Hi and thanks for the complement.
By the way,
Have fun on this site. This is the best 914 site on the planet. These guys here will help you out of any jam you get into with your 914. Chances are if you have trouble someone's already had it before and can help. Check the "Lapuwali Classic Thread Forum" here for how-to articles.
Removing the rear suspension is quite easy as jobs go. The only difficult part may be that some of the bolts are rusted. I had a major problem on my 71 914 with a shock bolt that was rusted on. I ended up grinding the head off so I could remove the shock.
Here's a quick how to remove the rear swing arms:
1) Jack car up, remove tire and remove cotter pin holding center nut. Replace tire and lower jack.
2) With breaker bar and correct size socket, loosen center nut and remove.
3) Put car on jackstands. Use more than one on each side for safety, and stack the tires under the car for added safety.
4) Push on brake pedal and hold down with a stick. This keeps the brake fluid from draining when you remove the rear caliper.
5) Remove brake caliper and disconnect from brake line and emergency brake cable.
6) Remove the shock. One nut at the top and big bolt through the rear swing arm. Support the rear swing arm with a jack or other item to keep it from dropping and the drive shaft hitting the heat exchanger.
7) Remove large nut on swing arm pivot on the inside. Remove outer nut too. Remove 3 bolts holding outer swing arm adjustment plate. Watch out for alignment shims falling to the ground. Keep track of where they go and how many.
8) At this point, I've found I can remove the swing arm without disconnecting the drive axle from the transmission. If the axle spline is stuck in the hub, push it out with a gear puller just to loosen it. It should then come out on its own. You may want to remove the axle from the transmission if you want to repack or inspect the CV joints.
I might be forgetting something or other members may want to chime in with their methods or point you to a link. It isn't necessarily a hard job, just takes some time. The rear end will need aligned after replacement.
