QUOTE(rfinegan @ Sep 1 2023, 12:12 PM)
My first log....The last downward slope is the mains coming in at 35- 4500 rpm and look good at 13.2:1 and richening slightly (1.30)
I think I see the lean pop pop pop at 2-5 sec. (55 idle jets)
Here is an odd observation
While warming up the first light throttle up into the transitions feels smooth and no pops. try it again in a few seconds or another gear and is lean
Some times the ratios feel look good some times they are lean
I am going to have a helper watch my fuel pressure gauge on some next recordings
I did read somewhere that the fuel enricher (choke) gave some users problems rich or lean (not sure) that are not hooked up but the valves are in place.. I have seen dummy valves tap took off the ports (X4) with no holes.. 15-17 bucks each
I have richened the mains to overlap over the transition circuit and felt a little sluggish rich but not great numbers on the mains and WOT. But no lean hole or pop pop pop. I feel I’m on track with the correct 130 to 135 mains and richening the ideas to .57.
.60 Idle jet was very rich and 55 too lean
Fun to see how thy work
MORE LOGGING FUN TO COME
FIRST imported graph after a little smoothing
My RPM was off but working so I need to rewire my adapter on the 3.5 mm audio jack
Click to view attachmentIs the left margin AFR?
If so most of that graph looks dangerously lean IMO. Anything over 16 is "lean burn" In my book and above 20 should be avoided at all costs on everything.
18:1 appears to be the limit on a water-pumper set up for lean burn on gasoline.
During acceleration I want to be as lean as cylinder head temps can take it but below 13.5. Maybe richer on an air-cooled.
Only way to consistently run above 15:1 on gasoline is to have an engine designed for lean burn and a seriously active self-adjusting FI system with knock sensors.
Modern OBD2 systems work fine with lean burn but I'm not aware of a lean burn set up on an air-cooled motor.
Maybe the very last air-cooled 911s had it. They also had twin plugs and a bunch of modern technology that the T4 did not.
I would expect that would run HOT and tend to detonate. It would be very sensitive to timing adjustments.
The number on the right margin for AFR is what I believe the average for the graph and shows 17.83.
IMO, long term those AFR readings are the DEATH of new motor.
If that left margin is not AFR then the above may not apply.
I'd also check and re-calibrate the wideband as your plug does NOT look 17.8/1.
Plug looks great, maybe a tiny bit rich, IMO.
An 18:1 plug would look "glowing" white and have little white deposits on the ground strap.
Edit: Can someone tell me why the image didn't post over with the quote. I wish it had as it makes more sense if the image was with the quote.
