914pipe
Dec 26 2013, 08:11 PM
Template
914pipe
Dec 26 2013, 08:12 PM
First time doing sheet metal... Was hard not blowing holes!!!
914pipe
Dec 26 2013, 08:14 PM
U see the wet spot... Cats fighting back!!!
914pipe
Dec 26 2013, 08:16 PM
RUST
914pipe
Dec 26 2013, 08:17 PM
Have to protect everything fast. Otherwise will rust fast.
914pipe
Dec 26 2013, 08:19 PM
Under the wheel well. Thanks GOD it's a wide body!
914pipe
Dec 26 2013, 08:20 PM
nuther
914pipe
Dec 26 2013, 08:21 PM
Doing some bending with the home made bending machine.
914pipe
Dec 26 2013, 08:22 PM
more
914pipe
Dec 26 2013, 08:24 PM
more
914pipe
Dec 26 2013, 08:25 PM
more
914pipe
Dec 26 2013, 08:26 PM
more
914pipe
Dec 26 2013, 08:30 PM
more
914pipe
Dec 26 2013, 08:31 PM
more
914pipe
Dec 26 2013, 08:32 PM
more
914pipe
Dec 26 2013, 08:35 PM
I will take a couple of day just to grind everything off...!!
914pipe
Dec 26 2013, 08:38 PM
let's fight more rust...
914pipe
Dec 26 2013, 08:39 PM
Surprise!!! FOAM!!!!
914pipe
Dec 26 2013, 08:40 PM
more
914pipe
Dec 26 2013, 08:41 PM
more
914pipe
Dec 26 2013, 08:42 PM
more
914pipe
Dec 26 2013, 08:43 PM
cut, clean and protect...
914pipe
Dec 26 2013, 08:45 PM
more
914pipe
Dec 26 2013, 08:49 PM
more
914pipe
Dec 26 2013, 08:50 PM
It won't be a show car but will be solid again!!!
914pipe
Dec 26 2013, 08:52 PM
a lot of seam sealing to do....
914pipe
Dec 26 2013, 08:53 PM
more
JRust
Dec 26 2013, 08:54 PM
Wow that is a lot of welding. Hopefully that cage is keeping everything in place for you. While it may not be a show car. You can drive the hell out of it & enjoy every minute of it. Love to see it finished. Keep up the good work
914pipe
more
914pipe
Dec 26 2013, 08:55 PM
some floor action
914pipe
Dec 26 2013, 08:56 PM
some protection while keep working....
914pipe
Dec 26 2013, 08:57 PM
the other side
914pipe
Dec 26 2013, 08:58 PM
Center tunnel....
914pipe
Dec 26 2013, 09:00 PM
pedals area
914pipe
Dec 26 2013, 09:01 PM
More
914pipe
Dec 26 2013, 09:03 PM
more
914pipe
Dec 26 2013, 09:05 PM
more
914pipe
Dec 26 2013, 09:06 PM
the other long
914pipe
Dec 26 2013, 09:09 PM
more
914pipe
Dec 26 2013, 09:12 PM
Not in order as you can see....
914pipe
Dec 26 2013, 09:13 PM
more
914pipe
Dec 26 2013, 09:15 PM
more (these are now my jack points)
914pipe
more
914pipe
Dec 26 2013, 09:18 PM
That tube go through the long to the inner tube frame.. as is, add so much rigidity (with the engine on) that the tub doesn't twist at all
914pipe
Dec 26 2013, 09:20 PM
more and some protection
914pipe
Dec 26 2013, 09:22 PM
see the tube from the inside?
914pipe
Dec 26 2013, 09:23 PM
pic of the car
914pipe
Dec 26 2013, 09:24 PM
CAT PROTECTION!!!
914pipe
Dec 26 2013, 09:26 PM
The person that welded these... didn't use gas with the mig welder.... Rust out fast...
914pipe
Dec 26 2013, 09:28 PM
Need to do some cutting
