I bring this up as it seem to be a lot of talk up changing the idle jet sizes...Driving on the idle jets circuit will give a better idea if you rich or lean and can tune that first before moving to the transition circuit, main jets and accelerator pump. The AFM will be best but reading the plugs will get you there too, one step at a time.
General rule here for the mixture screws: Plates below transition holes
1/2 turn from closed or less = jet too big
1/2 to 1 1/2 from closed = jets ok
1 1/2 or more from closed = jets too small
You can have slight variations between mixture screes but they should be close each other
Jets size will be tuned when you get to the transition tuning stage. (step 5)below
Syncing the idle is EZ, as you have a throttle plate screw on each side. The final speed can be adjusted with air bleeds and timing if needed.
You can follow along as there are a few write up on this :
Example:
https://www.aircooled.net/how-to-use-a-wide...-flat-4-engine/snippet :
The carburetion adjustment is carried out as follows:
1. Adjust the position of idle throttle just below the machined progress holes in the body (using a vacuum hose).
2. Synchronize the second carburetor.
3. Adjusting the idle speed with the idle screws to a value at the bottom of the 14 / 14.7: 1 range a little richer than the stoichiometric point for good idle stability. The idle speed should be around 800 RPM.
4. Adjust the idle speed to the desired value by adjusting the idle by-pass screws, or by increasing the idling advance value, check that the maximum advance does not exceed 28 / 30 ° before TDC.
5. Idle jet selection, main nozzle assemblies / emulsion tubes / air nozzles removed. We aim for an AFR of 16/17 in order to obtain a low consumption in cruising. Re-adjust the idle speed at each idle jet change.
6. Selection of the air nozzle, main jet assemblies / emulsion tubes / return air nozzles, with oversized main nozzles. The hole between the progression circuit and the main circuit must disappear by gradually increasing the size of the air nozzle.
7. Select the size of the main jet by accelerating at full load, aiming at an AFR of between 12.5: 1 and 13: 1, ideally 12.75: 1.
8. Reassemble the pump stem nuts and screw them in until the slightest hesitation during a very sudden acceleration disappears completely.
9. ENJOY YOUR “NEW” TOY!
QUOTE(malcolm2 @ May 22 2023, 02:15 PM)
QUOTE(rfinegan @ May 22 2023, 08:58 AM)
Did you try to pull the main stack, and drive around on the idle jets? Conservative Throttle/driving should not need an accelerator pump.
Did you check the sync of the carbs at 1500 rpm or 3000 rpm?
Have not done that yet.... set-up wise, what is removing the jets gonna tell me. I understand that it will give me a FEEL for where the MAINS kick in, but what else can I learn there??
I did CHECK the flow on the carbs at 1800 rpm. But I only checked it, did not adjust anything at 1800rpms
Drivers side was 11 on the front barrel and 12 on the rear.
Pass side was 10 on the front and 10 on the rear.So is it recommended to re-sync at that RPM? Kinda go back and forth from 900-ish to 1800-ish adjusting so all 4 barrels are flowing evenly at both RPMs??
