Drivers Side Longitudinal - Part 6 (2/4/2024): After welding in the stiffener on the inboard side, I moved over to repairing a few items in the inside of the longitudinal. There were two areas that had to be addressed here before I could move on: 1) Close the small hole at the front of the longitudinal that was previously used to shoot in rust preventative wax. 2) Reconstruct and weld in reinforcement metal and the new seat belt bolt. Note the arrows.
Click to view attachment1) Hole Repair - I started by cutting and shaping a small patch made out of 18 gauge metal, which I tacked in place. After aligning the patch, I then fully welded it in and finished it all off with some grinding/sanding. I'm not concerned at this point with reconstructing/repairing anything else in the front wheel well at this time. I'll have that "party" some day in the future!
Click to view attachment Click to view attachmentClick to view attachment2) Rear Longitudinal Reinforcement - Unlike the small hole repair, this task was a little more time-consuming. I started by creating the vertical reinforcement using the original part made out of 18 gauge sheet metal. Once sanded and painted the metal was welded into place. Note, I did used a small piece of the original metal to make things a little easier.
Click to view attachment Click to view attachmentClick to view attachment Next up was drilling out a hole for the seatbelt bolt. This was done by drilling a pilot from the other side and then widening the hole using a step bit. Once the hole was finished, it was just a matter of welding in the prep'd bolt "assembly". This is the part sold by Restoration Design, by the way.
Click to view attachment Click to view attachment Click to view attachmentNext was fabricating the lower support piece. This was actually pretty fun to do. My goal was to make it look like the "pressed" stock piece but utilize two or three separate pieces. Since this is an original longitudinal and does not have a flat bottom, it requires the repair piece mimic the shape. My repair here certainly is not perfect but I think it does the job and looks the part.
Click to view attachment Click to view attachmentClick to view attachment Click to view attachmentClick to view attachment Click to view attachmentClick to view attachment Click to view attachmentAfter completing the repair work, I was finally able to prep and paint the internals. After a good cleaning using glass cleaner and lint-free disposable wipes, I sprayed in Eastwood's Internal Frame Rail paint followed by CRC's Protective Wax.
Click to view attachment Click to view attachmentClick to view attachment Click to view attachmentThe final photos show some late Sunday afternoon work to rivet in the heater tube clips, weld in the front heater pipe, and re-weld the "reconditioned" inner fender piece, that's lives under the inner rocker panel. Decided to call it a day after that. I will pick it up next time when I get to finish up the longitudinal in part 7.
