KBMC1304
May 11 2021, 05:10 PM
QUOTE(rgalla9146 @ May 10 2021, 06:11 PM)
Is it just me or do those floors look a bit unusual ?
This is the first time that I restore a 914.
I don't know if the floor is unusual.
it seems that it fits well.
rgalla9146
May 11 2021, 06:43 PM
Looks right now.
The other picture was from an odd angle I guess.
You do fast work.
KBMC1304
May 18 2021, 06:40 AM
preparing and stabilizing the the rear floor
Root_Werks
May 18 2021, 08:38 AM
40% new 914! It's a lot of work, but it's already paying off. Looking good!
wonkipop
May 19 2021, 03:42 AM
farken hell.
my hats off. thats a shit load of rust.
i don't think that car spent its entire life in a french colonial outpost in africa?
its full of dirty french salt euro corrosion?
but you know, our american friends just rip into it with their rusted out east coast "barn finds". aussies would pooh their pants confronted with that.
love the way you are just going for it. its going to work or it won't.
good luck and what a car you will have if you can keep it all straight and aligned after you tear its guts out. i am sure you can do it. i mean that. i want you to pull it off.
KBMC1304
May 20 2021, 12:39 PM
QUOTE(wonkipop @ May 19 2021, 03:42 AM)
farken hell.
thank You Wonkipop.
I found the car in the north of Algeria unfortunately the humidity is too high.
it had 2 owners. the second one has not used it for more than 20 years.
KBMC1304
May 20 2021, 01:07 PM
KBMC1304
May 20 2021, 01:09 PM
jcambo7
May 20 2021, 02:13 PM
With no door bracing from what I can see, what are you doing to prevent twisting while welding?
May 20 2021, 02:22 PM
QUOTE(jcambo7 @ May 20 2021, 01:13 PM)
May 20 2021, 02:25 PM
wonkipop
May 20 2021, 05:01 PM
QUOTE(SirAndy @ May 20 2021, 02:25 PM)
if there was one of those in aus we'd use it too.
with a heap of steel bracing.
and one panel at a time if possible.
very interesting to see on this site discussion and photos of that bench.
valuable resource to have and for it to still be around.
KBMC1304
May 23 2021, 05:33 PM
QUOTE(jcambo7 @ May 20 2021, 02:13 PM)
thank you for your advice.
I will do it.
for the moment I'm cleaning the floor from the rust
KBMC1304
thank you
KBMC1304
May 23 2021, 05:36 PM
KBMC1304
May 23 2021, 05:39 PM
I would like to know what is the best alternative to restore my 914/6 and increase its selling value.
Keep engine stock or performance rebuild?
gereed75
May 24 2021, 05:36 AM
Khaled, Not sure what the attitude is in your part of the world but since you do not have the original motor anyway, I would think a 2.2 or 2.4 carbureted S motor would be an “attractive” choice.
What motor came in most ‘72 sixes from the factory?
rgalla9146
May 24 2021, 05:47 AM
QUOTE(KBMC1304 @ May 23 2021, 07:39 PM)
Given the extensive metalwork that your car has needed and the approach you've
taken you should feel free to go with a higher performance engine.
Without the original engine you have good reason to do as you like.
Cairo94507
May 24 2021, 07:10 AM
Since your original 2.0 911 T motor is gone (sadly) the replacement depends upon what your finances can handle. I think any of the 911 motors are terrific in these cars. Of course a bit of horsepower/torque in a 914 is always fun.
KBMC1304
May 24 2021, 07:43 AM
I found the original engine 901/38 642...
. that is why I asked you if a keep it stock or performance
Root_Werks
May 24 2021, 08:43 AM
Number matched cars always fetch more money. If you put a different engine in the car, keep the original engine to sell with the car.
rgalla9146
May 24 2021, 09:07 AM
QUOTE(KBMC1304 @ May 24 2021, 09:43 AM)
Please tell how you connected with the original engine.
Was it in Algeria ?
As for stock or modified I'd correct the known faults of that era engine and modify it
without changing the block beyond return to stock.
Build a 2.0S or a 2.2 S
KBMC1304
May 24 2021, 02:40 PM
QUOTE(rgalla9146 @ May 24 2021, 09:07 AM)
Was it in Algeria ?
I asked the former owner where the engine was exchanged. luckily the mechanic is still there. Then the engine was sold in France and since it stayed with the same owner.
I asked Mittlemotor for an upgrade, they told me its possible to increase it power to 200/220 HP
KBMC1304
May 25 2021, 11:32 AM
KBMC1304
May 25 2021, 11:33 AM
KBMC1304
May 27 2021, 03:19 PM
KBMC1304
May 27 2021, 03:45 PM
does anyone know the rubbers references?
rgalla9146
May 27 2021, 03:55 PM
The blue circled hole is not original. The green circled hole is for the fuel pump wire.
Don't loose the two hole plugs they're hard to find.
The single fuel supply hose for a 6 goes through the open oval hole with a black tubing grommet.
Root_Werks
May 27 2021, 05:27 PM
Red circle = factory plugged rain tray drain? On a 1972 914-6 maybe they left them stamped, then plugged them?
rgalla9146
May 28 2021, 05:52 AM
QUOTE(Root_Werks @ May 27 2021, 07:27 PM)
They were plugged on all 6s....no rain tray
Only one fuel delivery on a 6, other oval hole plugged in engine tray
The oval nylon plug is a tough one to find.
KBMC1304
May 30 2021, 02:13 PM
KBMC1304
May 30 2021, 02:15 PM
KBMC1304
KBMC1304
Jun 2 2021, 01:04 PM
ClayPerrine
Jun 2 2021, 01:34 PM
QUOTE(rgalla9146 @ May 28 2021, 06:52 AM)
The sixes had the holes stamped for the rain tray drains, and they had a plastic plug in them from the factory.
Clay
KBMC1304
Jun 3 2021, 02:51 AM
tazz9924
Jun 3 2021, 03:32 AM
what are you using to take the paint off? seems to be doing a good job
rgalla9146
Jun 3 2021, 06:11 AM
Your car has some features that are not found on '70-'71 year 914 6s
The recoil seat belt mounts and later jack mount seem odd at first but are found on
all 1972 model year 914s
Did it have two movable seats ?
Root_Werks
Jun 3 2021, 09:46 AM
Love this thread, so much new metal going into this 914-6.
Question: You using a flux core welder? Seems like a lot of slag being tossed around.
KBMC1304
Jun 3 2021, 04:43 PM
QUOTE(Root_Werks @ Jun 3 2021, 09:46 AM)
thank you.
im using MIG
TRIMIG 250-4S DV
KBMC1304
Jun 3 2021, 04:44 PM
QUOTE(rgalla9146 @ Jun 3 2021, 06:11 AM)
exactly
KBMC1304
Jun 3 2021, 04:48 PM
QUOTE(tazz9924 @ Jun 3 2021, 03:32 AM)
I'm using Fidea 1052 stripper.
Root_Werks
Jun 4 2021, 03:11 PM
QUOTE(KBMC1304 @ Jun 3 2021, 03:43 PM)
thank you.
im using MIG
TRIMIG 250-4S DV
Looked up the welder, looks like a nice unit!
This project is inspiring, my 914 needed....well, still needs some welding. Nothing this extensive!
windforfun
Jun 4 2021, 04:46 PM
Je pense que vous être très magnifique. C'est incroyable!
Can you tell that I haven't used my French since high school? That was about 48 years ago.
Best of luck to you & your project.
KBMC1304
Jun 4 2021, 06:41 PM
QUOTE(windforfun @ Jun 4 2021, 04:46 PM)
Thank you
you are doing very well
KBMC1304
Jun 4 2021, 06:43 PM
QUOTE(Root_Werks @ Jun 4 2021, 03:11 PM)
thank you.
im using MIG
TRIMIG 250-4S DV
I encourage you! go for it!
KBMC1304
Jun 4 2021, 06:45 PM
bretth
Jun 4 2021, 11:00 PM
QUOTE(Root_Werks @ Jun 3 2021, 10:46 AM)
I am going to guess it is the weld through primer?
Wish I could work this fast a pace on my cars. Looking good.
Jun 5 2021, 09:52 AM
QUOTE(rgalla9146 @ Jun 3 2021, 05:11 AM)
@rgalla9146 That matches the fact that it is a '72 /6
KBMC1304
Jun 13 2021, 04:16 PM
