degreeoff
Feb 25 2008, 04:55 PM
To elaborate on the EZ wiring harness....it was CHEAP and it was all there and they (manufacturer) were very helpful but I am afraid that is all I can offer....I had to modify it a bit as it is designed for the hotrods (front engine). BUT if I did it right which as a non electrical guru I would say I have a 90% or better chance that it is goinna work. it was well woth it and it is CLEAN and all new (AKA no OWI old wire issues)
ALSO to be noted...I cannot imagine trying to do this new harness for a factory car with all the goodies that came stock....This has basic lights and wipers and gauges nothing more.
rick 918-S
Feb 25 2008, 09:39 PM
QUOTE(degreeoff @ Feb 25 2008, 02:55 PM)
I'm doing the same thing in the Healey right now! I have the 12 curcuit and had to add one for the electric cooling fan. But it was cheap and it's new.
Nice project!
degreeoff
Mar 1 2008, 07:36 PM
Well as stated in another post...thanks guy's! (plas76targa and crash914)
here is an engine pic from before the install...she looks good! If not a little bright!
crash914
Mar 1 2008, 08:39 PM
degreeoff
Mar 3 2008, 01:43 PM
OK boring progress....brakes bled...1 leak @ the Jwest prop valve...lotta fluid in these bigger brakes with the 23mm MC, running cables oil lines shift rod...dull stuff but after a lil cutting and some muffler painting and polishing the tip...PERV! I have some goo shots...I mean good shots up er ass!
Click to view attachmentClick to view attachment
crash914
Mar 3 2008, 02:04 PM
Looks good, you got a lot done...
Mar 3 2008, 02:44 PM
QUOTE(crash914 @ Mar 1 2008, 06:39 PM)
why does this picture remind me of christmas?
Andy
PS: looking good!
degreeoff
Mar 3 2008, 04:10 PM
Believe me Andy, that is a Xmas present long in the coming....hopefully short in the completion and short in issues?????
degreeoff
Mar 4 2008, 11:08 PM
OK so I am one tired SOB!!!
It has been 3 days of nonstop nonsense! BUT the plus side is that for all intents and purposes I am done with the mechanical BS. Things left to do are add oil (anyone know how much??? add gas add battery (hope there are no zap zap EEeewwww what the hell is burnin?) add spark plugs and add the oil tank to case breather hose.......
Because I want to be sure of running state before I leave Thursday for a 10 day ski VACA and before I put BEAUtiful paint on.....
So tomorrow I shall...........
Source a oil hose.....install.........
Set timing and verify plug order on my new age fandangled HPX crankfire setup..............
Add battery...check for proper circut workings.........
Add oil and crank her over without spark plugs to build oil pressure........
Add gas and turn on the pump making sure the carbs are not spilling over and or leaking from a fuel line I forgot to tighten.....
Grab my handy dandy class SUPER DUPER fire extinguisher..........
Sit in car, say my prayers TWICE
and flip the fuel pump switch, flip the ignition switch and turn her over ........
WISH ME LUCK!!!!!
and for GODS sake if I am forgetting anything let me know!!!!!!!!!
And of course if she runs as well as I hope she does I will most likley spin her around the block!!!
Click to view attachmentClick to view attachmentClick to view attachment
PeeGreen 914
Mar 4 2008, 11:12 PM
I love seeing your work come along. Looking forward to seeing it all finished.
crash914
Mar 5 2008, 05:34 AM
WoW!!! no motor no seats on Saturday to this!!!!
rock on!!!
degreeoff
Mar 5 2008, 04:39 PM
Well no joy.....spent 3 hours looking for a damn tube for the breather, then 2 hours diagnosing issues with my 'one size fits all' wiring harness. Then oil pressure with no plugs in was not reading after 9 qts added, then fuel pump was putting out 8 PSI and gas leaked from one barrel and down the throat of another....turned the regulator down to 3.5 easy still need to pop the carbs off and check them again....BUT all this on another day!! I am outta town for a 10 day VACA....until next time.......PEACE!! BTW should oil pressure read spinning fast like that w/o plugs? Never could get the idiot light to work....hmmmm
crash914
Mar 5 2008, 05:30 PM
degreeoff
Mar 17 2008, 01:51 PM
IT LIVES!!!!!! After much work and sweat a couple cuts and much cussing as well as a few posts on the bird board and calls to Clewitt engineering and electromotive a singe $.20 part (1k ohm resister ) and she sputtered to life........
sounds good and smoked like a bitch (mainly from the cheezy exhaust paint from a evilbayer) no CRASH GRIND BANG!! (ok a couple out of the carbs....
) no I am out to see if she will tune a bit (carb work)....
Wish me luck!!!
Josh the grateful!!!
Chris Pincetich
Mar 17 2008, 03:29 PM
AWESOME
good luck with all that remains!
brer
Mar 17 2008, 04:16 PM
simply amazing.
When all the stock parts on my car wear out I'm going to do this.
can I ask what brand paint and the color of your primer?
J P Stein
Mar 17 2008, 05:36 PM
Yes!
Mine rumbled to life again a week ago Sunday.
Feels good, don't it.
degreeoff
Mar 17 2008, 05:44 PM
The color is POR137....and the primer is just grey all by Dupont (chroma base/ Nason clear. The only problem I am now having is my fuel pressure was dropping and I dont know why?? But I will figure it out. The pump is mounted high so I think it may be that but who knows? It could also be a fuel pickup problem as I had to dump 5 gallons in it to get it to start to draw.....BUT all in all it is looking good and I was able to put the car in all gears today and roll forward and back under power!!!!
Twise
Mar 17 2008, 06:00 PM
Real nice - got me thinking about my next project...????
crash914
Mar 17 2008, 06:49 PM
congrats!!!
I just got back and missed your call.....now to kick mine in gear....
rolling under power sure puts a smile on your face doesn't it...
gotxqss
Mar 18 2008, 02:48 AM
AWESOME MAN!!!!!!!! Simply LLOOOVVVVEEE the color. Attention to detail is what its all about. wouldn't change much on a dream build!
hope someday I got the funds to make that happen
degreeoff
Mar 18 2008, 01:09 PM
Well now I gone an broke the law today with a quick drive down the block! aside from the tears all be it joy , surprise or the fact that there is no windshield....the world may never know! I'll say this once it gets on cam......
Now I have a few MORE issues....
seems to run pretty good although my fuel pressure is wacky after relocating the pump, so it may be a bad regulator or gauge??
also there seems a bit more popping through the carbs than I would like.....
also the first second reverse gears are way STIFF.....I had to make the rod so I think I may have screwed it up a bit as the bushings are all good...?
BUT on the flip side there are very minor weeps in the way of oil and no PUDDLES!!!!!
YOU TOO CAN REBUILD A 9elben engine.....
Josh
degreeoff
Mar 24 2008, 03:19 PM
linky linky me and pinky! And yes it is running RICH!! But my guy said I need to seat the rings and such before we can tune it properly....
http://www.youtube.com/watch?v=orlHDVCBC1Q
jonferns
Mar 24 2008, 03:21 PM
Freakin awesome
crash914
Mar 24 2008, 03:31 PM
Paint!!!! Paint!!!!
way to go...I was hoping to see donuts!!
degreeoff
Mar 24 2008, 08:10 PM
need LSD for that.......tailed it in 3d though while goin around that corner!
roadster fan
Mar 25 2008, 01:34 AM
I just read this whole thread again (I think my third time) and all I can say is................SWEEEEEEEET!
Can't wait to see the 73 RS you build, you have been an inspiration.
Keep the updates coming,
Jim
Dr. Roger
Mar 26 2008, 01:25 PM
Hey Josh,
Summer is almost here.
Wuzup wit' yer ride???
Is the engine in yet?
degreeoff
Mar 26 2008, 05:39 PM
well the new toy came in today!! Hard as hell to get that thing off a trailer and set up weighing in at a measly 800lbs!! THIS is the $949 39"lift from Harbor freight.....I am ALL for american made but this thing works VERY well and is 1/3d the price....for a bunch of heavy steel. So being the CSOB that I am I went this route!
crash914
Mar 26 2008, 05:40 PM
damn, I was at the laurel HF earlier today....could have helped...
crash914
Mar 26 2008, 05:41 PM
looks like it would be easy to mount the rotisserie also...
degreeoff
Mar 26 2008, 05:44 PM
Its all good Herb, they forklifted it onto the car hauler trailer and I had em set it on the 4 1000lb ($9.99 each) mini dollies (which I will use for my alignments) and I basicly rolled it off the trailer and onto a jack and off a jack and on a jack until it was far enough off the trailer to use the built in doohickiemagigy(on the pump) for moving it around the floor (its semi portable that way)
degreeoff
Mar 26 2008, 05:46 PM
Yep good for that as I WILL build a RS (73ish) replica next .....welll in a couple years!
degreeoff
Mar 31 2008, 06:17 PM
well we be paintin....and striping and....what was I talking about????
(sorry the fumes are getting to me!) A few runs and a bit 'o' dust but 3 clear coats = wet sand + buff right out......
crash914
Mar 31 2008, 07:11 PM
looking good....
I just bought some paint myself.....got to finish the body work......
degreeoff
Mar 31 2008, 07:17 PM
Hey Herb, maybe you could get it together in time for the autoX @ baysox stadium on 4/26....thats my NEW goal!!
crash914
Apr 1 2008, 04:40 AM
tempting...but....
engine and trans yes, body most likely not...the re-assembly will be a bitch....
jonferns
Apr 1 2008, 02:13 PM
Hey, is that a white stripe? Looks great
degreeoff
Apr 1 2008, 03:06 PM
ahhhh yup!. Took it for a lil spin again today, after I buffed out the clear...not perfect but close enough for a garage job and racer....I can smell the end. All electrical gremlins addressed and all lights/wipers/etc etc is in good order so all thats left is the bolt on bits and install glass and GO BABY! Pulls like a beast as I hit 65 into 3d on a very short stretch of road! So far the cam seems to come on @ 2500 or so?
crash914
Apr 1 2008, 04:47 PM
sweet!! bring it on by when you are out shaking it down....
Zardozz
Apr 4 2008, 05:49 PM
Took me almost an hour to read all of this and I have to say one of the best hours of my life. Most impressive...mostest impressive. I think I'm going to go work on my sticky door hardware now
plas76targa
Apr 4 2008, 07:25 PM
Josh - I did the autoX school and hope to go on 4/26. Then maybe drive up to Hershey to catch up with the gang where ever they are. Follow me up or visa versa!
crash914
Apr 4 2008, 07:47 PM
Matt, did you try the tach yet?
motor is back together.. got to finish the paint....
plas76targa
Apr 5 2008, 08:42 AM
QUOTE(crash914 @ Apr 4 2008, 05:47 PM)
Herb, yer showin yer age.. it was a spedometer. I did get it hooked up before going to the autocross school. Works fine except with my 50 series tires it reads high by about 10%..
crash914
Apr 5 2008, 08:48 AM
right on....tach speedo....whatever......I saw the transmission lifts on sale at harbor freight....Hmmmmm
back to topic...
PAINT!!!
root
Apr 5 2008, 10:50 AM
QUOTE(plas76targa @ Apr 5 2008, 06:42 AM)
Matt,
Do you still need that speedo I have saved for you? Sounds like you got one somewhere else 'cause I lammed out and didn't send you this one I have?
plas76targa
Apr 5 2008, 06:30 PM
Rod you didn't "lamm out" on me. Herb just loaned that on to me.
degreeoff
Apr 5 2008, 10:16 PM
Hey Matt, sorry had to run out of town for a family affair up nawth....I will try, BUT I do not know how my beastie will be as it'll still not be broken in enough for that trip??? We shall see?
degreeoff
Apr 7 2008, 05:08 PM
OK so after yet another trip up nawth for a funneral (2nd to last bit 'o' blood relation on fathers side) I am back at it. Details Details Details !!! What has been done
-lights in and lenses in
-weather srtipping in
-windshield and rear window in
- painted the top (with stripe), top hold downs etc, doors (with # circles), head light covers and eyebrows, windshield wipers, wheels, valances, side enginge grill covers and side skirts WHEW!
ONLY 7 PIECES LEFT! ( the hoods, bumpers, valances and engine lid all of which need to be striped....jeez am I glad this is almost over! (Need more clear coat bringing the total paint volume up to 5 gallons{unmixed} or so including primer!)
PeeGreen 914
Apr 7 2008, 06:03 PM
Can't wait to see it all together.
