thought I would throw out a quick update - been awhile and been working all the little stuff that it takes to wrap things up.
Rear is fully welded along with the uprights fully TIG'd, etc and the car is officially sitting on the ground in the rear, on the springs, ready to roll. My custom stub axle adapters are all welded up, so now I have removable/rebuildable 930 CVs inside and outside on the Carrera axles.
Not being able to rebuild the outers has been a thorn in my side since I bought that setup but the axles fit perfectly and it is nice to have an off-the-shelf item.
Various UPS orders and delays would move me around a bit and sometimes really blow a weekend, but I got the sway bars and custom bent links (they are steel and unfortunately rather heavy - 13lbs per end!) and finally my other rod end showed up to put the front tie rods together and get the front end squared. It is nice as I used the computer to determine nominal toe link angles for near zero bump and doing this both front and rear meant that I measured the link angle with a gauge when I installed them, and sho' nuf, when I checked bump all four corners were spot on.
I had to order some more tubing to mount the rear sway bar, notched the existing chassis to fit it in, welded it in with reinforcement, all that good noise so now I have a rear sway bar finally! Much needed after I added the LSD sequential trans.
The front sway bar mounting was already set up for the 1" diam Tarret bar, so I had to remachine and grind out some of those pieces to work with the new 1.25" diam Speedway front bar and all that is done and the front bar is also now installed.
Was cutting downlinks tonight from tubing so I hope to get them drilled and threaded tomorrow or Fri, then Sat my buddy is set to come over (barring he doesn't get called into work, he has had insane OT lately = bad for me
) and finish weld the front upper A arm stuff.
I am actually thinking I may be able to fire the car up and hammer around the block by Sunday :knock on wood/hope I didn't jinx that smiley: I sure hope so, weather has been perfect for a track day and will not be so in a few weeks.
Will be gone to SEMA first week of Nov as well, so I want to keep rollin' on this and be done!
