So, after taking a break from the car during the hot humid summer, I am back at it. As previously stated, I was having an issue of no power to the fuel pump when I turned the key. After replacing the relay board still no go, so I swapped out the ECU with an extra I had and this did the trick
So now that I had power to the pump, it was time to put gas in the tank. I checked for leaks and found none, so it was time to light the fire. First I disconnected the coil wire and cranked it several times to get the oil moving. Then I hooked it up and tried to start and nothing.
I started checking to see if I had fuel to the pump, and there was not. I had a hell of a time getting the air out of the system, but after a fuel bath I was able to finally get fuel up to the injector rail. Once I had fuel to the engine she fired off immediately
She ran pretty good for just having the timing close, and also idled nicely.
So after tying up some loose ends, I was ready take my first drive ever in this car.
The car was still without doors, rear trunk lid, engine lid, and the windshield. The purpose of this drive was to make sure I had a working transmission, I was not disappointed, it seem to shift smoothly into all the gears. Big relief! I did not want to install all the other pieces on the car until I knew the trans was going to work in case I had to drop the engine and trans. Less chance of getting dings or scratches if they stay stashed away under heavy padding.
So now that the drive train appears good, I am starting the install of the remaining pieces. The rear trunk lid was first. After bolting it on, I slowly lowered the lid to check alignment and latch engagement. It all looked pretty close with a small adjustment needed. When I went to push the release button, nothing happened, so I figured it was in the locked position, but after switching the position with the key, nothing. I must have put the latch together improperly
Now my lid is shut and I cannot see how to get it open, what are my options? Help
Click to view attachmentClick to view attachment
