dlee6204
Apr 4 2012, 09:36 PM
So its been a while since my last update. Lots of work has been going on... I'll add some tonight then more to come soon...
Here is the seam for the rear fender before welding it up
Click to view attachmentI had to replace a small section too. Sail panel holes were also welded up.
Click to view attachmentClick to view attachment
dlee6204
Apr 4 2012, 09:37 PM
dlee6204
Apr 4 2012, 09:39 PM
dlee6204
Apr 4 2012, 09:42 PM
dlee6204
Apr 4 2012, 09:52 PM
Front fenders also needed to be partially replaced. Passenger side had some damage that was cut out before it came to me.
Click to view attachment Replacement piece tacked on
dlee6204
Apr 4 2012, 09:56 PM
My spot welds came out stealthy
Click to view attachment Seams finished off, bumper clip welded on, paint stripped. The side marker hole has since been filled too.
dlee6204
Apr 4 2012, 10:04 PM
Socalandy
Apr 4 2012, 10:33 PM
Awsome
rick 918-S
Apr 5 2012, 08:34 AM
Nice work sectioning those fenders.
broomhandle
Apr 5 2012, 10:22 AM
Holy crap, nice work. I thought i had horrible rust. but, your work has shown me a lot. keep it up!
saigon71
Apr 5 2012, 04:02 PM
Wow...awesome work! Keep it up.
trojanhorsepower
Apr 5 2012, 05:55 PM
Man Chris,
Looks like you got the right guy on this...
Doug, any chance random people could stop by and watch you work.
I am stoked to see another NC Teener
Pete
dakotaewing
Apr 5 2012, 06:48 PM
What are you using to grind those welds?
Good Job!!
dlee6204
Apr 5 2012, 08:02 PM
I use a 36 grit flapper disk to cut back most of it, then follow up with an 80 grit to finish it off.
dlee6204
Apr 5 2012, 08:07 PM
Pete
Anybody can literally stop by anytime and shoot the breeze. I'm always up for meeting new people and talking cars.
dlee6204
Apr 5 2012, 08:20 PM
Here a few pictures of the front hood. Overall it had about 6 dimples and one bigger goofy dent. A little hammer and dolly work took care of most of it. No filler for this hood.
Click to view attachmentClick to view attachmentClick to view attachmentI should add that after I've gotten done with a repair, I hit it with some rattle can primer so it doesn't rust. All of which will be removed before I hit the areas with epoxy primer.
dlee6204
Apr 5 2012, 08:31 PM
The Pass. rear fender has numerous dents and low spots. Only a couple of them will need hammering out, the rest will smooth over with some sanding and primer.
Click to view attachment Click to view attachmentIn case anyone was wondering what happens when you powdercoat the body, the lead filler liquifies.
Click to view attachmentClick to view attachmentAnd this one has me stumped... There was a spot of lead filler underneath the targa bar.
dlee6204
Apr 5 2012, 08:52 PM
And here is my biggest accomplishment so far.
The driver's side rear fender had a really nasty dent in the back. It was my goal to get the dent pulled out and repair it so that it will need no filler. It was a lot of work but mission accomplished. Tools used: hammer, dollies, stud gun and puller, metal files and a big ole shrinking disk.
Click to view attachmentAfter I got the panel into shape, I started filing the top of the area to get it smooth.
Click to view attachmentThis shows some low spots after I started filing
Click to view attachmentMore or less finished.
I wish I would have taken better pictures throughout the process.
993inNC
Apr 7 2012, 07:39 PM
Looks pretty damn amazing from my house Doug! We gonna take first at pebble beach with it
SUNAB914
Apr 8 2012, 05:03 PM
dlee6204
Apr 15 2012, 09:12 PM
Got some work done on the doors. The passenger door had some dents and one small bit of rust. The driver's side had more rust though. Both doors though had large oil-canning on the bottom half. Possibly from the heat of powder coating. I got both doors roughed back into shape but they will need a skim coat of filler.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentAfter some heat and hammer and dolly work
dlee6204
Apr 15 2012, 09:14 PM
dlee6204
Apr 15 2012, 09:23 PM
And the driver's door... the 'fun' door
Click to view attachmentClick to view attachmentI started by cutting out the bottom channel completely.
Click to view attachmentI then cut out a strip of some 20 gage steel
Click to view attachmentMade a 90 degree bend
Click to view attachmentAnd used a steel block to form the U-shape
dlee6204
Apr 15 2012, 09:28 PM
Voila!
Click to view attachment Click to view attachment I welded it in! I smoothed over the welds and its now good to go.
dlee6204
Apr 15 2012, 09:33 PM
993inNC
Apr 16 2012, 07:36 AM
Dude, really, that is very cool! And the bottom edge of the door didn't warp with all that welding? I never even thought about cutting all of that out, just thought we'd fill it in.
Great work......
FourBlades
Apr 16 2012, 10:32 AM
Nice repair work!
John
dlee6204
May 21 2012, 07:34 AM
dlee6204
May 21 2012, 07:42 AM
Lots of tedious work has been happening... I have been focussing on finishing the bodywork for the doors and lids. I started off by sanding everything, applying an epoxy primer over any bare metal areas, and then adding filler over that. This is followed by several stages of high build primer and block sanding. They have their final stage of primer and after I finish the rest of the car, I will wet sand everything down in prep for paint. I'm not going to paint it, Chris will find someone else to do that.
Click to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachmentClick to view attachment
dlee6204
May 21 2012, 07:46 AM
I also started working on prepping the rest of the car. I sanded the underside of the floorpan and applied some epoxy. I will add seam sealer and then apply a second coat.
dlee6204
May 21 2012, 09:05 AM
Cairo94507
May 21 2012, 03:08 PM
Wow
That is some serious work and nicely done. Love watching the progress of the build.
speed metal army
May 21 2012, 11:30 PM
QUOTE(Cairo94507 @ May 21 2012, 02:08 PM)
Wow
No sh!t!!!!seriously, crazy nice work and dedication. Hats off.
saigon71
May 22 2012, 06:11 AM
Impressive work...especially that door channel piece.
Keep it up!
dlee6204
May 22 2012, 08:55 AM
Thanks guys.
The underside of the floorpan is pretty much done.
arkitect
May 22 2012, 09:06 AM
Very talented repairs...it will be like new after you are done.
Dave
993inNC
May 22 2012, 09:08 AM
Are we spraying the entire car that white epoxy Doug? That white will go a long way to helping the factory yellow really pop!
Work looks great from here BTW
dlee6204
May 22 2012, 10:38 AM
Chris, ill try to give you a call tonight. There's a few small things we need to discuss.
993inNC
May 22 2012, 04:25 PM
Ooo that doesn't sound good!
dlee6204
May 22 2012, 04:32 PM
I said SMALL stuff
dlee6204
May 27 2012, 10:01 AM
I got the floors and engine bay epoxied and sealed. I'm being very thorough with the seam sealer but I'm making sure not to use too much and not to glob it on there. I will shoot a second coat of epoxy in the morning and then these areas will be done.
OllieG
May 27 2012, 11:13 AM
Great stuff going on here, nice one!
Are you sanding down each coat of epoxy so the next layer can key to it?..or is it working without?
Ollie.
dlee6204
May 27 2012, 11:29 AM
For the epoxy primer, I sand the surface with 80 grit and then apply the epoxy. You can re-coat the epoxy up to a week without having to sand per the tech sheet. So when the car goes in for final paint, everything will have to be scuffed up again.
dlee6204
May 27 2012, 11:31 AM
I should also add that the primers I am using are from Southern Polyurethanes.
http://www.southernpolyurethanes.com/
dlee6204
Jun 7 2012, 05:05 PM
UPDATE: I've been getting a lot of work done. I started by prepping the driver's side, hitting it with some epoxy primer, seam sealer, body filler, high build primer and block sanding. That side is pretty much done, just needs final sanding.
The cowl area also got done.
Click to view attachment Click to view attachmentI also used Eastwood's Internal Frame Coating in all the cavities possible.
Click to view attachmentWhat's left to do: Passenger side fenders and final sanding.
Jacob
Jun 7 2012, 05:44 PM
Great work! Thank-you for posting your progress. Very educational! Much appreciated!
dlee6204
Jun 24 2012, 07:01 PM
Well the body is pretty much done as far as I'm concerned. I gave it two coats of epoxy primer/sealer and gave it a wet sand. Bodywork came out great.
Click to view attachmentClick to view attachmentI used water when taking these shots. The epoxy is NOT that glossy.
dlee6204
Jun 24 2012, 07:03 PM
Cairo94507
Jun 25 2012, 06:48 AM
Wow - very nice I can't wait to see it with color.
trojanhorsepower
Jun 25 2012, 05:31 PM
Doug,
That looks great! What are you going to do next?
Peter
