Rotisserie (10/2023): Having completed the repairs I thought necessary to stiffen up the chassis on the LE, I went ahead a built another rotisserie from scratch. Unfortunately, I had sold the previous rotisserie that I had made for my other 914 a few years ago - 'cause I never thought I need it again
However, I did employ a few "lessons learned" from the last one like: using a drill press for the support bar connection holes on the hoops, and properly cleaning and painting ALL of the metal. Keeping your hands free of that dirty, oily coating is really the way to go.
So, using the same Restoration Design blueprints, I went forward with the build. I ordered/picked up 12 pieces of 12' X 1 1/4" square tubing along with several scrap pieces of 1/2" plate for the casters and the for the four mounting points on the car. BTW, the casters were purchased off amazon for less than $100. I actually only used 10 pieces of tubing for the rotisserie, the other two pipes were saved for an engine test stand that I will be building later.
Click to view attachment Click to view attachmentOne thing to note about the RD plans is the fact that the angles listed for the rear hoop's mount to the transmission support tunnel are 180 degrees out. I also think additional support metal should be added to the mounting points, which is easy to do with some of the leftover metal scrap. The following pics show how I used my old flux-core welder to build the hoops that were cut, cleaned, and primed. This process is easy to do based on the drawings. I used Simple green to clean all the pipe and painted everything (once dry) with some self-etching metal primer. I would also recommend welding the hoops with the aid of the flat garage floor, like I did.
Click to view attachmentBack outside, I finished any necessary welding on the hoops and began the process of constructing the front and rear mounting points. Once completed, I painted the hoops with some cheap black spray paint. I then decided to add some additional bracing and welded two 6" plates for the casters to the bottom of each hoop. Sorry, I don't have a good picture of the front hoop's mount to the 914's Aux Support bar that is utilized with this design. I also cut the 8 long connecting bars to length and added a 2 1/2" piece of angle iron to each end. A hole was later drilled through each bar end to secure each bar to both hoops.
Click to view attachment Click to view attachmentClick to view attachment Click to view attachmentClick to view attachment Click to view attachmentThese final photos show the car being mounted to each hoop and later secured with the 8 support bars. All that is left is to remove the remainder of the rear suspension so the car can be rotated. This entire process took me 3 days and cost less than $450. IMO, this is not a very difficult job to do. You just need a welder, a drill, and something that can cut metal.
