QUOTE(charliew @ Feb 27 2011, 08:45 AM)
I haven't tried this yet, not sure if I will need to but I do have a bubble on the edge of the seal strip on each fender. Wouldn't it be easier to just remove just the top of the fender and not distrub the lower part where the fender attaches. It really looks like the fender will be hard to put back on and seal up the way you have removed it. You probably have thought about it a lot and have it figgured out but it still looks like a hard spot to get to from under the fender and getting sealer in at the door jamb side looks even harder. I'm still thinking the only reason for the strip was to allow for a fender replacement without body work at the windshield post area. Maybe they learned from the karmen ghia. But it could be for flex also. I'm thinking I will just blast the seam out, clean it up, ospho it, seal it up with weld through primer then close it up with weld, especially the trunk channel and see if it cracks. The bottom of the welded area won't be sealed though. The only thing is if it does crack it will be way harder to fix it back stock.
You are doing so good so far I'm sure you have it under control. This thread is a really good reference thread.
Hey Charlie, I decided to make one smaller visible cut and take the 1/2 section of fender for a few reasons:
- The problem with just removing the top of the fender is the double layer in the top corner of the fender. If you come down the fender about 10" you'll clear the double layer. It'd be near impossible to weld the back side of the double layer when re-installing.
- Steel flare will cover all but about 5" of the visible cut at the top
- Cutting the jamb attachment stretch will be pretty straight forward to re-attach. There is good access from both sides to weld it back in.
On the passenger side, it isn't nearly as bad, so I'm going to...
- use a heat gun and saw blade to scrape out as much of the factory seam sealer as possible from the under side of the cowl/fender seam. There's no welds, just seam sealer for 99% of that seam.
- ospho from the top of the seam letting it soak through the seam to the under side. - prime and 3m seam seal the bottom and top side
- and finally paint.
The cowl/fender seam will be left open with no rubber seal to match the trunk and door gap. This will allow it to dry out whenever it gets wet, with not much chance to trap any water.
