Thanks for checking in on me Dean
However, the car will not be ready by WWC '11, even if I would be in town. I will be in Maui, for my sister-in-laws' wedding.
Quick question to Suby converts. Does the later stock Tach from the 914 work with the signal sent from the Suby ECU?
I found this quote the the Classics engine conversions thread:
Tachometer- Early (silver button) 914 tachometers will not register the stock Subaru ecu tach output signal. They can be modified to work with the addition of one resistor (search the forum). Later 914 tachometers should work fine. The basic 5" Autometer tach(~$100) will fit in place of the original tach and register correctly.
Can anyone confirm this? It would save me a bit of money right now until I can afford a new gauge makeover. I need to use the Tach in order to break in my Delta Cams.
Thanks!
Nate
