gorman and headed out. On the way to our first stop at Harris Ranch I started to notice valve chatter. Checked my oil while there and was barely registering on the dipstick. Threw a quart in (thanks
@coondog , I still owe you so pm me a shipping address or let me know next time you are in my area) and hit the road.
Click to view attachment Next stop 120 miles or so up the road and a couple quarts lower, smell of oil while driving, and visible oil coming from right front top side of engine. Still running ok so decided to press ahead. Rolled into Petaluma with engine running poorly and minor backfires.
Enjoyed the evening with the group and made the decision right before the 0900 meetup on Friday that we could probably nurse it home if we left then. Took it easy and made the 400 miles back somehow. 800 miles round trip in 2 days and added about 8 quarts of oil along the way to make it happen.
FL000
Nov 8 2020, 03:40 PM
Decided I was going to do the Audi 01E install after WCR so now I need to throw some engine work in too. Probably won’t completely change gears at this point (so to speak) but it is a good opportunity to do some more with the motor at the same time.
Guesses on what happened before I tear into her? Symptoms that I know of:
-Oil leaking about a quart per 100 miles as described in previous post
-Engine running rough, underpowered, and backfire on right exhaust side
-when hard on or off accelerator oil spraying out and making it out engine lid and then to rear trunk
-does not appear to be coming out of passenger side breather although in the same vicinity.
-Radiator fluid no longer pure antifreeze color, looks dirty, but not leaking and not overheating
Mueller
Nov 8 2020, 03:44 PM
I parked next to you at the hotel (beat up light ivory 914) and was looking forward to checking out your car. Glad you made it back home.
I have the same parking brakes, however they are still in the box so I am without functioning parking brakes right now....hopefully for not too long.
Nice 914 build for sure.
FL000
Nov 8 2020, 03:56 PM
QUOTE(Mueller @ Nov 8 2020, 02:44 PM)
Too bad we didn’t get a chance to meet up. If you want more info on what I did for my parking brake setup just let me know.
76-914
Nov 8 2020, 06:26 PM
QUOTE(FL 000 @ Nov 8 2020, 01:24 PM)
Even went so far as to jinx myself on that thread Met the So Cal crew in Gorman and headed out. On the way to our first stop at Harris Ranch I started to notice valve chatter. Checked my oil while there and was barely registering on the dipstick. Threw a quart in (thanks
Never fails.
FL000
Nov 14 2020, 02:37 PM
Alright here’s the next clue from the first peak inside the engine. These are “new” and have about 1000 miles on them.
Click to view attachment Bottom left on pic is front driver side for reference. The rest are in order.
bkrantz
Nov 14 2020, 08:32 PM
QUOTE(FL 000 @ Sep 16 2020, 06:37 PM)
How is the front gap? It is possible to shift the door forward slightly, with a bit of persuasion of the B-pillar hinge mount spots (with a block and hammer and feeling brave).
76-914
Nov 15 2020, 10:06 AM
Damn. So many possibilities. Where is the origin of the oil leak? So many fouled plugs, too! Have you done a leak down test yet? Sounds like a head gasket leak between the water & oil passages but not between the cylinders. The odd thing is fouled plugs on both sides. 0 chance of blowing head gasket on both sides or cracked heads on both sides unless it overheated but you'd have noticed that. Looking forward to seeing what you find when you tear it down.
FL000
Nov 15 2020, 05:32 PM
QUOTE(bkrantz @ Nov 14 2020, 06:32 PM)
I have always been one of those guys that over tightens, over bends, etc so to be honest I am afraid to try to push too much on the hinge side
With that said I have done some of that with a hydraulic ram and some lifting on the door but the front gap is pretty good so figured I would leave it alone...at least for now!
FL000
Nov 15 2020, 05:38 PM
QUOTE(76-914 @ Nov 15 2020, 08:06 AM)
No leak down test yet but may once I get the engine and trans removed. I did a compression test before WCR and all were in the 150 psi area. Guessing that isn’t the case now
Here is the oil and coolant; kind of hard to tell which is which right?! The coolant was a nice green last I checked.
Chris914n6
Nov 16 2020, 01:38 PM
Your bulkhead seal is missing the flap that the factory seal has that actually contacts the trunk lid. It should help greatly with the blow by issue.
76-914
Nov 16 2020, 10:39 PM
QUOTE(FL 000 @ Nov 15 2020, 03:38 PM)
Click to view attachment Click to view attachmentThe top pic is from the radiator and the lower from the oil pan?
Rider914
Nov 17 2020, 02:52 PM
Wow - Did you cross your oil cooler and water coolant return lines? Sorry, wish it was that simple... Good luck
djway
Nov 17 2020, 03:17 PM
Head gasket?
FL000
Jan 8 2021, 08:03 PM
QUOTE(Chris914n6 @ Nov 16 2020, 11:38 AM)
Yeah another lesson learned for me. When I did all the bodywork for the fiberglass hood and fenders I did many fit checks, but none with the seal on. After paint when reassembling the hood with the seal on, it pushed the hood up enough to make the lines unacceptable. Trimming it down solved the problem. May go back and do a better job making sure the seal fully contacts the hood.
FL000
Jan 8 2021, 08:05 PM
QUOTE(76-914 @ Nov 16 2020, 08:39 PM)
That’s funny, actually the top pic is from oil pan and bottom is the coolant. It was a mess.
FL000
Jan 8 2021, 08:11 PM
Alright it turns out the heads were jacked up. Took it to my local machine shop and they went through them both. The said tons of carbon deposits on the intake valves. All the valves and guides checked good, so they basically just gave it a valve job and replaced the seals. I wouldn’t have thought valve seals alone could cause the oil consumption I was seeing, but I have a lot of confidence in the shop so assuming they are good now.
Click to view attachment Sure look nice all cleaned up.
FL000
Jan 8 2021, 08:18 PM
So put my heads on tonight and adjusting the valves and this happens
Click to view attachment Yeah, rotating crank and engine literally falls off the stand without warning. Luckily didn’t land on me or my feet. Base of stand took initial impact and then it fell final few inches to the ground. Scary.
Click to view attachment Click to view attachment Too upset to assess damage tonight so will get it in the air tomorrow. Just curious if this has happened to anyone else before?
rhodyguy
Jan 8 2021, 09:13 PM
WOW! That could have been a life changing event. Sorry for the hassle. It'll work out.
djway
Jan 8 2021, 09:28 PM
Holy Crap.
What brand is that stand?
Glad you still have both legs.
FL000
Jan 9 2021, 10:14 AM
QUOTE(djway @ Jan 8 2021, 07:28 PM)
Holy Crap.
Harbor freight 1/2 Ton. Lightly used and never abused. Might be overkill but I think I will always use my crane as a backup from now on.
808 WRX
Jan 9 2021, 10:48 AM
Glad your feet are ok! Hope the motor is ok too.
Was it pressed on? Or is that a little ring of broken weld?
Either way, I'm gunna have to check out my engine stand and make sure its welded all around, both sides!
76-914
Jan 9 2021, 10:24 PM
Aww Man. Sorry dude. I've got one of those but never put anything more than an aluminum 6 on it. It seemed it was at it's limits with the 6 on it, though. Hang tough.
cali914
Jan 10 2021, 01:29 AM
You are lucky from the head situation and the accident. Get a edelbrock programmable fuel injection kit and you will be so happy.
Andyrew
Jan 10 2021, 01:33 AM
Wow that is nuts with the engine stand! I have the same one. Looks like a failed weld or no welding at all... Makes we want to check mine...
Hopefully the damages are just the oil pan??
I had my first v8 engine fall over on me. But I still had a tire attached to it from when we grabbed it from a pick n pull....
djway
Jan 10 2021, 01:39 AM
QUOTE(FL 000 @ Jan 9 2021, 08:14 AM)
Holy Crap.
I can’t even see a weld...
FL000
Jan 10 2021, 10:53 AM
A couple more pics that may help some of you with a better eye than me. With the material still showing in the top one it does look like it was welded and broke there.
Click to view attachment Click to view attachment And now here is my current setup. A little more difficult to work on it and flip over but not that big of a deal.
