The collective experience we have all had is that new carbs are not always setup properly and you can get two carbs that are different.
cgnj
Apr 30 2023, 05:30 PM
Based on video at idle you have at least one dead hole Look how much it is rocking. Carb on 2-3 bank has pump jet circuit problem. Should look like #4
Can this car idle without blipping the throttle? If it can pull the plug wires off one at a time. Idle speed drops = good hole Move to next one. Check all of them.
malcolm2
Apr 30 2023, 06:35 PM
QUOTE(r_towle @ Apr 30 2023, 06:05 PM)
In theory you are right. The proper specification is 10mm, but you can set it as you choose.
I would suggest you verify the needle valve is seating properly with no dirt or obstruction then you are done with this step.
Remove and verify your jets are correct, and properly seated. Then move to validate your accel pump, gaskets, settings etc. The pump needs to be right
I removed the floats and dropped the needle valves, I see no dirt in the needle valves. Jets have all been removed and verified with the spec sheet.
I did remove the pump cover and checked under the pump. Springs are there. It seems to activate the jets nicely on the bench.
Someone mentioned the pump adjustment is set with the threaded rod and nut, but Number of threads??? Is that the check? how many?
While on the bench, I loaded the bowls with carb cleaner and activated the throttle. The pump jets were straight and true, I saw no leakage.
Superhawk996
Apr 30 2023, 06:36 PM
QUOTE(malcolm2 @ Apr 30 2023, 05:40 PM)
The floats on both carbs are 12mm. Post #11 has the spec sheet that ACN gave me with my carbs.
12mm from the plate to the top of the float would result in LESS fuel in the bowl than if they were set at 10mm from the float to the plate, correct?
It seems that my situation is, or might be OVER FUELING. So the bowls are LESS full per the float at 12 vs 10mm, correct?
Don’t get hell bent on the exact number - people have their own preferences.
What you want to know is where is it at and is it in the ball park within a couple mm - your answer to that is yes - OK
The reason you want a baseline. Higher fuel level in the bowl from your baseline = runs richer. Lower fuel level in the bowl runs leaner.
malcolm2
Apr 30 2023, 06:43 PM
QUOTE(r_towle @ Apr 30 2023, 06:06 PM)
That is why I paid extra for the "set-up" from Air Cooled.net. So going thru this exercise has confirmed that they did what they said they would do.
Superhawk996
Apr 30 2023, 06:55 PM
I should have mentioned 10mm correlates to a higher fuel level in the bowl as you correctly inferred.
FWIW - 10mm seems too high to me. CB Performance IDF guide suggests 14mm. That seems low but again it’s all relative to what your engine wants.
You need to figure out why your plugs are black.
I’m guessing . . . but assuming . . . you don’t have idle mixture screws and throttle plate position set properly as you’re trying to tune idle. If your idle speed screw is holding the throttle blade above the 1st transition port, you’re going to pull in too much fuel at idle and lose throttle response.
Once you get closer to an ideal tune, then float level can be used to tweak slightly richer / leaner but at this point - let it go. You’re close enough.
Superhawk996
Apr 30 2023, 07:02 PM
Since you were looking for a book and the Tomlinson books aren’t readily available - I highly recommend reading this - the Weber tuning manual that was put out by Weber.
This doesn’t have the IDFs but the way the idle circuits woek and the transition from idle to mains is the same. Pay special attention to the diagram on page 10.
So you know that isn’t the problem - go back to the tuning basics - best idle, balance airflow, sync carbs. Don’t mess with the accelerator pump linkage - if you’re spraying a steady stream on the bench - it’s OK and the issue is elsewhere.
Although I didn’t pick it up in the video - take the prior suggestion to heart that Member CGNJ mentioned. Make sure you’re running on all 4 cyclinders. That is assumed before any attempt to tune
930cabman
May 1 2023, 10:35 AM
I run 12+mm on my 40IDF Weber floats. I prefer to have the fuel level a bit lower as opposed to higher. Is your fuel pressure in the 1 - 3 psi range? I run around 1.5 and seems to work just fine.
malcolm2
May 1 2023, 12:13 PM
QUOTE(930cabman @ May 1 2023, 11:35 AM)
That is my next recommendation.... As I started doing test drives around the hood, it was suggested to run at 3.5 psi.
Recently, it was recommended to drop to 2.5, so once I get the carbs back on and the idle adjusted and sync'd, I will drop the pressure.
Whole thing started when I noticed the pressure was 1.5 not sure what happened with that, but since then, I have made enough changes to pretty much start from scratch.
So here I go...
930cabman
May 1 2023, 01:37 PM
QUOTE(malcolm2 @ May 1 2023, 12:13 PM)
So here I go...
For me 1.5 works great (on the street), a track machine might be different and I have never ran the float bowls empty with 1.5 psi. Staying on the low side makes sense for me.
porschetub
May 1 2023, 11:34 PM
QUOTE(930cabman @ May 2 2023, 08:37 AM)
So here I go...
Not really sure about that ,1.5psi is very low,specs are around are 2.5-3.0 normally for your carbs. Are you running a quality fuel specific gauge rated to just above your pump output ? ,I have found if you run a say a 10 or 15 psi gauge for a max fuel pressure of 3.5 psi the gauge may be off due to the range of the gauge. I suggest you check your gauge,cheers.
malcolm2
May 3 2023, 07:48 AM
Found some time last nite and I re-assembled the carbs and set the screws as recommended in the Weber set up document. One thing I did notice is that the AIR BLEED SCREWS, marked red below, were NOT SEATED.
They were 2 maybe 3 turns OUT. all 4 were that way. I don't remember doing that, but I am sure I did.
Wouldn't more air call for more fuel? So maybe this had something to do with my Super Rich situation?
Good find. Usually you’ll only have 1 air bleed screw adjusted per carb and even then only slightly.
Keep going - you’re on the right path!
Also make sure if your carbs are equipped with vacuum ports - they should be sealed. I’ve seen Weber IDF’s with no ports, 1 port per pair of carbs, and 1 port on each barrel. Not sure what dictated the port configurations. Regardless, they need to be sealed, either with plugs or by being connected to the distributor vacuum canister (without leakage) if you’re using vacuum advance.
malcolm2
May 3 2023, 01:59 PM
I do have a vacuum can on the disty. Both carbs have a Vac. Advance Port as noted above. They came plugged. I removed 1 plug and attached a hose to the vac can. I also have a 1 way valve on that hose or something similar. IIRC AC.net recommended the device to help smooth out erratic pulses.
Tomlinsons Weber book p.22 ….’pre-set your air by-pass screws. Set them 1/2 turn off the bottom’. Beg, borrow or steal a Tomlinsons.. Start at the beginning and go thru the set-up procedure again. It’s only a few screws and settings. Should take about 10-15 minutes. Start fresh.
nditiz1
May 3 2023, 04:54 PM
ACN recommends using the port over cyl 4. I use the anti pulse when running dual carbs as well.
I haven't cracked my Tomlinsons in awhile, but I set my air bypass the same as Richard from PMO sets his. All closed, whichever chamber is the lowest, open to bring it up. Should only need a few turns. Anything excessive and you might have a vac leak. I think you were able to sync all 4 chambers so that's probably not a problem.
Now that you have them back together, turn your car on to fill the fuel bowls. Then turn off the car and manually operate the throttles to see the squirt volume. Both sides/all 4 should have the same shot.
malcolm2
May 4 2023, 12:14 PM
QUOTE(rhodyguy @ May 3 2023, 03:38 PM)
Maybe you would send it to me..... ??
I will pay the freight to and from and get it back to you ASAP.
rhodyguy
May 4 2023, 12:56 PM
PM sent.
Jack Standz
May 4 2023, 02:08 PM
QUOTE(malcolm2 @ May 1 2023, 04:42 AM)
This float setting does not seem to be accurate. I see videos with the dude hold the plate vertically, the floats bounce back and forth and he sticks a mic on it and says it is not right.
Sorry, but I don't see the exact second when he is measuring a moving float.
ACN says they set mine at 12mm.... I can move the plate around and say BOOM... 12 mm. is that right? THis guy suggests 10mm. i can't tell.
The current standard specification is 12mm to 14mm (and with the float flipped the other way, it's 34mm).
Something about fuel now being part alcohol (10%). This makes the float sink a little more because current fuel is lower specific gravity. So, unless you're running 100% gasoline in the motor, you should be good.
nditiz1
May 4 2023, 04:44 PM
QUOTE(malcolm2 @ May 4 2023, 11:14 AM)
I think I have an extra one for Weber, or an extra for Dells, but yeah I can send it.
malcolm2
May 4 2023, 07:35 PM
QUOTE(nditiz1 @ May 4 2023, 05:44 PM)
Thanks. I bought a weber one on ebay. And i have borrowed the supertech book. I will read it and return it. No need for copies or pdfs. Wink wink.
malcolm2
May 4 2023, 07:39 PM
I go back and forth on ethanol or pure. Nice to know why we were getting 10 and 12 from different folks.
malcolm2
May 6 2023, 08:15 AM
OK.... engine started. Had to give the idle screws a full turn to get it to idle.... but it is running on it's own this morning.
The first thing i wanted to do was adjust the fuel pressure. it is just slightly above 3 this morning.
I did get some comments that the gauge could be troublesome. But I attempted to adjust the QFT low pressure regulator and the gauge did not move... threaded it in and out and got no change in the gauge. Did not notice any engine changes either.
EDIT::: I turned the engine off, and let the pressure bleed off and restarted and was able to ADJUST to 1.5.
But which way do i adjust the regulator? I would have thought IN would block the fuel and lower the pressure??
I may have..... Flow matches on all barrels, idle is set, linkage is back on and the flow #s and RPM stayed the same.
I took a video of the end and will add it here later. I am happy, but my FP gauge is still acting strange. I can't really adjust it up, but I can adjust it down.
This morning it was on 3, i took it to 1.5 and every now and then I see it drop to about zero.
malcolm2
May 6 2023, 03:25 PM
youtube won't let me rotate..... but you can still watch. Hey, is there a way to add a DOCUMENT to a post?
I’m still hearing sumpin wrong. Still sounds like one cylinder is not performing the same as the other three. I forget what venturis you have, but you may want to get smaller ones It seems sluggish at lower idle. Maybe get a new fuel pressure unit?
930cabman
May 6 2023, 05:07 PM
How does she run? WOT? seems to idle ok
Superhawk996
May 6 2023, 05:15 PM
Still sounding a bit like it’s bogging a little when throttle begins to open before it picks up RPMs. You are on 28mm venturis so should be better than that.
I think you’re getting a bit distracted by fuel pressure. To be honest, carbs don’t care much and will run in a wide range of pressure between 1-4 psi. Don’t believe me. Try this - run your fuel pump till bowls are full - then disconnect and plug the fuel line. You’ll be amazed how long it will idle / and do light transitions before the bowls run low and start running really poorly.
You’re expecting a 0-15 psi gauge to be accurate in the 1-3 psi range. I think you’re probably seeing gauge “sticktion” at those low pressures where the needle temporarily sticks from internal gauge friction with just barely enough pressure to even begin to move the gauge. As someone said earlier you want a gauge that is about 0-5 psi to have an accurate indication.
Depending on the range that the regulator is designed for it may be that the “sticktion” is in the regulator if that was designed for 0-15 psi. Edit: just looked at your JEG’s link - you should be peachy!
Bottom line - I suspect you’re chasing your tail on fuel pressure.
Barrels to barrel airflow is pretty good. Edit: after watching a 2nd time - I’d say that one cylinder is 6 vs all the others at 6.5. Might bring that one up to 6.5 with air bypass. Then recheck idle mix.
Are you sure your idle mix is tuned properly for best lean idle? I know you said you’re about one turn out which is probably about right but you should be getting an idle speed drop if you open or close the idle mix from that setting if you’re at best lean idle. Is that the case?
What is your idle speed set at? The tach is not the best indicator if true idle speed. I use a digital engine multimeter to set idle speed. Idle sounds sort of low. Once you have best lean idle set, you should only be using the carb linkage, idle screw to tweek the idle speed. After you tweek that, you need to go back and recheck best lean idle mix - it’s an iterative loop.
Also what distributor set up are you using? You may not be getting enough advance early enough.
Final edit - I just compared 1st video to latest. Defiantly improving. Good job. Keep tweaking it and once you have the idle speed and mix finessed - go back and recheck carb to carb sync and how equally your linkages are moving. You’re getting there
Jack Standz
May 6 2023, 05:52 PM
Yes, fuel pressure could be the problem, if you truly are having little or none.
I recently had a problem where the fuel pressure gauge was showing zero and the regulator made no change to the reading turned all the way in or out. The motor would run. But, it wouldn't run right or wouldn't take a tune. Since the motor would run (some), I just couldn't believe the gauge.
Completely new fuel delivery system, new carbs, new motor. Turns out the fuel line was kinked under the tank (914 versus bus). Seems that some fuel could make it through. At least the first carb in the set was gettingsome fuel. Bus fuel lines are different, but I suppose something could pinch it.
Probably not your problem, but worth checking. Especially since you said the gauge goes to zero. But, it could be just the gauge. I bought a second gauge ($15 on Amazon) that also showed zero before I figured out the fuel line was pinched. When you get it figured out, run with 3 psi or less, as long as fuel isn't dribbling out the auxiliary venturis. My 2056 likes about 2.5 psi give or take.
If you want to tune these carbs, suggest getting a colortune spark plug (Google it) and a wide band AFR gauge (you decide whether to permanently mount it or not. If permanently mounted in a bus, you'll need the longer wiring harness.
malcolm2
May 6 2023, 06:56 PM
All day run with new plugs. Lots of adjusting etc.. but not DRY JET BLACK.
Have you verified that the throttle plate is closed, covering the 1st transition port when the idle speed screws aren’t even touching the linkage?
This is Hugely important.
If you have done that then I suspect the idle mix isn’t being adjusted properly for best lean idle
OR
You will need to go down on idle jet size
malcolm2
May 6 2023, 07:46 PM
QUOTE(Superhawk996 @ May 6 2023, 08:15 PM)
You’re running way too rich
Only way to verify now is that the speed screw is hitting the bracket. I did look at it when it was on the bench. Fully closed. Several little holes in the barrel under the plate. Seemed closed to me.
Remember, this pic is from idling all day and setting and resetting screws. All that. They look a bit lean to me. Gray??
Superhawk996
May 6 2023, 11:11 PM
QUOTE(malcolm2 @ May 6 2023, 08:46 PM)
There are also a series of small holes (the transition ports) that should closed and a few that are open or just obscured above the plate when the throttle plates are closed. Click to view attachment
It is critical that you’re not running idle such that the transition ports are uncovered by having the idle speed screw set too far open. You want to make sure you don’t have the condition shown in illustration B when idling.
With respect to the plug condition, that plug is no where near a lean condition even when looking at only the insulator.
DO YOU SEE ANYTHING ELSE I SHOULD DO, OR DO DIFFERENTLY??
Linkage removed Speed Screw 1/2 turn in after touching Bypass screws closed Mixture screws out 1 turn
Engine runs poorly as expected. 1. turn IN mix screw until the engine runs worse... i would turn each screw about 1/4, then move to the next one, and so on. 2nd time around (1/4 at a time), as I got to the 3rd barrel, the engine would run worse. 2. turn OUT mix screw until the engine runs better. Again 1/4 turn at a time, til I got no reaction. Turn them back IN until they are BEST.
Then I set the Speed screw to 950 to 1000rpm. I have an analog meter.... one lead on batt- one lead on coil-. using the V8 scale and doubling it. I am sure you remember those old timers.
I placed the snail on the front barrel of one side then the other. adjusted the High flow barrel down to the low flow barrel with the speed screw. then adjust both back to 950 -1000, matching flow using the snail.
From there, i went to the bypass screws. checking flow front barrel to back barrel and adjusting the LOW flow up to the high flow. Leaving the high flow CLOSED. Then again, matching the right to left carb's flow to the idle rpm with the speed screw.
I have a new pertronix SVDA disty with a P3 module in it. I dismantled it, and cleaned and lubed it after arrival.... another AC.net item.
malcolm2
May 7 2023, 08:21 AM
QUOTE(Jack Standz @ May 6 2023, 06:52 PM)
Was thinking I should put an A/F on the bus and eventually I will.
I have a A/F on my 914. It has a blue tooth adapter that allows me to use my phone for the readout. Unfortunately, they have been out of stock for over a year. Guess I need to find another vendor....
Now you’re seeing how small adjustments can result in BIG changes. Remember to pause a bit after every adj. Bosch plug #?
Superhawk996
May 7 2023, 01:18 PM
QUOTE(malcolm2 @ May 7 2023, 09:11 AM)
Generally I think you’re on the right path and doing reasonable things. You don’t mention readjusting mixtures after resetting idle speed. Idle mix affects idle speed and vice versa. Same again after setting an air bypass - recheck mix all the way around again after that. Everything affects everything else.
I might go only 1/4 turn on the initial idle speed screw just to ensure that transition port is fully closed when you are adjusting mixture initially.
And probably just slow down on the idle mix screw adjustment - there is always some time delay between turning the screw and observing the effect when it finally gets to the engine.
Maybe smaller 1/8 turn changes as you get closer. It really is a multiple iteration process between mixture, idle speed, air bypass. Each change affects the others. Agree with Rhodyguy that small changes have big effects as you get closer and closer.
Check ignition advance and make sure you’re starting to begin a good advance by 1500 rpm. As noted on NGK chart retarded timing (not enough advance) can manifest as running rich. Basically just verify SVDA is working properly.
And finally, it isn’t unheard of to have to go down an idle jet size. Too big of a jet really jacks up the speed & mixture effects of the needle mix screw adjustments. .
malcolm2
May 8 2023, 09:32 AM
QUOTE(rhodyguy @ May 7 2023, 01:27 PM)
NGK BPR6ES
malcolm2
May 8 2023, 05:30 PM
QUOTE(930cabman @ May 6 2023, 06:07 PM)
I would not say WOT, but fast enough for me to be a bit worried.... 55mph in a bus is kinda scary. But engine-wise it felt nice.... a bit up hill, accelerating all the way thru 4th gear.
I live on a hill with 4 speed humps. The trip on the day that crap started raising it's ugly head, I did not feel like I had much power.
TODAY, I went up the hill 2 times, 2nd gear, pulling hard after the speed humps to the next hump.... also felt good. Enough power for a 72 bus with a 2.0 liter, bus pistons and camper special heads!!! Much better. Drove about 8 miles today around the hood and down to the elementary school on the long straight is where I got to 55.
malcolm2
May 8 2023, 05:37 PM
OR
I found a way to MAYBE verify your concern about the throttle plate and maybe you are right, but how do I deal with it? As you can see from the last vid, all 4 barrels are very close in flow. So here is what i found.
It was obvious that the tip of the speed screw shows more threads on the PASS Side than on the Drivers Side. Wouldn't that mean that there is a chance that the plate is open past the port you showed me???
What can I do to make it close more and still run nicely?
Superhawk996
May 8 2023, 06:50 PM
I wouldn’t judge by that 1.3mm variance in the amount of screw showing. You have casting variance, stamped linkage variance, and variance in the length of the screw. That 1.3mm variance is sort of normal when you synch carb to carb.
Especially since you seem to be happy that it’s running better and improving.
I’d just stay focused on trying to lean out idle mixture and given where you are in the process, I’d just swap the idle jet and keep moving forward.
I’ve always made a point of being sure that the transition ports are closed when it is on the bench for initial bench settings. It’s much harder to do when the carbs are installed.
What I’d probably do is shine a light down the throttle bore and verify that the throttle butterfly is hardly open when it’s setting at rest on the idle speed screw stop. Throttle butterfly plates should basically be closed with only a tiny sliver of a gap. Maybe you might be able to see the top of one of the transition ports sitting ABOVE the plate that would be good. If the butterfly plates seem to be lifted significantly when sitting in the stops, I might pull them and bench check where they are sitting. Just pulling them and replacing them won’t mess up too much of the tuning you’ve done but you’ll have to verify and then re synch again.
I would really hate for you to pull them again which is why I’m suggesting you go down in idle jet 1st. It’s easier and is probably going to be more of a sure thing vs the chance that the transition port is uncovered at idle.
r_towle
May 8 2023, 07:13 PM
The throttle plates should be visible from above to let you see how they are sitting at idle. Idle is zero throttle They should match.
Like Stated above, the screw position can be different The throttle plates should not be different
To make yourself comfy with how they work….I might suggest you remove the throttle linkage Start car Turn screw out (close throttle plates) Listen to the difference on each side Then check again with the air flow meter, adjust as needed.
You are getting close, and thankfully once you get them setup perfectly for your engine, you won’t need to adjust them anymore.
Get the plugs brown, not black It can be done, and you will be thrilled once you nail it
Then you can answer all carb related questions here
I listen to the motor, your ear can tell once it purrs
malcolm2
May 9 2023, 01:14 PM
OK so I should get smaller Weber IDF Idle Jets.... CB has 0.45 and 0.40. figured I would get 4 of each. $4.50 each.
Where are your idle mixture screws? If I recall correctly they should be in the range of 1 1/2 turns out from seated. If less the idle jets are too large, if more the idle jets are too small. PLEASE check the previous statement. It's one way or the other
Don't throw new jets in her just for the heck of it
nditiz1
May 9 2023, 01:54 PM
50 idle are fine. I doubt you will need to go lower.
