It started to get chilly here at night so I added heat to the driver's side of the car. The passenger side will get done eventually. I also added a front valence, rocker panels, a stereo system, replaced the ignition switch, wiper stalk and many other small things.
And now some of the things that need work:
- The transmission is hard to shift and grinds when going into some of the gears. I have tried to adjust the linkage and and clutch will no real success. I am leaning towards the transmission itself so that might get replaced sometime in the near future.
- The driver's side rear has a camber issue. I'm going to swap out the trailing arm with a spare to insure it is not bent.
Click to view attachment-Emergency brakes/ rear calipers need adjustment.
-Fresh air fan does not work. I cleaned the contacts but that didn't work. I will get around to replacing the fan.
-Passenger side needs heat ducting
-Wheels & tires need to be finished
-New axles need to be installed.
-Front steering pan needs to be painted and installed.
-Driver's door doesn't want to close some of the time.
-Interior light doesn't come on when door is open. The door switch is suspected.
-License Plate Lights need to be installed.
-Defrost illumination light doesn't work
-Clock doesn't work
To be continued...
