Friday this came on the delivery truck:
Click to view attachmentI also ordered the welded support tray, it will get powder coated and then bolted to the trunk floor but this was good enough to start playing.
So I spent the rest of the weekend debugging all of the electrics, remembering this was a roller so this is the first time it has seen voltage in my hands. I got the headlight motors adjusted but despite tracking all the wires they remained up in the off position and down when turned on so I reversed the wires at the 3 way connector and left it at that.
The Headlight dimmer relay is toast and the brake warning light comes on when the handbrake is off. I am pretty sure that is related to the brake warning switch on the master cylinder but why that should be activated as it is new I have not figured out.
There are two components I have not tested, the wiper and blower motors, something for next week when I get some used parts delivered.
My fuel level sender was stuck, removing it showed why:
Click to view attachmentRust on the shaft, cleaned it all up and works great.
OK, some of you might get a laugh out of this, so here is the starter motor that came with the car.
Click to view attachmentThought it might be fun to dismantle and rebuild, well once I took it apart and looked at the cost of replacement parts ... yep forget it, just buy a new one. It had a rebuilt sticker on it anyway so it had a good life.
Last thing I did today was put on the new basket weave dash face, reason for doing this was so can put all the electrical in, hopefully for good. New material (thanks Morph) covers way more than you need and when the dash top goes on should look pretty smart.
