Like the screw as a handle. Still had to have been fun trying to place tacks in that tight space!
Nope, not much fun at all. My legs and neck were very sore and stiff after that was all done, just from the contortions needed to make the welds. But, I was trying hard to keep the holes as small as possible.
Maybe shoot some Eastwood Internal frame coating or something similar into that outer reinfocement to lock down the rust progression while access is easy?
It wasn't shown, but I've been spraying rust-converter paint inside each layer right before I seal them up. I do have the Eastwood Internal Frame coating, which will be applied inside the heat tube and inside the longitudinal through the factory access holes inside the passenger compartment.
Photo's like this always make me laugh. No such thing as rust free 914's. You just can't see it . . . . yet. It's always lurking inside these sorts of cavities.
Someone here quipped a while ago that "rust free 914" just means the seller isn't charging for the rust. ( )
