CCW has an offset that I would prefer too... argh. The real selling point was the looks of these wheels, I really like the centers and they tend to be pretty unique in the 3pc wheel world. CCWs look like every other BBS copy... I dunno. I really try to keep some level of form in the function equation on this car, and I really think these wheels look great on the car.
But the CCWs are damn tempting... to the point of getting a set, then telling Kodiak when they get around to it, make me new halves whenever and have the backup set. If anything could put a more DOT legal tire on 'em for the street
I currently just blast around the neighborhood main roads with the slicks when I test drive, but if a cop were a tool he could tow the car as it wouldn't be considered "road worthy" on the slicks, even if I were only a block from home.
Meanwhile, more of this coming
I now have the lower As so fricken square you can't even measure the difference in cross or wheelbase on a tape, so less than 1/32", so the heims are locked down and I started building the upper As in the rear last night.
Rear wheel spacers are down to .350" thick with the bias plys, will be thicker with radials if I go back to them as the top comes way in, around 3/4" like I mentioned before. Nice thing about the thin spacers is I can use the hub centric feature on the hub itself, not the spacer, so less tolerance stackups which is what I am really after.
So now I don't feel so bad letting the cat out of the bag - this car was NOT square before by any stretch of the imagination or tape measure. I spent two days after I picked it up, one weekend before I moved to CO, with my circle track friend Scott trying to set this car up. He has built track cars on the floor of his garage in Moreno Valley and decades of racing means he knows his shit. We fought this car, gave up and got it as close as possible after a 15hr Sat and 12hr Sunday. The two of us can square a car within a couple of hours typically. Right off the bat we realized that somehow the whole rear end is shifted over 5/8" (!) and why I had all the new custom brackets waterjet so I can get everything where it belongs - the right side brackets in the rear are 5/8" longer at the lowers, same length at the uppers as the left.
Before I had different length tubing right to left, all sorts of shit just trying to get by, so now you guys all know why I decided to just hack in so deep and really redo everything.
So for guys like Brett - imagine what my RCs and ICs were like before! Certainly not symmetric and would have wandered like a mofo. And if I lowered the car 1" it would start bump steering in the rear to the tune of 1/8" in the next inch... PER SIDE.
Embarrassing to admit since this is stuff I caught and would have had fixed, but unfortunately I was moving out of state by the time it was in finishing stages, so I had to accept what I got.
Car bodywork is within 1/16" on all corners now with lower arms at exact same adjustment - damn fricken tight for a garage job
I had to square the rear body work a little (it was out a bit as I fudged it to make the previous stuff seem ok) and now am plumb bobbed exactly the same fender to hub on the front and 1/16" out on the rear so a little more squaring, but everything is where it should be.
Finally. Need :smiley with poor bastard wiping sweat from his brow:
Feeling pretty good as it should be a much nicer car to drive now. It was a handful before when it wasn't squared up - makes a car freakin' DARTY, 'specially at speeds around 150-160mph when things aren't square. I need to knock on wood to remove the coming jinx, but I am really looking forward to seeing how this thing drives with the new stuff.
