MoveQik
Jul 29 2006, 12:09 AM
QUOTE(JOHNMAN @ Jul 28 2006, 11:03 PM)
Are you really using those valve cover gaskets? I tried those once and went back to the stock type valve cover gaskets. I had troubles with them wanting to squish out and not feeling comfortable that I had the nuts tight enough.
You like them?
Ok.....I give. I am not the most mechanical guy you'll meet on this board(reason number one that Joe is doing the conversion!). But please tell me how you can determine the valve cover gaskets that are being used from the pics posted here.
I'm just a brotha lookin' to learn.......
GWN7
Jul 29 2006, 12:18 AM
Joe's Garage?
John
Jul 29 2006, 12:22 AM
In the picture with the two gauges shown, in the background, there is a set of orange silicone 911 valve cover gaskets. I recognize them as I have had a set in the past.
They are "forever" gaskets. You are supposed to be able to re-use them and only replace the hardware during a valve adjust.
I recall they were made by "real gasket company" (or something close to that).
John
John
Jul 29 2006, 12:27 AM
BTW, the 901 can hold up for light duty use with the 3.2. (That's what I'm using in my street car).
If/when it fails, I have the 915 that came with my 3.2 just about ready to convert to 914 use.
The track car (also a 3.2) started eating 901 boxes for snacks (4th gear would loose all the teeth on both gears). After the 4th box, we went with a converted 915.
MoveQik
Jul 29 2006, 12:29 AM
QUOTE(JOHNMAN @ Jul 28 2006, 11:22 PM)
John
ahhhhh....you see, there you go. I thought you were looking at the pics of the engine and you were SO skilled that you could see the valve cover gaskets! As for the ones in the pics, you'll have to wait for Joe's input.
TurtleGirl
Jul 29 2006, 12:47 AM
Those are actually for my car. They are one of the few things left that need to be handled at Joe's house... My garage isn't as well equipped as Joe's.... Slowly but surely!
QUOTE(MW 914 @ Jul 29 2006, 12:29 AM)
John
MoveQik
Jul 29 2006, 12:52 AM
QUOTE(TurtleGirl @ Jul 28 2006, 11:47 PM)
Hey Liz! I can't wait 'till Moab! Hopefully Nico will make it and we can enjoy PLENTY of Turtle Mountain Brew!
Series9
Jul 31 2006, 04:30 PM
This is an expensive tank, but it's very nice:
Series9
Jul 31 2006, 04:32 PM
Holes cut for the tank and undercoated:
Series9
Aug 7 2006, 06:54 PM
O2 sensor bung welded up. Yes, I said bung.
Series9
Aug 7 2006, 06:55 PM
This stuff is going to ceramic coating today:
Series9
Aug 7 2006, 06:56 PM
This stuff is going to Rich Johnson tomorrow:
Series9
Aug 7 2006, 06:57 PM
/4 fuel lines completely removed:
Series9
Aug 7 2006, 06:59 PM
5-bolt front end. Unfortunatley, I had to contact the seller about not including the spindle nuts and the dust caps for the hubs:
Series9
Aug 7 2006, 07:00 PM
Last. The gas tank out so I can run new fuel lines:
GTeener
Aug 8 2006, 10:16 AM
Look'n good. Thanks for sharing the progress!
Series9
Aug 14 2006, 07:40 PM
......mmmmmmmmm......digital 914....
The 914 and DME are now one.
Here's the DME, Altitude switch and spot for the DME relay:
Series9
Aug 14 2006, 07:43 PM
The 3.2 pump fits in place of the original:
Series9
Aug 14 2006, 07:45 PM
Here's a mock-up to check the size of the cooler/fan assembly I'm going to use:
16x6.5x6
Series9
Aug 14 2006, 07:46 PM
Setrab:
LvSteveH
Aug 15 2006, 01:50 AM
Nice cooling fan setup, do you have a part number by any chance?
thesey914
Aug 15 2006, 04:08 AM
I have a question...what's Rich going to do to the 911 throttle linkage (or is that just in the picture with the cooler by chance)?
Series9
Aug 15 2006, 10:26 AM
QUOTE(LvSteveH @ Aug 15 2006, 01:50 AM)
http://www.hrpworld.com/SetrabCPFanPackOil...;action=product
Series9
Aug 15 2006, 10:34 AM
QUOTE(thesey914 @ Aug 15 2006, 04:08 AM)
He puts new bushings and reorients the pins as part of his kit.
thesey914
Aug 15 2006, 03:47 PM
Joe, kit for what?
enquiring minds want to know
Series9
Aug 15 2006, 08:27 PM
QUOTE(thesey914 @ Aug 15 2006, 03:47 PM)
Joe, kit for what?
The throttle linkage kit.
Series9
Aug 15 2006, 08:29 PM
Engine mount installed. It might seem simple (I thought it would be), but it required some mods to fit correctly:
Series9
Aug 15 2006, 08:30 PM
Ceramic coating home:
Series9
Aug 15 2006, 08:34 PM
Two hour job....the custom piece-of-paper-template to make the metal to cover this hole:
Series9
Aug 15 2006, 08:35 PM
Since multiple pictures still refuse to work for the Mac, here's the paper:
John
Aug 15 2006, 09:40 PM
You know I make the whole piece:
Series9
Aug 15 2006, 10:14 PM
You should sell those for less than $120.......
seanery
Aug 15 2006, 10:27 PM
I like the ceramic coated engine tin....very slick. I'll have to remember that one
John
Aug 15 2006, 10:54 PM
Joe they are $50
Where did you get $120 from?
Series9
Aug 16 2006, 06:57 AM
QUOTE(JOHNMAN @ Aug 15 2006, 10:54 PM)
Joe they are $50
2 hours of work for me.
xitspd
Aug 16 2006, 10:22 AM
Hi Joe,
The ceramic coating on the engine tin is very cool and an innovative idea! Keep up the good work. Tell Luckie I said, "Hello". Are you guys coming to GAF?
Dan
MoveQik
Aug 26 2006, 01:33 PM
I talked to Al Reed yesterday about my wheels. Conversation goes like this...
Me - So Al, are they done? How do they look?
Al - They are done. You are going to love them...they look like jewelry.
Me -
They ship out Monday to Joe.
Series9
Sep 2 2006, 12:35 PM
Nice wheels:
Series9
Sep 2 2006, 12:36 PM
Engine and tranny together:
Series9
Sep 2 2006, 12:37 PM
Speed sensor mod:
Series9
5-bolt front:
Series9
Sep 5 2006, 07:06 PM
The official introduction.
The engine is in.
The oil tank is in.
The oil system is completely plumbed.
The fuel system only needs the filter installed.
Electrically, I only have the engine harness connector to sort out.
I have to fly the next three days, but I should be able to attempt a first start in the next week.
Aaron Cox
Sep 5 2006, 07:12 PM
Looks killer! will it be ready for RRC???
BTW- the 5 point harness safety washers should be mounted directly to firewall, not thru the pad... as the pad is compliant.....
Series9
Sep 5 2006, 07:29 PM
QUOTE(Aaron Cox @ Sep 5 2006, 07:12 PM)
As long as the computer is fine, It'll be at RRC.
.....I didn't install the belts.
MoveQik
Sep 5 2006, 08:37 PM
QUOTE(Aaron Cox @ Sep 5 2006, 06:12 PM)
Noted. I will make sure that my pad does not comply going forward.
Joe - That looks
AWESOME!! I can't wait to drive it!
AZ914
Sep 5 2006, 09:43 PM
Serious BLING on those fuchs! Al Reed is a stud.
WaideS
Sep 6 2006, 08:10 AM
First start in a week
WOOOO HOOOO
Very Nice Joe
Good Luck Wills
Series9
Sep 9 2006, 04:31 PM
Oil tank finished:
Series9
Sep 9 2006, 04:32 PM
Tires are here:
Series9
Sep 9 2006, 04:35 PM
And now for the fun stuff.
The definition of irony:
Mike wanted to keep the car 4-bolt so it looked stock. After I talked him into 5-bolt, he insisted that he would only have Fuchs on the car, so it looked stock.
When it came time to choose a muffler, he chose this.......
wait for it......
here:
